Hi,
This engine was last run 17 years ago. At that time, there were no issues with oil pressure - 50lbs cold, 20lbs hot, with 10W-40. The engine turns freely by hand now. I'm working to get oil pressure before I start it. I've tested the gauge. Turning the oil pump (CCW) by hand will fill the oil filter canister, verifying that the pump is picking up oil from the sump. But turning the oil pump faster with a drill does not produce pressure even after 30+ seconds.
Could the oil pressure relief valve be stuck, perhaps, and block oil flow up into the block? I see no pressure at the gauge and no oil at the rocker.
Any advice is greatly appreciated,
Cliff
Cliff
