TR4/4A hsu6 float chamber tr4a
grant tr4a
Member
Hi, I want to open upthe float chamber. I just want to clean out whatever has accumulated. The carbs run fine, but the car sat for most of 5 years before I got it and I have had it for 6 years. What do I need to know before I pull the float tops off. I have new gaskets on the way. Grant
TR3driver
Great Pumpkin - R.I.P
Sounds like you've got it covered. The gaskets can sometimes be reused, but may tear when you pull the lid off. In a pinch, you can run without them, though.
To clean the bowls out thoroughly, though, you'll probably want to take them off. Crud can also accumulate in the line to the jet. As I recall, you can undo the choke linkage to the jet and just pull the jet out of the carb, leaving it attached to the bowl by the little hose.
charleyf
Once inside of the float bowl you are likely to find that most all of the dirt is settled in the two pockets that are on each side of the well that the hose is connected to. It was designed to trap the dirt in those spaces instead of going through the hose into the jet. You should be able to clean those spaces out without removing the bowl from the carb body. You will need some tool to suck out whatever is in the bottom. It is pretty small.
Charley
dklawson
I am going to go one step further and suggest something the manuals warn against.
If you take a pipe cleaner and make SURE there are no sharp burrs on the cut end of its wires, you can spray car cleaner down into the jet (with the suction chamber, and piston/needle removed) to gently clean fuel gum/varnish out of the jet. The flexible tube to the float bowl can often be cleaned by spraying carb cleaner through the jet back into the bowl where you blot it up with paper towels. You may find you need to spray into the flexible tube, then let things soak for a while and try again. The important part is to make sure that if you use the pipe cleaner it has no sharp ends that would cut/damage the inside of the jet. If you clean the jet and flexible tube with the carb on the car you can often get the passages open without disassembly or disturbing the mixture settings. That will help you with the initial restart of the engine after which you may find adjusting the mixture is necessary.
titanic
Another thought-if you remove the jet tube from the float chamber, the seal will often leak on re-assembly. I have found that a 008 o ring make a good substitute and is locally available. Faster and cheaper than having to order one.
Berry
dklawson
While a regular o-ring will seal for a while, its round cross-section will not seal as well as the rectangular section of the factory seal. If you use an o-ring as a temporary fix, either buy the right part or make your own.
The seal can be made from 3/16" low pressure fuel hose. Buy a minimal amount (probably a foot). Use a razor blade to slice off a 1/8" thick donut with parallel sides. Carefully split the outer jacket of the donut and peel it off, down to the fiber braid, then pick off the threads of the braid. The inner donut you are left with will have the same dimensions as the factory seal.
titanic
The o ring has been in place for at least 2 years. It seems to compress enough to provide a seal. I will keep the fuel line in mind as it is probably closer to the hardness of the original seal. I might be wrong, but I don't think the seals are available from the "big 3". Joe Curto or Burlen might be the only source.
Berry
dklawson
The Burlen/SU float bowl to jet tube seal is not readily available. The SU part number is AUD2194 and it is supposed to be common to all HS carbs.
AUD2194 is available from Spitbits, Mini Mania and Seven Enterprises. I don't know if other British car vendors in the U.S. have the part.
J MGB Jet Tube to Float Chamber Fuel Leak MG 7
Briancole702 MGB-GT 71 Mgb gt no gas in float bowls MG 1
jehuie Will this lid work with my HS2 carburetor float chamber? British Motor Corp 4
jehuie Wanted HS2 carburetor float chamber cover wanted Spridgets Classified 0
dripdripdrip TR2/3/3A Deformed float bowl Triumph 7
AUSMHLY Synchromesh Hub End Float Austin Healey 1
AUSMHLY Laygear End Float BN1-BJ8 Austin Healey 2
F TR4/4A New to forum - Rebuilt Fuel Pump and weeping float bowl Triumph 9
S Carb Float Levers Austin Healey 9
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
GeorgeC HS 2 float adjustment Spridgets 5
K TR2/3/3A Front wheel bearing adjust and end float?? Triumph 10
J TR6 End Float Triumph 5
T TR6 My '74 TR6 Zenith Stromberg Carbs Float Bowls Leaking Gas Triumph 11
eschneider Spitfire Float height - '64 spitfire w/ dual HS2 Triumph 1
T TR6 Carb. Float Chamber Fix Triumph 5
2 General TR SU float settings Triumph 3
jfarris TR2/3/3A Metal washers for SU H6 float bowls Triumph 1
S TR2/3/3A understanding the float and needle set up better Triumph 6
sundown TR6 Fuel float Triumph 3
K TR2/3/3A Gas Gauge sending unit "float" orientation? Triumph 5
Healey Nut Carb float Austin Healey 16
dklawson GT6 Float Height, 150CD [Early CD, Not Later CDSE or CD2SE] Triumph 7
Merlin63Tr4 TR4/4A Cracked Zenith-Stromberg float assemblies Triumph 13
R TR2/3/3A Establishing distributor shaft end float Triumph 4
S BJ8 Float Level Austin Healey 37
H Is there any difference in using the 1275 Float Bowl that have a different casting? Spridgets 6
M TR2/3/3A SU H Type Carberator Float Lever Adjustment Triumph 10
Lin HD6 1-1/2" SU Front [L/H] Float Chamber Austin Healey 1
Talon TR2/3/3A Float lever issue on SU type H carbs Triumph 1
R Front wheel bearing - end float Austin Healey 40
Lin Post in float bowl came loose Austin Healey 6
steveg Carb float setting tool Austin Healey 11
KVH General Tech Distributor Gear End Float Triumph 6
BN6_2197 Advice on removing the float from the chamber Austin Healey 6
F Wanted TR3 Front Float Bowl Lid SU H6 Triumph Classifieds 6
Tinkerman TR2/3/3A TR3A SU H6 Rebuild Float chamber Cap Nut Triumph 3
GBRandy MGB HIF float chamber seals MG 6
D BJ 8 Float Bowl securing bolt loose Austin Healey 6
J BJ8 Float bowl vent pipes Austin Healey 11
KVH TR4/4A Carburetor float bowls Triumph 8
Zimmycobra TR4/4A Who's right - float height on ZS 175CD? Triumph 5
J TR4/4A Transmission counter shaft end float. Triumph 3
busybrit Healey 3000 distributor drive gear spacer washer, end float! Austin Healey 2
Martinld123 Push button on top of new H6 carbs float bowl from Moss Austin Healey 3
T TR2/3/3A SU H6 float level Triumph 4
H TR2/3/3A SU Carb Float Question Triumph 18
C TR6 Carb float chambers Triumph 7
S Float valves for HD8 - Grose Type Austin Healey 20
R TR4/4A Fuel pouring out of float bowl Triumph 3
