mightymidget
This is a photo of a leaf spring mounting box on a 1959 Bugeye with the spring removed
The rust at the end of spring box is that need to be repaired? or can I just clean the rust up good and treat with chemicals?
can not tell if the end is open and edges are rusted or if it should be closed up.
If I need to cut that rust out and put in new piece of metal how in the world do you get to it? Need advice from someone who has been here and done the repair. can not tell if it is structually needed to put in new metal at end of box
