Heavy hex nuts
TulsaFred
The cylinder head and exhaust manifold nuts on my 1275 look about double the thickness of a standard nut.
Didnt see any at Lowes, anyone know wher I can get some?
Thanks
Fred
You need to order the proper hardware from a specialist.
aeronca65t
Part #13 HERE
$0.85 each.
TulsaFred
TulsaFred
thanks guys
looks like the exhaust manifold nuts may be brass, in which case I can probably just reuse the old
Fred
Jim_Gruber
Fred,
You need some new gaskets likely anyway. Order from MOSS or VB and the nuts you need won't add any more to the shipping charge. Go new with the nuts on the exhaust and do them in brass. There is an engineering reason Heat expansion/contraction and staying put I'm sure in addition to the fact you can remove down the road if you need to.
jlaird
Header nuts are brass, reuse em.
T supporting BE tonneau cover during heavy rains Spridgets 10
RAC68 Heavy Tapping low in the Engine Austin Healey 58
hondo402000 TR6 TR6 Heavy duty front Stub axles Triumph 12
RJS TR4/4A TR4A Heavy Clutch Pedal Triumph 2
kurts100 Bugeye Lever Shocks/Standard or Heavy Duty Rebuild Spridgets 14
athenssprite heavy smoke on start up - burning oil Spridgets 13
UmmYeahOk Shipping heavy bulk items [triumph related] Triumph 17
QuickSilver Right Snap Under Heavy Braking MG 9
Jer TR2/3/3A How long/heavy is a TR3A ? Triumph 6
C TR6 TR6 Heavy Duty Headligh Harness Triumph 9
B HEAVY WEATHER ALERT!! Tyler,Texas Regionals Triumph 2
kyreb1862 Heavy Duty Headlight Harness MG 2
RickB MGC Recommendations for heavy rust removal [MGC] MG 36
Randy Harris Heavy fuel odor in car Austin Healey 2
Randy Harris Heavy fuel odor in car Austin Healey 4
Randy Harris Brake Lights Work Only With Heavy Pedal Pressure Austin Healey 12
B Heavy Clutch Pedal Triumph 6
SCguy Installing a VB heavy duty light harness?--Up-date? Triumph 8
Nunyas heavy stumble at low RPMs - Catalytic Converter? MG 5
John_Mc Heavy duty manifold gasket Triumph 6
R Heavy Clutch Austin Healey 8
F Midget with heavy steering and no recoil. MG 7
AN6-TX Hex Nut 2BA? Austin Healey 4
C A great substitute for a "Not Quite 3/4 Inch" hex wrench Austin Healey 9
A Hex head bolts with the pointed end. Triumph 8
C Hex. nut size? Austin Healey 1
petnatcar Cylinder Head Nuts - Tightening Sequence Austin Healey 2
Scotsman TR4/4A Chimney nuts, where do they go Triumph 5
S TR2/3/3A ¼ fine square nuts Triumph 7
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
shadowfever Midget seat nuts and bolts Spridgets 2
A BN7 Front Hub Stud Nuts Austin Healey 5
T Storing nuts and bolts (so you can find what you need) Austin Healey 7
Z Lug nuts for Minitor rims Spridgets 1
HighAltitudeTR3 T-Series Why are there nuts in my core plugs?! MG 8
D Rear Brake Drum Nuts Austin Healey 15
Lin Water Pump torque value for nuts on studs Austin Healey 1
steveg TR6 Loose wheel nuts after torquing Triumph 2
D TR2/3/3A Wing nuts for gauge panel on TR 3 Triumph 10
K TR2/3/3A Coil nuts? The SW and CB nuts on a Moss gold coil? Triumph 3
J TR2/3/3A caged nuts problems Triumph 12
T TR2/3/3A Can someone confirm size and thread count on fuel line tube nuts [brass fittings]? Triumph 16
Rob Glasgow Rear Hub Nuts Austin Healey 11
D TR2/3/3A More small nuts [ and studs!] Triumph 2
healeyblue Longbridge side screen star shaped nuts Austin Healey 15
AUSMHLY BJ8 Manifold, how many brass nuts? Austin Healey 2
banjojambo TR2/3/3A TR3A Re-torquing Head Nuts Triumph 7
T TR2/3/3A Is there any problem in putting TR6 plastic wheel covers & TR6 lug nuts on TR3 wheels Triumph 4
Lin Rear Axle Hub Nuts Austin Healey 3
