blue/gray exhaust smoke
NutmegCT
My 1958 Rambler American (196 cu in flat head six) runs beautifully. Smooth idling (no smoke), strong acceleration (no smoke), no hesitation nor miss under load, under no load, and at idle. Cylinder compression is even, about 150 150 152 150 150 150.
Climb a hill at 65, no problem.
But get to the crest of the hill and start down - grey/blue smoke is lightly visible from the tailpipe when I let up the gas pedal. Give it more gas, smoke stops. Smoke isn't heavy - just "visible". Similar to:
What could cause this?
Thanks.
Tom M.
Deleted member 8987
Sucking oil past the guides. Might be rings.
The last flatmotor in my 50 Tudor did that..long drag, stop at the light, take off and two full cars disappeared in the smoke cloud. Seriously.
Still have that block, hone will work, rings were wore...out. Guides were loose.
On yours....cannot remember Ramblers...but I think the guides are separate drive-in units, not cast in.
Trick on those was to pull manifolds, head, side cover(s), then all the valves (inspect stems and faces carefully) then lay rags in the lifter gallery, drive then down almost to the lifter, hit them with a chisel and hammer to break them off, drive the rest out.
Chill the new ones, know your installed guide height, drive them in (correct orientation), faced valves, quick lap to see if they grey up all the way around the block seat.
BTDT.
NutmegCT
NutmegCT
TOC - thanks for the details.
Just to be clear, I do *not* get smoke when I take off from the light. Smoke is only after I remove my foot from the pedal. So - no smoke under load at all.
LarryK
Coasting on engine, oil bypasses guides.
pdplot
My Tr6 does the same thing decelerating down a hill and puffing oil smoke when hitting the gas pedal. Valve guides were supposedly replaced when head was done and hardened valve seats installed two years ago. Compression is down in one cylinder however. Worn or broken ring maybe?
pdplot
I remember those stories. Gus and the Model Garage. I don't understand how oil can work past the guides if they in fact were redone. I don't remember if I got the old guides back or not. I did get a few valves back that were replaced. The machine shop that did the work was upstate. Since the engine still runs great except for the oil, I'll keep putting in oil until there are other signs that a teardown is imminent. I still have more than 75 lbs. oil pressure and about 40 at idle. Runs cool too.
Deleted member 8987
You may not SEE the smoke when you take off.
Trust me...if you come down a grade or long compression slowdown, and you get out and see the tailpipe burbling blue/grey, the entire system is full of smoke.
It will not miraculously all turn to clear air once you take off....combustion chamber, exhaust valves and ports, exhaust manifold, header pipe, muffler and tailpipe.
It will start clearing out once you start moving, but it has to clear out all of those places.
My cloud of smoke was the system doing exactly that...about two vehicle's worth.
LarryK
Might take note: Had a Triumph GT6 that did the smoke thing only on coasting. Took a while then it did on take off and early morning start. Come to find out, when doing head, that no valve seals had been installed. Intakes were supposed to have seal, exhaust none. Back then seals for exhaust were not in parts book and you used a Chevy seal, now they are available at most parts vendors.
NutmegCT
NutmegCT
Thanks Larry. From the workshop manual, this 196 flat head six doesn't have valve seals. Maybe adding a heavier oil (10w40?) and/or Bardahl NoSmoke will cut down on the smoke, which now only occurs when coasting downhill while in gear. Back pressure from coasting, forcing oil up into the combustion chambers?
Tom M.
LarryK
10W/40 is what I run in my older cars. All my old Jags get 20W/50. Only varible would be for winter contant driving would be 10W/40 in winter. If you ever tear it down, Chevy umbrella seals would be looked at, but the draw back would be less oiling of the guides and more guide wear.
PAUL161
Don't know that engine, but in the past I've installed umbrellas on other engines and cured the guide leakage, if that's the problem. Also make sure the lower end can breath properly with no restrictions. PJ
NutmegCT
NutmegCT
Thanks Paul. I'm concerned about "umbrellas", as Larry points out the likelihood of increased valve guide wear.
I just tested the road draft tube, and it's clear. Removed oil filler cap, blew air into the filler, and felt a strong stream of air coming from the draft tube.
Maybe try Bardahl NoSmoke to thicken the 10w40 oil?
Edit: here's a bit more about the engine, the "Super Flying Scot".
https://wildaboutcarsonline.com/cgi...tion=viewad&categoryid=9960481656952&viewad=B
Keith_M Now the smoke is blue/gray Spridgets 10
2wrench TR6 TR6 Water in the oil; blue/gray smoke. Triumph 5
C For Sale Rover Mini Blue Star Tribute Other British Classifieds 0
Eeffoc TR4/4A Out of the blue - started to loose power Triumph 17
vpanza Wanted Salvado blue paint sample Triumph Classifieds 8
PAUL161 T-Series Puff of blue smoke on startup MG 17
S Baby Blue gets a Shout Out from BaT Spridgets 4
A For Sale 1966 3000 Healey Blue BJ8 Austin Healey Classifieds 3
KLUTZ Wedge Adding Blue Devil head gasket sealer Triumph 4
BoyRacer Rattle can Healey Blue paint Austin Healey 2
BoyRacer Blue Vinyl Dash Material Austin Healey 3
A Color Matching Austin CU 50 "Dominican Blue" British Motor Corp 3
J Opalescent Silver Blue paint code Jaguar 0
B TR4/4A Midnight blue interior Triumph 6
boxofparts TR2/3/3A TR3 Spotted Petoskey Michigan Red and Wedgewood or Powder Blue Triumph 1
BJ8Healeys For Sale BJ8 blue full tonneau cover Austin Healey Classifieds 2
R TR6 Sapphire Blue color Match? Restoration & Tools 3
B MGB 1972 MGB Project Blue First attempt and fixing no spark and other checks MG 67
Mickey Richaud TR2/3/3A From Out of the Blue! Triumph 12
A Modern paint codes for Speedwell and Iris Blue for my Bugeye Spridgets 7
M TR2/3/3A Red or Blue Loctite Triumph 1
HealeyRick Healey Blue Austin Healey 12
glemon Iris Blue Spridgets 11
M Modern Paint Code Needed for Honolulu Blue Restoration & Tools 1
M TR2/3/3A For those with blue/white/black TR3 badges Triumph 7
L Ice Blue [BU2] touch up pen Austin Healey 5
Mickey Richaud Blue Healey on the Blue Ridge Parkway Spotted 0
K Healey Blue Paint Source Austin Healey 30
wangdango BJ8 gauge blue jumper? Austin Healey 2
A Iris Blue vs Speedwell Blue Spridgets 10
Scotsman TR4/4A Triumph Royal Blue paint code and formula Triumph 3
R TR4/4A Where can I get Triumph Midnight Blue carpet? Triumph 0
S Baby Blue to the Rescue...again Spridgets 8
DerekJ Healey Blue Paint - suggestions Austin Healey 23
K 1980 Jaguar paint colour.... Quartz Blue? Jaguar 2
S A Playmate for Baby Blue? Spridgets 19
bighealeysource My Healey at a Blue Angels Air Show in Beaufort,SC Austin Healey 0
J Pacific Blue paint code needed Jaguar 6
HealeyRick Blue Bristleflex? Austin Healey 3
B Recommendation for Healey Blue and Old English White Paint Austin Healey 15
S Happy Birthday, Baby Blue! Spridgets 6
Rut Iris Blue interiors Spridgets 15
simon1966 Armacord in the trunk, Healey Blue BN1 Austin Healey 5
S Were Valve Covers Ever Painted Blue? Austin Healey 8
weewillie baby blue Spotted 1
KVH TR4/4A Baby Blue TR4 Triumph 2
RichBall OT Once in a Blue Moon Spridgets 3
longbridgehealey blue bugeye on a trailer Spotted 2
J Rivera Blue with Tan interior? Spridgets 2
M Today on the Blue Ridge Mountains Triumph 34
