Bluish gray exhaust?
OregonTR4A
Member
When I high rev at idle I get a little bluish gray smoke out of the exhaust. I have only noticed a little while driving. Can anybody tell me what this indicates, if anything? I also noticed a slight oily film on the back of the car while washing it.
Thanks
PeterK
rings. type to renew the bottom end.
(edit)If there's oil on the back of the car, I doubt it's just worn valve guides. Worn guides give a puff of smoke at startup because of the oil draining past the guides into the head. Then it goes away, mostly.
But if the smoke is at higher rpms and consistant, probably worn rings. A compression test will tell.
How many miles on the engine? What oil are you using? You could also try an oil emulsifier like Lucas temporarily, until you get it fixed.
AltaKnight
If you get the blue smoke all the time its piston ring replacement time, and main/rod bearings while you are in there.
If it only smokes briefly when you first rev the engine (as in when pulling away after idling for a while) then it's likely oil leaking past the valve stems in the head.
Easy way to check is with a compression test on each cylinder, do it dry and record the readings then a small quirt of oil in each cylinder redo the test and see if the readings come up significantly, if they do then it's rings.
Either way it's work but quite do it yourself. If you need the comp test procedure just ask.
OregonTR4A
OregonTR4A
Member
It sounds like it is probably the valves as it only smokes a little after idling for a while. I will do a compression test to verify. Thanks for the replies.
Webb
YankeeTR said:
drive it and don't worry about it...it's an old car...
My sentiments exactly. When it gets so bad it pisses off the motorcyclists behind then it's time for a rebuild!
BIBBER
OK...this is the first time I have <u>ever</u> promoted this stuff and I'm going to open a major debate when I post...I don't work for these guys...and I don't get any kickbacks...I found them several years ago by surfing the net....tried them and it honestly worked in my situation...I had an old smoker 6 cylinder...like a freight train...I figured what do I have to lose but a few bucks...if it works it saves me a major rebuild, which I couldn't afford,..didn't want to do myself...and I had only planned on keeping the car for 1 year more anyway....did what they said.. drained out the old oil...I didn't flush it out but it is recommended...put on a new filter, refilled it with the FHS oil and I swear on the kids...an immediate major reduction in oil burning on the first drive...only smoked when I got down hard on it....ran it for a month...and figured what the heck...did it again...new filter...fresh FHS...it has now been smoke free for 3 years (I just made sure to put nothing but FHS in it)never spent a dime on rebuild yet just the oil...it isn't cheap runs about $12.00 a quart plus shipping but I have to be honest it is well worth the try....compared to a rebuild or just putting up with a smoke trail...
Here's where I hear there's NO SUCH THING AS A SMOKELESS MOTOR OIL...and I said it all the years growing up until the day I tried this stuff...and I still can't believe they are not known worldwide for this stuff..I even sent them a testimonial which to-date is posted on their website with many others.....they are known however for their outstanding racing formula's...it's your call...here's the website:
https://members.aol.com/FHSoil/SmokeLess.html
I don't know if it works in every case but it did in mine...Should you try it I would be excited to know your results and I'm sure as well as ...what is it now 8001 other BCF'ers...
Just an added note..it doesn't help anything regarding leaks...
BIBBER
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]Wonder how much ZDDP it has. [/QUOTE]Shawn sorry..everybody would expect me to do it...I can't resist...
I don't know...how much does a ZDD...p?
Matter of fact I don't even know what a ZDD is?
update 8/24/2007: <span style="color: #3366FF">OK..I'm back to serious now...but agree if it's minor who cares...my situation as I commented was a freight train...and it definitiely needs a rebuild but since this stuff is working I figure it can't do much more damage than a complete rebuild..so I'll put off the inevitable..</span>
MadRiver
Bronze
You know, I have to say that I agree. I just had the extreme pleasure of spending the weekend with my dad at the Pebble Beach Concours d'Elegance (he had a 1937 AC sports tourer showing there), and I noticed that a huge percentage of the outrageous automobiles on the field smoked -- they either burned oil, ran way too rich, etc. And these were serious cars. But they're *old* cars. I figure if an Aston Martin DB3S, a 1934 Duesenberg Boattail Speedster or a Talbot Lago aero coupe can burn a wee bit of oil or run a bit rich, so can my LBCs. Unless you've clearly got a serious problem, drive it, and have fun. /bcforum/images/%%GRAEMLIN_URL%%/grin.gif
swift6
Matter of fact I don't even know what a ZDD is?[/QUOTE]
hehehe, which is why I put the "wink" in there. Just trying to beat a dead horse a little more...
BIBBER
the great CARNAC was consulted and found everything one would not want to know in a Funk & Wagnell's 3rd Edition, kept in a mayonaise jar on a shelf hidden from site for three years...but now the answer is known...ZDDP:
(may your sister run into a low flying YAK!)
https://www.ttalk.info/Zddp.htm
some of us remember Johnny Carson! don't we?
KVH General Tech Permatex Aviation Form a Gasket; Permatex Ultra Gray Triumph 12
NutmegCT blue/gray exhaust smoke Other Cars 13
Keith_M Now the smoke is blue/gray Spridgets 10
DrEntropy Gray Lady Down!! Other Cars 5
Patrick67BJ8 Top/Hood/Drain Channel Gray color needed Austin Healey 2
John_Mc Gray "sludge" in brake reservoir Triumph 4
T TR2/3/3A TR3 gray hood Triumph 9
TR4nut Standard Triumph Gray Colors for Russ.. Triumph 15
tinman58 TR2/3/3A Silverstone gray TR3? Triumph 8
Shinsen774 Gray Motorhome in Virginia with MG MG 4
2wrench TR6 TR6 Water in the oil; blue/gray smoke. Triumph 5
M Gray Horwood Engineering Other British Cars 1
M Gray Horwood Engineering Carburetor Synchronizer Austin Healey 3
G gray star Triumph 7
Basil Gun metal gray EType spotted Jaguar 12
P Gray spray paint Jaguar 1
J TR4/4A Exhaust a tad too loud... Triumph 6
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
K TR2/3/3A Exhaust bracket rubber "top hat" bushings? Triumph 3
K TR2/3/3A Thick flat washers for exhaust manifold studs? Triumph 0
CARSINC Please Identify this Exhaust Header Spridgets 2
Patrick67BJ8 Traced down that elusive exhaust leak! Austin Healey 5
Walter74 AH Spares Side Exhaust Austin Healey 2
TomMull GT6 "Sports" Exhaust Triumph 2
Tim Tucker TR4/4A Phoenix Stainless Steel Sports Full Exhaust System Inc Manifold experience Triumph 3
B Thread Type and Size of BN2 Intake/Exhaust Studs Austin Healey 0
AUSMHLY Cylinder Head Input/Exhaust Circlip/Split pin Austin Healey 3
K TR2/3/3A Exhaust pipe banging inside the cruciform? Triumph 8
B TR4/4A Exhaust Wrapping Triumph 8
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
T Exhaust Pipe Hose Austin Healey 9
B Stainless Steel Exhaust System Wanted Austin Healey 5
newmexTR3 For Sale TR2-4 performance valve springs, collars, exhaust seats, cotters Triumph Classifieds 0
jfarris TR2/3/3A Exhaust Hanger Question Triumph 4
3 Exhaust Manifold/Headers BN2 Austin Healey 16
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
tahoe healey Exhaust Manifold Gaskets Austin Healey 5
K 100-6 Exhaust Front Mounting Bracket Austin Healey 2
nichola TR6 Stock exhaust sound... short video Triumph 4
S TR2/3/3A Exhaust system - It hangs too low no matter what I do Triumph 15
60TR3A TR2/3/3A Exhaust System Recommendations Sought Triumph 15
B Exhaust Pipe Size Austin Healey 26
6 Exhaust Pipe Spridgets Classified 2
K TR2/3/3A Can heat from exhaust downpipe ..... Triumph 2
AngliaGT MGB-GT TT Stainless Steel Exhaust Re-Installtion Suggestions MG 2
Ripper01 SOLD-TR6 Dual Port Exhaust Manifold Triumph Classifieds 6
K TR2/3/3A Time to replace the exhaust header wrap.... Triumph 2
D Wanted TR6 exhaust manifold w/air rail Triumph Classifieds 2
S TR2/3/3A Exhaust Systems Triumph 10
S TR2/3/3A TR3 has me stumped, it runs then dies over and over and the exhaust system was pulled Triumph 9
