ENGINE OIL TYPE ?
BOBBYR
Hey Gang,
It's been a long time since I've been on and I hope everyone is doing fine.It's time for me to change the oil in my 65 and I thought I would try getting A good recommendation on oil type and weight.Any help would be appreciated.
Thanks
Bobby R
Fishplate101
Hi Bobby,
There is a lot of noise in the blogs regarding this matter and Vavoline VR1 20-50 racing oil for street or tract.
Regarding ZDP level and flat tappet engines.
Bulletin from Vavoline ---> https://www.valvoline.com/downloads/2008-003a.pdf
I went with Racing VR1 20-50 plus one quart of Lucas Heavy Duty Oil Stabilizer.
My BJ7 is very happy, it's hot down here in Florida, I get 60PSI on cold start and 50-55 when running hot, 20 idle.
Also, I was having trouble with over heating, flushed the radiator, added 3/4 water 1/3 antifreeze and Red Line water wetter.
She runs right at 190 now or lower and when stopped for a long time holds steady at 200-210 in Florida.
I may try an improve on this by running a six blade fan and add more wetter.
Fishplate101
Editor_Reid
Platinum
Fishplate101 said:
...I was having trouble with over heating, flushed the radiator, added 3/4 water 1/3 antifreeze and Red Line water wetter.
Gee, with the radiator already 13/12 full, how on Earth did you find room for the Water Wetter?
(Sorry, I couldn't resist. <span style="font-style: italic">Somebody</span> was gonna say something, so why not me?)
Oh, and Bobby, my best read on all of the recent discussion on oils is that VR1 is a very good choice.
BOBBYR
BOBBYR
Hey Guys,
Thanks for the quick response.I've got to get this done soon and I would like to get my cooling system flushed out also.It's been nice weather here on the east coast but winter isn't too far away.Like I said before, I haven't been on the forum for some time and it's nice to know the good guys are still here.I hope all is good with you.
Bobby R
Fishplate101
Hey Reid, your are right the math is fuzzy, I don't remember the coolant running on the ground and this puppy runs much cooler now!
I must have been in a hurry while typing sorry about that, and this wetter job was done 4 months ago.
Red Line mixture down here in the swamp is going to be different for most folks anyway. It worked out to about 6 pints of antifreeze.
I could back the antifreeze off more down here. So it should say 2/3 water including the wetter agent, but this would be incorrect for cars located
up north during the winter, read the instructions for your temperature zone.
Cheers,
I'm a Fish now.
GregW
Platinum
Recovery tank. 'Prolly holds more than that extra 12th+ :laugh:
M Photos Needed of Series III E-Type Engine Oil Filter Clearance at Exhaust Manifold Jaguar 1
B Engine Oil Type and Weight? Austin Healey 8
M new engine rebuild, new type oil seal and LEAKS ?? Triumph 15
tr6nitjulius Oil flow view inside operating engine Other Cars 4
D TR6 Disconnecting pipe from engine block to oil pressure gauge Triumph 6
nevets Oil soaked engine bay Austin Healey 32
T TR2/3/3A What is best way to flush engine after antifreeze got in oil?? Triumph 2
T 1275 engine oil pressure warning light? oil filter warning light?? Spridgets 4
KVH TR4/4A I Can't Stop Burning Oil; Engine Missing at Take Off Triumph 5
S My recent decision regarding oil in a '66 3000 with a rebuilt engine Austin Healey 101
B TR2/3/3A Engine Oil Pressure Triumph 7
H What are the pros and cons for full synthetic oil in a 948cc engine Spridgets 5
H Preferred Motor Oil for 948cc engine? Spridgets 6
gbtr6 TR6 Prime oil pump in rebuilt engine... Triumph 10
M TR4/4A Oil pressure line from engine....assistance please. Triumph 9
T TR4/4A Restarting an engine - oil pressure problem Triumph 6
JPSmit engine oil cooler question Spridgets 11
KVH TR4/4A Removing Oil Canister/Pressure Housing from Engine Block Triumph 5
TulsaFred Front engine oil leak Spridgets 33
David Townsend TR2/3/3A Engine Oil Cap Decals Triumph 0
sundown TR6 1973 TR6 oil between the head and engine block? Triumph 11
T TR4/4A Any problems with new oil pumps for TR4 engine? Triumph 8
C new engine - oil pressure blowing filter seal Austin Healey 12
J Engine block modification for oil to water jacket leak Austin Healey 8
drooartz MGB At what oil pressure do I need to dig into the engine? MG 21
PatGalvin TR2/3/3A TR3 Engine Front Sealing Block, Oil Pan Screw Size and Thread Pitch? Triumph 11
Tim Tucker Front Engine Oil Galley Plug Triumph 10
V TR2/3/3A TR3B Engine Oil Triumph 8
P Engine & Gearbox Oil Austin Healey 3
H Engine oil Austin Healey 4
KVH And for the Engine Oil Leak Triumph 3
memphis Engine Side Cover Plate Oil Leak Austin Healey 15
V How much extra engine oil with oil cooler??? Spridgets 5
F Engine painted! Questions on Oil? Spridgets 27
coj oil pressure 1963 engine [29F] Austin Healey 7
T Oil for an anciente engine Spridgets 3
I oil/oil additives for stock Bugeye engine? Spridgets 10
L Low oil pressure in new engine Austin Healey 67
R flush oil & water pathways in engine Spridgets 4
I bugeye 948 rebuilt engine - no oil pressure, Spridgets 7
doughairfield Oil during engine break in Triumph 6
bighealeysource oil leaking from engine side covers Austin Healey 25
Number_6 TR4/4A Oil Leak on TR4 Engine Triumph 9
beachbumbarry Rebuilt engine oil pump MG 1
M Engine Oil Leek Raising Some Concerns Spridgets 2
pjsmetana Auxiliary Oil Feed to Rockershaft on 1500 engine Triumph 4
roscoe Oil should be INSIDE the engine... Austin Healey 11
MGBGT_noob oil pump for rebuilt engine MG 17
tony barnhill '63 Midget Engine to Oil Pressure Guage... Spridgets 8
Bruce_B Need help with oil pressure on startup of engine!! Spridgets 8
