ABS/ TRACTION CONTROL lights on
KevinB
I have a 2000 Jag S-type and this is throwing me a curve. THE SCANNER reads that it is the rear wheel speed sensor signal missing. Does anyone know of the module that is located in the ABS box that is removeable and serviceable ? Thanks for the info !!!
LarryK
Have you check the wheel sensors? Do you know which one is the missing one? Check first before getting into module. ABS modules are rebuildable: modulemasters.com > bba-reman.com > proautotronics.com
K
KevinB
It is the left rear wheel. I checked the sensor compared to the right one and seem to be the same. I also ohmed the wires from the wheel to the module and everything checks out good. I will check that site you sent me, Thanks
LarryK
Try this, it has worked on some of the newer cars. Find the traction control fuse. Turn off car, pull fuse and then turn on without starting. If light goes out turn off and replace fuse and restart to running. If light stays out a reset successful if not continue your search.
D 1992 jaguar xjs abs Jaguar 1
eschneider Spitfire Spitfire ABS transmission tunnel cover - worth it? Triumph 10
O Jaguar ABS Brake Bleeding Jaguar 1
6 1994 Mercedes ABS light Other Cars 0
P ABS Warning System Jaguar 3
G ok i'm bored. ABS time Triumph 20
L XJ40 ABS Warning light Jaguar 0
aeronca65t 944 + Traction Avant Spotted 4
K TR2/3/3A Putting traction bars on a TR3? Triumph 3
K TR2/3/3A Traction Bars on TR3 Triumph 2
prb51 Leaf spring traction bars Racing 6
prb51 Rear Traction Bars for our Leaf springs Triumph 0
TRMark Traction Bars Triumph 0
Sherlock Citroen Traction-Avant - 70th birthday Other Cars 10
K TR2/3/3A Who sells steering wheel control head "Allen head'' grub screws? Triumph 5
KVH General Tech Heater control valve/cable Triumph 1
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
D BT7 Air Vent Control Cable Routing Austin Healey 0
K TR2/3/3A Inside the horn and turn signal control head. Triumph 3
K TR2/3/3A Question about installing the steering wheel control head? Triumph 1
rgfrey 1959 BN7 Throttle Control Linkage Austin Healey 2
F Wanted TR3A control head parts (trafficator) Triumph Classifieds 4
B RHD BJ8 Throttle Control Rods Austin Healey 9
H BJ8 Heater Valve/Control Tap Austin Healey 3
71TR6 TR2/3/3A Control Head horn contact Triumph 7
Lin Another Trafficator/Control Head Question Austin Healey 10
Kurtis TR4/4A Voltage Control Module Triumph 15
C TR2/3/3A Horn Control replacement Triumph 3
M TR2/3/3A Upper Fulcrum Orientation On TR3A with Late TR4 Upper Control Arms Triumph 6
B TR2/3/3A Control Head/Stator tube orientation Triumph 8
K TR2/3/3A Turn signal and control head memory refresh..... Triumph 9
K TR2/3/3A Control hedd fit? Triumph 1
K TR2/3/3A Turn Signal Control Head Alignment Again Triumph 1
S TR2/3/3A Horn not working unless I rotate the control head Triumph 6
K TR2/3/3A The 3 Steering Wheel "Grub Screws" and the Control Head. Triumph 2
TRMark T-Series Directional Control Relay DB10 MG 4
T TR2/3/3A Is it possible to buy stronger springs for turn signal lever in control head? Triumph 14
Lutz Kramer Heater Control Valve function Austin Healey 2
T TR2/3/3A Questions on TR3A steering control head refresh Triumph 34
S Heater and fan control replacement - any advice? Austin Healey 9
S Wanted Source for 100 6 right hand remote control door regulator Austin Healey Classifieds 1
G TR2/3/3A Fitting the Control Head - Telescoping [Adjustable] Wheel Triumph 20
T Hurst Line-Lok/Roll Control/Launch Control - anyone use? Spridgets 5
edkap2002 TR6 Heater Control Valve Triumph 9
T TR4/4A Heater control valve - cant completely turn off Triumph 3
KVH TR4/4A Lower Control Arm Front Pivot Bolt Triumph 9
KVH General TR Pressing in the Lower Control Arm Bushing Triumph 6
P TR2/3/3A TR3A Steering Control Head Harness Triumph 7
R TR2/3/3A New Control head wiring - Moss purchase Triumph 1
