SSsnake's Getting His 'Eyes'
tony barnhill
Great Pumpkin - R.I.P
A little more shaping on the driver side fender to make the headlight fit perfectly & then they start building the brackets for inside the fenders that hold the lights. Next is forming the chin spoiler & moulding the valance to the fenders & installing park lights.
& they started fabricating the rear spoiler today - with integrated 3rd brake light!! But I don't want to let on too much about it yet.
vping
Bronze
Needs fangs. Do overriders play a role in this design? Looking really good Tony but I think your tow in is a bit off. :laugh:
tony barnhill
tony barnhill
hehehehe...for the rest of the front end look, you'll just have to wait....& there's just enough front suspension under it to allow us to roll it around if necessary...the custom front suspension/steering is in my garage:
Scott_Hower
Lights look great. Pray you never need to replace a ballast or an ignitor on an HID headlight.
But you know, I'm not feeling the love for the teardrop hood scoop. Something about the lines with the MGC hump in the front. Maybe I need I different angle.
mccalebr
Scott_Hower said:
...I'm not feeling the love for the teardrop hood scoop. Something about the lines with the MGC hump in the front...
I'm with Scott on this one, Tony...
There are two looks that appeal to me, at least. One is the fluid, can't tell where one part starts and the other ends, thought out at a design table rather than a sheet metal shop, no single part/area that draws attention to itself. The other is the in-your-face, customized, sharp delineation between the original (stock) design and the modified version for an obvious reason.
The hood on the car (IMO) misses, falling into the 'kludged' category. Maybe it's the combination of two dissimilar elements, the rectangular raised stock hood bump to which has been added (obviously) a teardrop reversed scoop.
The fix...I'm not sure. Perhaps extending the scoop all the way down to the front of the hood, mainitaining a constant width, and a radius that matches the "C" hood bump at the sides and front. {Think about how the GM stylists did it with so many products, Corvettes, Camaros, etc.) Yes, visibility would be reduced...a small price for a better look. It would be quite easy to mock it up using either cardboard templates and/or foam shaped to approximate the profile. Some cardboard and foam, a hot glue gun, a camera, and an hour or two is all it would take. I think it would be worth the time to do it now, rather than later.
Tony...no offense...I love the car, otherwise I wouldn't have posted. Just want you to hear the comments now, in this forum, while the car is under construction, rather than down the road at a cruise/show.
All that said...it's your car...and your tastes...you are most welcome to tell me and anyone else to butt out.
Ray
Smesne
What about just cutting the teardrop off and letting a nice chrome air intake stick up through the hood? I've seen some gorgeous cars done that way.
That would allow you to leave the "C" bump in place without the distraction of another scoop but still gives you a nice "in-your-face" look that says you mean business.
My $.02 (worth about half that due to inflation).
jlaird
Boy talk about business, that engine has got 300 HP. I can't wait.
tony barnhill
tony barnhill
Good comments all...I've a vision of the hood after paint & striping that I hope ties the 2 elements together....& I need the extra height to clear the quad-44 SU's that are on my Boxer cross-ram intake!
tony barnhill
tony barnhill
Here ya go, Tim...
That's a Glenn Towry-built engine & 5-speed transmission!!
I just got back home from visiting my ill elderly aunt in Mississippi - stopped by the bodyshop to take some additional photos....will post them later today....from the side, all the lines & angles are equal & fall together.
When we paint the car, there'll be some accent work that'll blend all the different elements together....we've got a graphic designer working on the stripe ideas.
Oh, when I was at the bodyshop, SSsnake was also getting his 'tail'!!
jlaird
Where do you procure the SSsnake chrome flashing for the rear?
tony barnhill
tony barnhill
Here's a side view showing how all the lines match - even the windshield...& the front chin spoiler isn't built yet nor is the Sebring valance faired into the fenders...heck, the fenders aren't even bolted on solidly yet - we do that Monday!
tony barnhill
tony barnhill
.....&: SSsnake's Getting His 'Tail'
It's just sitting there right now...they've got it cut to fit & now have to build the 'feet' & then shape them to fit the trunk lid once we figure the exact placement front to rear (think it'll be just after the peak of where the taillights meet the quarter panel)
jlaird
Re: .....&: SSsnake's Getting His 'Tail'
Oh boy, how cool is this?
This is definitely a one-of-a-kind, something you don't see everyday automobile! :laugh: I can't wait to see it finished, I am sure you can't either!!!
tony barnhill
tony barnhill
When its finished, it'll be my everyday driver...I want all your comments - good or bad - & will consider them.
I'm gonna talk with my bodyman tomorrow about the hood lines & maybe try some of your ideas.
& definitely tell me what you think about the spoiler (tail).....it initially was on a 1991 Mazda MX6...we cut it down approximately 5"-6" on each side of the 3rd brake light...now, we're rebuilding the 3rd brake light base & the 2 feet to fit the contour & height requirements of the MGB trunk lid....
Someday, as we get closer, I'll tell you about our thoughts for striping, colors, etc....suffice it to say, they carry out the snake concept!
{EDIT: I don't think the hardtop will ever come off - to me, it just makes the car look sinister!}
billspohn
I don't mind most of the mods on the body. I assume that the dashpots are what sticks up to high to clear the stock bonnet, so it was just a choice between a single wider bulge down the centre or two, one for each side, sort of like a double sided MGC. Your choice was probably as good as any.
If it were my project I'd lose that Rice Rocket rear deck spoiler though - shades of the local honda Civics. Unless you plan to install twin exhaust pipes with 5" diameter of course....:smile: No offence, just my opinion.
tony barnhill
tony barnhill
Yep!
Some comparisons with & without "tail":
Photo 1 versus Photo 2:
Photo 3 versus Photo 4:
Oh, Bill, those 2 holes through the rear valance are where the dual exhaust system tips protrude - no, not 5"-ers though...hehehe
Scott_Hower
Ok, this angle works for me. :smile:
Scott_Hower
Another opinion ... sorry, cant help myself, tell me to go away/shut up and I will... side gills are too large/low. Maybe an M3 gill?
tony barnhill SSsnake's Hood Operates MG 2
tony barnhill SSsnake - It's Been Awhile MG 99
tony barnhill SSsnake Up-date - New Photos MG 6
tony barnhill SSsnake's Outside... MG 11
tony barnhill SSsnake Design Up-date MG 22
tony barnhill SSsnake Up-date... MG 2
tony barnhill SSsnake's Bodyshop Stablemates Other Cars 6
jlaird SSsnake MG 21
tony barnhill MGB MGB Thy Name is SSsnake... MG 43
K TR2/3/3A Getting a cylinder head skimmed for flatness.... Triumph 2
S TR2/3/3A getting the circlip off 3rd gear Triumph 9
Celtic 77 MGB Getting closer! MG 5
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
J TR4/4A Getting electrical shock from horn button when using the horn. Triumph 9
D TR2/3/3A Getting difficult to start. Triumph 6
S TR2/3/3A problems getting the engine to run correct Triumph 21
J MGB 73 getting loud squeal with acceleration MG 11
steveg Toyota W58 Trans Hard Getting Into Gear Austin Healey 8
M Getting behind the dash on BJ8 Austin Healey 4
John Turney Getting Speedometer out of the Case Austin Healey 6
tr6nitjulius General TR Part 4 What We Missin' we getting closer Triumph 0
HealeyPassion Getting a bit more space for triple Webers... or EFI Austin Healey 3
Rob Glasgow Getting Ready for Winter Austin Healey 24
BoyRacer Need Tips on getting wiring harness through firewall Austin Healey 4
J TR2/3/3A Finally getting started Triumph 20
glemon GT6 GT6 Getting Some Recognition Triumph 8
K TR2/3/3A Dismantling Speedometer...getting the odometer pin past the case??? Triumph 2
D Getting closer... Spridgets 2
RAC68 3D Printing Getting Closer Austin Healey 16
bighealeysource Getting rid of pesky rubbing/polishing compound overspray Austin Healey 5
Jagguy MGB Ignition timing issues....I'm getting confused! MG 16
steveg Really Getting Into one's Healey Austin Healey 17
M TR5/TR250 problem getting engine running Triumph 15
simon1966 Seats upholstered and the shrouds getting cracks fixed Austin Healey 9
Jim_Gruber Brake Light - Getting them working Spridgets 8
Darrell_Walker General TR TR3A on Comedians in Cars Getting Coffee Triumph 7
S TR2/3/3A getting a new multi meter Triumph 9
gbtr6 TR6 Getting frustrated getting my TR to run properly Triumph 17
RickB MGB Rain water getting inside behind dash MG 17
drambuie Getting more horse power from a Healey 100 Austin Healey 63
J TR2/3/3A Joe the TR3 Guy getting started with suspension Triumph 4
Jim_Gruber 1/4 Elliptics- Getting the Bast__rd Apart Spridgets 22
steveg HD8s - getting below 1000 rpm idle Austin Healey 4
steveg Unable to edit posts, getting a wierd message FORUM Navigation Questions 2
RickPA Getting back in the game Austin Healey 5
D Getting hot in the car [AH3000mk3] Austin Healey 6
Got_All_4 General Tech Getting the nut off for J Type drive shaft flange Triumph 3
T Spitfire Randall - anyone you would recommend for getting a driveshaft shorted in SoCal Triumph 4
Jim_Gruber Help Needed, getting those 1/4 Eliptics out of the spring mounting box Spridgets 24
