BN7 - Basic Carb Settings
Dace
Member
Having fitted refurbished standard carbs to my BN7's rebuilt engine, and set timing, and confirming fuel to the carbs, I've failed to get the engine to run.
Its dawned on me that I've assumed the "new" carbs are set up!
I would like to "base-line" the carb settings to get the engine running. Any advice on the correct sequence for establishing the basic carb setting would be much appreciated.
(Twin HD6's fitted)
thanks
Dace
GregW
Platinum
One other thing to consider is the distributor being 180 degrees off. BTDT
I start with the jet being at the bridge and move it open (down) two full turns each. Enrich as needed with equal turns. The resting idle is also adjusted two fill turns to start I think, then set to about 600 rpm. There are many thing written on the subject in all the manuels.
Greg is correct and also check the wires inside the dizzy and the sequence of the insulators on the points.
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 0
H BN7 and BN2 Lengths Austin Healey 3
A BN7 Front Hub Stud Nuts Austin Healey 5
rgfrey 1959 BN7 Throttle Control Linkage Austin Healey 2
B Roof vent position on BN7 hardtop. Austin Healey 15
B Cold Start Problems BN7 Austin Healey 21
S For Sale Austin Healey 3000 and 3000 MK II Factory Parts Manual - BN7 & BT7 on CD/ROM Austin Healey Classifieds 0
G 1960 3000 BN7 Top Help Austin Healey 0
F Which Original Oil filter assembly for BN7 Austin Healey 19
lbcspinners 1962 Austin-Healey 3000 Mk II BN7 Tri-Carb 2-Seat Roadster: for sale on BaT Austin Healey 2
F BN7's left Austin Healey 9
F For Sale Disc Wheel Hub, From Bn7 Austin Healey Classifieds 5
jnew >>> Austin-Healey Parts Lists for BN4-BN6, BN7-BT7, & BJ7-BJ8 Available Online Austin Healey 17
Healey Nut BN7 Austin Healey 6
R BN7 Speedometer issues Austin Healey 1
T BN7 wiring diagram in color Austin Healey 7
F Throw away BN7 Gas tank Austin Healey 3
F For Sale BN7 gas tank, original. [I think]. Austin Healey Classifieds 0
HealeyRick Nasty BN7 Sells for $75k Austin Healey 6
busybrit Healey BN4/6 bell housing vs BN7/BT7 differences. Austin Healey 2
stretchit2 Question regarding BN7 Hardtop Austin Healey 7
rjc157 bn7 electronic choke Austin Healey 0
BN6_2197 Front Wheel Clearing of BN7 Austin Healey 35
David Townsend BN7/BT7 Limited Edition Fine Art Prints Austin Healey 6
F VIN Problem / Whats difference between BN6 and BN7, bare car. Austin Healey 21
J 1960 BN7 2 seater roll bar. Austin Healey 5
R BN7/BT7 Windscreen Installation Advice Austin Healey 5
Marvin Gruber BN7 on Craigslist, Nashville Austin Healey 0
J Wood dash for 60 BN7 Austin Healey 16
S Green/white BN7 Chequered Flag Austin Healey 7
R How to erect at BN7 hood [top]? Austin Healey 4
bighealeysource BN7 sells for crazy money Austin Healey 22
R Proper Timing Technique '60 BN7 Austin Healey 0
Healey Nut Red bn7 Austin Healey 7
D Original BN6 / BN7 Battery Switch Wiring Question Austin Healey 15
B BN7 with BT7 VIN on eBay Austin Healey 11
R BN7 Windscreen removal Austin Healey 7
L 3000 BN7 insulation Austin Healey 11
R BN7 Coil Wires Austin Healey 3
R Need picture [s] of a BN7 or BT7 Servo installation Austin Healey 3
M Steering Wheel modification for a BN7 Austin Healey 15
R How to install a BN7 hood [top] Austin Healey 3
R BN7 / BJ7 Dash Top Removal Austin Healey 11
AH67 The size of battery for 62 BN7 Austin Healey 16
AH67 Spinning starter motor BN7 Austin Healey 13
AH67 exhaust & Battery kill switch- mkii bn7 Austin Healey 13
dougie 1960 BN7 For Sale Austin Healey 6
Jim_Newman Bn7 fan Austin Healey 6
R Headlight switch replacement on BN7 or BJ7 cars Austin Healey 3
AH67 ‎62 BN7 for $69,000? Seemed low to me.. Austin Healey 21
