body mounting
Greg_Blake
I have the body off the frame to finish up the body and paint work. When I go to reassembly the body to the frame I was planning on replacing all the body mounting rubbers with new. Do any of you delete the rubber to have a more solid connection between the body and the frame? What are the disadvantages other than noise? Since I plan on using some of my original mounting points as roll cage pick up points, I don't think I should be using the rubber pads in these areas. If that is the case, is there any reason to use them anywhere else?
Thanks,
Greg
JerryB
I'm confused........does the body contribute to the stiffness of the frame?
Is there subframes or is this a full frame.?
"""""""Since I plan on using some of my original mounting points """"""
define 'original mounting points'
""""""as roll cage pick up points""""""
are 'points' on the body or on the frame?
Got_All_4 TR6 Seal To Body Mounting Bracket Welded? Triumph 7
K TR6 Goodparts Trail arm kits mounting just to the frame( no body) and shims? Triumph 9
T TR2/3/3A Question on TR3A front body mounting Triumph 6
S TR2/3/3A Body Mounting Bolts. Triumph 14
J TR2/3/3A Body Mounting Strip Adhesive Triumph 10
T TR4/4A Body Mounting Strips Triumph 0
P TR4/4A Body mounting plate location? Triumph 2
O TR2/3/3A TR3 Body Mounting Hardware Triumph 1
A Body mounting to frame Triumph 7
K TR2/3/3A Mounting TR3 Body to frame with front apron on? Triumph 4
martx-5 TR2/3/3A TR3 Body Mounting Triumph 1
M Mounting the body on the frame Triumph 11
J Can a TF engine be installed in a TD body? MG 7
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
Editor_Reid V-12 E-Type Body Number Location Jaguar 3
5 MGA Body and Chassis Separation? MG 2
Bayless How does '67 Sprite top attach to body? Spridgets 3
Rod-H TR4/4A TR4 Body Number Plate Supplier Triumph 6
1 TR2/3/3A Best Rustproofing for inside of body. Triumph 7
K TR2/3/3A The "wide body" TR3? Triumph 6
W TR2/3/3A Interior and Body Colours Triumph 14
PatPink TR6 Hello, I am new to the site and want to post some photos of my 1973 TR 6. I have done all mods to this car except body and paint. Triumph 10
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
D Body/Paint Shop Recommendations Austin Healey 1
apbos TR5/TR250 TR250 rolling chassis and body for sale Triumph 3
T For Sale Free - Body Jig for TR3/TR3A Triumph Classifieds 6
M BJ8 Inner Body Panel Repair Austin Healey 2
T TR2/3/3A Body Tub Weight Triumph 8
D Wanted: Healey 3000 MkIII body and chassis Austin Healey Classifieds 0
T TR2/3/3A Should there be a body ground strap to battery on TR3 Triumph 7
J TR2/3/3A Need help with pivot and body bracket for hood Triumph 2
D TRIUMPH TR6 BODY SHELL Triumph Classifieds 1
B After bead blasting the body I noticed some interesting things… Spridgets 2
S Inner Body Alignment Austin Healey 0
B Body Reassembly Austin Healey 2
F TR2/3/3A front body mounts Triumph 7
jdubois GT6 After over two years stalled at the body shop, my GT6 is starting come back to life! Triumph 5
Csarneson Body panel assembly order? Austin Healey 6
J Wanted WTB Triumph TR6 Body/ Rolling Chassis Triumph Classifieds 0
Lotuswins Wanted TR4 H6 rear carb body Triumph Classifieds 4
nichola TR6 Recommendation for tail lamp to body gasket Triumph 16
X Production year based on body number ? TVR 3
TRclassic3 TR2/3/3A Body leans to right side Triumph 10
S For Sale Austin Healey Sprite and MG Midget Factory Body Parts Manuals - 1958 - 1974 Austin Healey Classifieds 0
J For Sale La Dawri 'Del Mar' fiberglass body for TR-2 thru TR-6 Other British Classifieds 1
T For Sale MGB Pull Handle Tub Body Shell for sale MG Classifieds 0
BJ8Healeys Body Parts Code Austin Healey 5
BOBBYR Body Panel measurements and angles Austin Healey 6
S TR2/3/3A Frame off vs. body on restoration Triumph 21
