Sometimes this car makes me feal really stupid!
OK, I was setting up the wiring for a redundant fuel pump and doing everything on the bench, not on the car. Band new Master fuel pump for back-up and brand new negative ground solid state SU pump as the primary. I connected the Master unit to power and ground and I heard it begin to pump. I connected the SU in the same fashion and heard nothing. The SU is connected to power at the thumb screw connection and to ground through the terminal provided on the body. So why is it not pumping???
Frustrated!
Lin
1960 BT7 in restoration
1959 Bugeye
Frustrated!
Lin
1959 Bugeye
