G
My steering column cowl has three screw holes on each side.
Front two are out easy, also the right side. Unfortunately, the left side screw hole near the dash is too close to the bottom ridge of the dashboard to insert a screw driver. Is there a trick to remove the last one? I could use a hammer, but alas, putting things back again may be a problem. I am trying to access the horn switch on the steering column.
