General TR SU float settings
2liter4cyl
Bronze
In going thru "Triumph Sports Owners Association" handbook, I found a fuel level check in carbs-- with dash pots off-- hold jets in rich position--fuel should not flow over tops of jets. If it does, adjust float levels to 1/2".
This is The first time I ever heard of not being 7/16". It is true that gravity makes the level in the float chamber equal the level at the jet. If it is not nearly up to the bridge, adjust it the other way, starting at 7/16".
[The most recent modification was for 50001L . How old is this handbook?]
LeT
bobhustead
The visualization of gasoline level in the jets is not the same thing as setting the levels of the float forks with the tops off the bowls and the tops inverted for insertion of a measuring rod.
Bob
CJD
Yes, the fuel level seen at the jet correlates to the float level. It should be below the top of the jet, or it will run down the manifold and flood the engine between runs. If it is too low to be seen, then it will result in lean hesitation. It is merely a double check for the correct float setting.
J MGB Jet Tube to Float Chamber Fuel Leak MG 7
Briancole702 MGB-GT 71 Mgb gt no gas in float bowls MG 1
jehuie Will this lid work with my HS2 carburetor float chamber? British Motor Corp 4
jehuie Wanted HS2 carburetor float chamber cover wanted Spridgets Classified 0
dripdripdrip TR2/3/3A Deformed float bowl Triumph 7
AUSMHLY Synchromesh Hub End Float Austin Healey 1
AUSMHLY Laygear End Float BN1-BJ8 Austin Healey 2
F TR4/4A New to forum - Rebuilt Fuel Pump and weeping float bowl Triumph 9
S Carb Float Levers Austin Healey 9
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
GeorgeC HS 2 float adjustment Spridgets 5
K TR2/3/3A Front wheel bearing adjust and end float?? Triumph 10
J TR6 End Float Triumph 5
T TR6 My '74 TR6 Zenith Stromberg Carbs Float Bowls Leaking Gas Triumph 11
eschneider Spitfire Float height - '64 spitfire w/ dual HS2 Triumph 1
T TR6 Carb. Float Chamber Fix Triumph 5
jfarris TR2/3/3A Metal washers for SU H6 float bowls Triumph 1
S TR2/3/3A understanding the float and needle set up better Triumph 6
sundown TR6 Fuel float Triumph 3
K TR2/3/3A Gas Gauge sending unit "float" orientation? Triumph 5
Healey Nut Carb float Austin Healey 16
dklawson GT6 Float Height, 150CD [Early CD, Not Later CDSE or CD2SE] Triumph 7
Merlin63Tr4 TR4/4A Cracked Zenith-Stromberg float assemblies Triumph 13
R TR2/3/3A Establishing distributor shaft end float Triumph 4
S BJ8 Float Level Austin Healey 37
H Is there any difference in using the 1275 Float Bowl that have a different casting? Spridgets 6
M TR2/3/3A SU H Type Carberator Float Lever Adjustment Triumph 10
Lin HD6 1-1/2" SU Front [L/H] Float Chamber Austin Healey 1
Talon TR2/3/3A Float lever issue on SU type H carbs Triumph 1
R Front wheel bearing - end float Austin Healey 40
Lin Post in float bowl came loose Austin Healey 6
steveg Carb float setting tool Austin Healey 11
KVH General Tech Distributor Gear End Float Triumph 6
BN6_2197 Advice on removing the float from the chamber Austin Healey 6
F Wanted TR3 Front Float Bowl Lid SU H6 Triumph Classifieds 6
Tinkerman TR2/3/3A TR3A SU H6 Rebuild Float chamber Cap Nut Triumph 3
GBRandy MGB HIF float chamber seals MG 6
D BJ 8 Float Bowl securing bolt loose Austin Healey 6
J BJ8 Float bowl vent pipes Austin Healey 11
KVH TR4/4A Carburetor float bowls Triumph 8
Zimmycobra TR4/4A Who's right - float height on ZS 175CD? Triumph 5
J TR4/4A Transmission counter shaft end float. Triumph 3
busybrit Healey 3000 distributor drive gear spacer washer, end float! Austin Healey 2
Martinld123 Push button on top of new H6 carbs float bowl from Moss Austin Healey 3
T TR2/3/3A SU H6 float level Triumph 4
H TR2/3/3A SU Carb Float Question Triumph 18
C TR6 Carb float chambers Triumph 7
S Float valves for HD8 - Grose Type Austin Healey 20
R TR4/4A Fuel pouring out of float bowl Triumph 3
R TR4/4A Fuel pouring out of float bowl Triumph 10
