Attempting to start a 20+ year old engine rebuild. Turned it over with the started without plugs and that generated two questions. First, should the engine being turned with the started be enough to cause an indication on the oil pressure gauge? And, secondly, should the engine being turned by the started cause oil splash on the rockers and push rods? I'm concerned about both the oil pump and the oil pressure gauge.
