Braided Steel Brake Lines with Toyota Caliper
SCguy
Now that I've put my wheels on my TR4 I can see that my steel lines will rub againts my wheels while turning. Those of you who have steel lines how did you solve this?
Here's a TR6. Notice the line points up and is located on the opposite side.
71tr
Seems that you might need to fabricate some sort of small bracket similar to the TR6 setup that will hold your steel lines in place. Check out moss' website for their toyota brake kit, i think they have photos of a similar fix. By the way that is a great shot of your suspension/brake setup, very professional.
Alan_Myers
Hi again Larry,
That flex line looks way too long to me, but I am not working with Toyota calipers and they might require something different than I'm used to.
You can reposition those flex lines a bit by bending the mounting tab on the frame. Also, you can often loosen the fitting and repostion/retighten so that they bend a specific direction. I'm not sure if that's enough to resolve the problem here, though.
Hoepfully, someone else who is using Toyota calipers will jump in here.
G
[ QUOTE ]
I sent an e-mail to Ted at TSI and I'll be interested to read what he has to say.
[/ QUOTE ]
I hope you included a copy of the picture in your email. Seeing is believing.
PeterK
Before TSI offered a full flex line conversion from metric to SAE, most, including myself, made up a short section of hard line that goes between the Toy caliper and the original bracket on the backing plate; from there I used a standard TR SS flex line. And it's a nice clean install. Hate to say it but your hose is way too long (hahahaha). You might try putting a loop in the line to shorten it and then tie wrap to avoid binding in the spring. I can post a picture of my setup if you want.
ALLAN
The problem is the TSI adapter sticks out of the caliper too far, I have talked to Ted about this after installing mine, there is a saftey issue with his set up. What I did is use the original hard line bracket that bolts to the caliper and drilled the hole that the line connects to as big as it would go and then installed a rubber gromet in the hole and ran the steel line through the gromet. It holds the line in place and keeps it away from the springs and wheels. The rubber gromet has to be put on the steel line first and then pass the line through the hole and then push the gromet into the hole. I had to tweak the bracket a little to get the line in the right position.
ALLAN
If you go with the bracket like the one I made, it helps hold the line in and takes up some of the slack. It was pretty easy to make up using the original brackets that bolt to the calipers.
G
Larry, there is something that has me a little worried about your setup. The end of the hose that fits into your brake seems to thread right in to the area directly and has nothing to take the load off the hose and the threads. I am not worried about the hose popping, I am concerned that the constant turning back and forth of your steering will in short order loosen that fitting. It won't take much more than a slight torquing of that fitting to break the seal and.... no brakes. Are we on the same page?
ALLAN
The connection is tight enough that the line will flex without the connection moving. But with the bracket you wouldnt have to worry about. I think you can see that bracket pictured in the hanyes manual (tr4a tr6) and/or Roadster Factory catalog or Victoria British. It is an L type bracket that bolts to the caliper--underneath the caliper bolts.
martx-5
I ran into a similar problem with putting the Toyota calipers on my TR3. My hose also comes from the back of the spring. I made a bracket to fit into one of the caliper mounting bolts to hold the adaptor line to the braided flex line. See the attachment for the finished installation, and then in the next post I will show the bracket itself. (I don't know how to put two attachments in one post.) I roughed it all out, and then tweaked where the bends and twists would be while on the car so I could see how everything lined up.
martx-5
OK, here is the picture of the actual bracket I made. The twist would of course be in the opposite direction on the other side.
Of course, the other thing is is that my set-up is two seperate pieces. The adaptor for the caliper, and the original line that Triumph used...except braided. It looks like yours is one piece. With the two pieces, I was able to secure the section where they connect into the bracket, as there is plenty of threaded section on the end of the flex line to secure with another nut onto the bracket.
ALLAN
This is very close to the stock bracket that comes on the TR6-very nice, however you are using the regular braided line with a hard pipe connection (almost like a stock TR6 setup).The real problem is when using the TSI type line with adapter strait into the caliper like SCguy. My bracket is like yours with a rubber gromet in place of the hydralic connection which allows the braided line to run through.
G
I think I have a pair of rigid brake lines pieces that come off the caliper for for the transition year that Triumph tried to go Metric, if anyone wants them. I am pretty sure I still have them (never been installed) but will have to do some digging. Dave at TRF sent both types to me years ago when they rebuilt my calipers and forgot to check the thread type. Mine are standard, these should be Metric.
I still disagree that the flexible hose installed directly into the caliper is good enough. Tighten all you want (and there is just so much that you can tighten before ruining the fitting) but they WILL come aloose (Southern word) in time with the steering movement of front wheel assm. It is an accident waiting to happen.
T Braided steel brake lines - worth it? Triumph 13
davidk TR6 Braided Steel Brake and Clutch Lines for TR-6 Triumph 1
J Fitting 5/16" Steel to 5/16" Braided SS Rubber Fuel Line Austin Healey 4
S Steel braided fuel line Spridgets 7
G Braided Stainless Steel Hydraulic Hoses Austin Healey 15
Jim_Gruber Braided Line for Spin Off Oil Filter Adapter Spridgets 13
SD Bugeye HS2 interconnecting SS Braided fuel hose Spridgets 7
K TR2/3/3A SU Braided hose Bling? Triumph 6
NutmegCT braided fabric fuel line cover Restoration & Tools 8
coj Braided fuel lines 29 f engine Austin Healey 2
T Oil Pressure Gauge braided line failure Austin Healey 6
98Redline BJ8 Stainless Braided Brake Hoses Austin Healey 8
DNK Braided Lines MG 4
memphis Braided Wire Insulation Austin Healey 12
J Braided ground cable Triumph 3
G A word of caution about using braided hoses..... Triumph 15
jhorton3 Braided Oil Pressure Line Spridgets 12
A Cutting S.S. Braided Hoses Triumph 4
K TR2/3/3A The steel head stud washers? Triumph 7
Tim Tucker TR4/4A Phoenix Stainless Steel Sports Full Exhaust System Inc Manifold experience Triumph 3
S TR2/3/3A brass fitting from a steel brake line Triumph 2
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
S For Sale Bugeye wheels, steel with round holes set of 5 available Spridgets Classified 0
D Wanted Bugeye bonnet (hood) fiberglass or steel Austin Healey Classifieds 0
Guido36 Stainless Steel Bumpers Austin Healey 5
B Stainless Steel Exhaust System Wanted Austin Healey 5
Got_All_4 TR6 2nd Gear Bush Problem TR6 Looking at Steel Triumph 12
S TR2/3/3A steel bushings for the lower Arms Triumph 10
Popeye TR4/4A Crankshaft pulley recommendations: One piece alloy, two-piece steel, wide, narrow...? Triumph 12
BoyRacer Best-Sounding Muffler - Stainless Steel or Mild Steel? Austin Healey 9
D Removing the last rust from pitted steel Restoration & Tools 11
B Electrochemical cleaning of stainless steel welds Restoration & Tools 7
Joel Lester Wanted Wanted - TR6 steel wheels Triumph Classifieds 6
DocDup1 General TR TR6/TR250 Steel Wheels Triumph 3
DocDup1 For Sale TR250/TR6 Steel Wheels Triumph Classifieds 5
AngliaGT MGB-GT TT Stainless Steel Exhaust Re-Installtion Suggestions MG 2
T Trying to identify a steel plate part Austin Healey 2
bighealeysource Installing stainless steel brake hose on BN2 Austin Healey 5
L For Sale 1960 Austin Healey steel oem wheels Austin Healey Classifieds 0
B TR2/3/3A Tubes in steel wheels? Triumph 18
T TR2/3/3A Anyone running tubeless radials on TR3 steel radials? Triumph 2
J TR2/3/3A Figure of Eight Gasket Compression - Copper vs. Steel Triumph 18
G For Sale Stainless Steel TR6 Bumpers Triumph Classifieds 0
I Stainless steel exhaust. Austin Healey 5
K TR2/3/3A Pressed steel body plates?????? Triumph 7
M TR2/3/3A Fitting Modern Steel Wheels Triumph 4
D TR2/3/3A TR3 Steel Wheels Triumph 7
busybrit TR4/4A Steel dashboard color Triumph 1
JimLaney How to treat media blasted steel Spridgets 3
B ISO two[2] steel road wheels, Morgan Other British Cars 0
