Door seal color.
Keoke
Hi John, Stock door seals {Furflex} were black but you can use blue if that be your preference.--Fwiw--Keoke
SHG
Hi John,
I've seen them in blue on blue interior cars, and they look good but noticeable. If you want the door seals to stand out, they blue is the way to go. If you want them to blend into the car so that the interior is what you look at, then go with the black. I went black, as the furflex wasn't the thing I wanted people to remember about my car.
J
John_Progess
Scott,
Is your BJ8 a phase I car? If so, I am looking for a picture of the magnetic latch on the cubby box. I like your thinking about what stands out so I think I will go with the black. Thanks and have a good day!
John
AUSMHLY
From page 171 of the Gary Anderson and Roger Moment Authentic Restoration Guide:
Door Opening Seals
Door seals on the convertibles, as with previous models, consisted of a continuous-bulb rubber seal with an attached tail that pressed against the door when closed, secured over the steel lip of the door opening by continuous spring-steel clips covered with Furflex in a color matching the primary interior color.
I went with blue. I did not use "Furflex". I used a brand from one of our vendors here. "Bristleflex" The blue color was so close to the blue carpet, it blends in nicely. Plus it installs so easy. Just push on and it stays. No rivits nor glue needed at all.
Photo included.
Best of luck with your restoration,
Roger
Keoke
Well Roger, so much for that page in the book. However, I do know that the "continuos bulb" did not have an attached tail!--Keoke
Keoke
John_Progess said:
Scott,
John
Hi John, The factory parts manual shows that latch clearly on page BN8. It looks very much like a current magnetic cabinet latch and I imagine you could make a replacement if it is not available using the core from one of the current ones.--Fwiw---Keoke
J
John_Progess
Keoke,
I did see that illustration and I agree it should not be to difficult to make. I was hoping for a picture to get the relative size of the latch. Thanks and have a good day!
John
John Loftus
Keoke, The original door seals had a tail coming off the continuous bulb to give a better seal against the door panel. The attached image shows it on some correct door seals under development (the tail is the part at the bottom that looks like the tail on the letter Q). I'm a bit shocked that you didn't know this! /bcforum/images/%%GRAEMLIN_URL%%/grin.gif
Cheers,
John
D Top Door rubber and fuzzy seal Spridgets 5
Popeye TR4/4A Door seal channel near top of windscreen Triumph 6
Bayless Door seal question Spridgets 3
D Door Seal Fit Austin Healey 18
chicken BJ7 Door Seal Austin Healey 5
chicken Inner Door Seal Trim Position Austin Healey 6
volunteer Wanted Need Door Seals, Vent Window Seals and Trunk Seal for Daimler ds420 Limo Jaguar Classifieds 23
B BT7 Door Seal Installation Austin Healey 13
S TR2/3/3A door seal windlace Triumph 8
S TR4/4A door seal channels Triumph 3
D Photos of Longbridge BN4 door seal track. Austin Healey 5
Got_All_4 TR2/3/3A What is this door seal for Triumph 15
R TR2/3/3A Door bottom seal Triumph 10
R TR2/3/3A Door seal Triumph 2
bugedd Door seal replacement Spridgets 11
S door glass inner seal Austin Healey 6
W TR6 fuzzy rubber door seal Triumph 3
vette Door Seal Austin Healey 4
W Fender > Door Seal Austin Healey 8
Jeepster Door to window brush seal Austin Healey 0
H TR4/4A Furflex door seal Triumph 3
B TR2/3/3A TR3b lower door seal question Triumph 3
H TR4/4A Outer door waist seal Triumph 5
Lbp TR2/3/3A Furflex Door Seal - Where does it go? Triumph 3
NutmegCT Source for rubber door seal material? Restoration & Tools 9
HealeyRick BJ7 Door Seal Attachment Points Austin Healey 0
B BJ8 door seal attachement point. Austin Healey 4
B '72 XJ6 Door Seal Installation Jaguar 2
TR4nut TR2/3/3A TR3A door seal question Triumph 7
B door seal material an suppliers Austin Healey 2
Q TR2/3/3A TR3A Spare Tire Door Seal Triumph 3
Stinger TR4/4A TR4A Door Waist Seal Tool Triumph 8
F Replace 1500 Door Fuzzy Weather Seal Triumph 3
MadRiver BT7 Fuzzy Door Seal Install Question Austin Healey 1
CJD TR2/3/3A TR3 Rear Door Seal? Triumph 2
chicken Door brush and rubber seal Austin Healey 2
I Bugeye door seal help please Spridgets 8
D BJ8 Door Seal Orientation Austin Healey 6
V Another door seal question. Spridgets 5
W TR2/3/3A TR3 Door Seal Rubber Question photo request Triumph 4
P BT7 Door seal Austin Healey 15
R BJ-7 Furflex door seal installation. Austin Healey 1
Newkie General Tech How to Install Door seal-furflex MG 14
G BN6 door seal clips - how many? Austin Healey 2
I TR6 TR6 window door pull/window seal help Triumph 6
A Door/Trunk Seal Spridgets 5
NutmegCT TR2/3/3A TR3A door "draft seal" Triumph 3
R BJ& front fender/door seal. Is there one? Austin Healey 2
JPSmit rubber door seal question Other Cars 2
bighealeysource aluminum trim piece for 100-6 BN4 door seal Austin Healey 2
