Team_Sprite
What are we doing wrong? We didn't check the drive-shaft yoke / smooth-case tail-shaft compatibility before installing the motor/gearbox (do people do that?), and now seem to have about 2-3 (+/-) inches more drive-shaft than needed. The yoke only goes on around 2" to the tail-shaft and stops, the 'collar' on the drive-shaft just fails to reach the seal/spline. (the teeth match) The drive shaft is aprox. 33." We were just given a shorter drive-shaft, but the yoke has finer teeth. I can switch yokes if need be, but it seems something else is wrong. We purchased the trans separate from the car, so this gearbox and drive-shaft have never even been on a blind date before. I will try the yoke on another tail-shaft over the weekend, and if it fits, then, I guess, we pull the motor back out (sigh) but would sure like to avoid that. So: how far does the yoke fit over the tail-shaft? Does it have free play just before bolting up the rear-end? What's up? As Willie sings: Time slips away....
Brian & the girls
www.teamsprite.com /ubbthreads/images/graemlins/grouphug.gif
Brian & the girls
