Capillary Tube repair
Marvinator
Is there a way to reattach the cable to the capillary tube. This is the sending unit out of a 1098 spridget. Screws into the head for temperature.
RickF
Yes, the gauge can be repaired. However, the tube and sensor are filled with ether and your's is gone. The solution is to buy a cheap water temp gauge at one of the big box auto parts store and use the new sensor and ether in a repair of your gauge. Do a search on Google for "1933 Plymouth temperature gauge repair" and you will find a website with complete instructions for doing this repair. 😁
Rick
Platinum
It's "fiddly" but do-able! And remember: ether is flammable... :eek:
M
Marvinator
Rick
Thanks
D Capillary Oil Tube Fastener Austin Healey 5
D TR2/3/3A tr3 temp guage capillary tube thread size Triumph 3
R Capillary tube temp gauge Austin Healey 7
K TR2/3/3A Temp gauge capillary tube routing? Triumph 11
woolfman General MG Replacing capillary tube MG 10
T TR2/3/3A Capillary Tube Clips Triumph 4
B Temp gauge capillary tube Austin Healey 3
S Temp gauge capillary tube Austin Healey 8
mountainman TR 3 Temp Guage Capillary Tube Triumph 6
germanmichel Capillary tube of oil/temp.-gauge as single part ? Austin Healey 8
martx-5 TR2/3/3A TR3 Capillary Tube Clamps Triumph 16
R Temperature capillary tube removal Austin Healey 10
M BN4 Capillary tube attaching Austin Healey 2
CharlieCarpenter What tool to use to disconnect capillary tube Austin Healey 6
T TR2/3/3A How do I remove temp gauge capillary end from thermostat housing on TR3A? Triumph 8
Tinkerman TR2/3/3A Attaching the temp capillary to the fuel line. 3A Triumph 13
beaulieu fixing a cut in half Temperature capillary gauge Restoration & Tools 13
Atrus 1/8” Capillary Tubing [Dizzy Advance] Spridgets 8
C Capillary pipe clip Austin Healey 2
tinman58 TR2/3/3A Vent tube Triumph 3
J MGB Jet Tube to Float Chamber Fuel Leak MG 7
K TR2/3/3A The Amco chrome tube type grille ....... Triumph 9
P MGB Tube axle wear MG 3
AUSMHLY BJ8 Overdrive Accumulator Spring Tube Austin Healey 1
G Stator Tube Nut and Olive Austin Healey 9
Cutrog1 BJ8 Fuel Tube Installation Austin Healey 10
P Classic Tube Pre-Bent Brake Lines Austin Healey 5
71TR6 TR2/3/3A TR3A Breather Tube Attachment Triumph 6
C TR2/3/3A stator tube Triumph 6
B TR2/3/3A Control Head/Stator tube orientation Triumph 8
M TR2/3/3A Removing Wires From Stator Tube Triumph 7
K TR2/3/3A Making your own steering wheel stator tube? Triumph 16
aero3113 For Sale Big Healey Tube Shock Conversion Austin Healey Classifieds 2
T TR2/3/3A Can someone confirm size and thread count on fuel line tube nuts [brass fittings]? Triumph 16
Jim_Gruber Pages from Porter Spridget Restoration Manual on Seat Recovering, You Tube Videos Spridgets 4
D TR2/3/3A stator tube will not go down Triumph 0
AUSMHLY Tube vs Tubeless discussion :] Austin Healey 28
F TR2/3/3A Tie member[front apron support tube] Triumph 11
S Wanted stator tube Austin Healey Classifieds 0
S stator tube nut Austin Healey 7
D Best little tube bender Restoration & Tools 8
K TR2/3/3A The rear axle "tube" seal replacement. Triumph 6
D You Tube made me do it. I bought a Milwaukee dry cut saw. Restoration & Tools 6
K For Sale Curved tube intake manifold...2" Triumph Classifieds 2
M Questions about stator tube and trafficator fixation Austin Healey 31
X BE jacking tube access holes and top bows. Spridgets 1
Sarastro General TR How is the axle tube attached to the diff housing? Triumph 16
D BT7 stator tube Austin Healey 39
