I'm rebuilding a 68 Copper S LHD. I've rebuilt the front suspension and brakes and am now putting it together. The manual says insert the drive shaft thru the spindle and slip on the brake rotor and collar and tighten the castellated nut. "Make sure you have .006 inches clearance between rotor and the edge of the brake caliper." But it doesn't say how to adjust this clearance. There is no reference in the manuals or parts books about shims that go between the drive shaft and the bearings or any reference to adjustments that can be made. Any ideas?
Thanks Dominick
Thanks Dominick
