SSsnake's Getting His 'Eyes'
mgb4tim said:
What reverse lights are you using in that modified rear valance?
Knowing Tony and his engine... I'm guessing thats for dual exhaust.
edit: oops, just realized you probably knew that from the flush rear upper panel.
Re: .....&: SSsnake's Getting His 'Tail'
Tony,
I've always been a fan of the molded in spoilers...in truth it was more of a turned up lip...think, late '60s/early '70s Vettes, 240Z w/ground effects pkg., or GT40...something like this:
https://bp2.blogger.com/_FoXyvaPSnVk/SByMsDeEO-I/AAAAAAAArFg/hf_UlOCBQdQ/s1600-h/SH40_22.jpg
Of course, that would be quite a bit of body work. The spoiler would probably be flush with the top of the rear fenders with a short section on each, then a corresponding upswept lip molded into the trunk lid. My guess is that there are fiberglass profiles available.
Ray
Scott_Hower said:
Another opinion ... sorry, cant help myself, tell me to go away/shut up and I will... side gills are too large/low. Maybe an M3 gill?
They're not as large as the black area makes them look....we made a template & sprayed black paint all around it to look at the positioning.....& I agree they have to be a little higher.....but, they have to line up no higher than the matching holes we've already cut through the inner fenders....they're working vents pulling hot air out of the engine compartment.
Yep, those holes are for the dual exhaust....we're modifying the lower OE MGB taillight lens to incorporate a reverse light....you know that flat reflector section in the lens? We've cut it out & have moulded a reverse lens from a BMW into that square & are putting the reverse lamp in the OE taillight....gonna be neat.
I threw away a perfectly good trunk lid after trying to make that profile...thing ended up weighing more than I could lift....no real way to do it with the vertical taillights that I could figure out.
I've tried to think everything through on this project & am constantly making changes based on what things look like in the shop. I could write a book on this project.
Tony:
This is pretty wild...
I think (and hope!) everyone will be pretty relaxed about my MGC GT project after seeing this car of yours!
Did you ever consider the Porsche 911 headlights like Rover used on the RV8?
Side vents look OK for position. Suppose you can't go any higher than the original detail (chrome strip) line anyway. Just seems they should be angled to match the wheel well angle at that elevation, doesn't it?
Have you considered the rear spoiler offered by Victoria British? It is intended for the roadster, but is styled after the original Special Tunings rear spoiler developed for the rubber bumper MGB GT. I think this GT spoiler helps the car look longer and a bit more "rakish" and ballanced. Besides, it's supposed to be good for about 50 lbs of reduced aerodynamic lift at speed!
I am working on adapting one of these to my GT hatch and also looking for a suitable LED third brake light to incorporate into it.
C Ya,
Mark
Ps.: Sorry if this is more than $0.02 (after inflation, thanks George Duh!) worth of opinion!
Mark - thanks...if I could talk about your various ponts:
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]I think (and hope!) everyone will be pretty relaxed about my MGC GT project after seeing this car of yours![/QUOTE]
Don't bet on it! Mine's a regular old '79 MGB of which I have 2 - yours is a limited availability car....I think you'll get beat up by some for hacking one of them up.
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]Did you ever consider the Porsche 911 headlights like Rover used on the RV8?[/QUOTE]
No, this was really an exercise of 'can it be done properly' - installing new Mini headlights in an MGB fender, that is...probably would've been easier doing the 911 units.
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]Side vents look OK for position. Suppose you can't go any higher than the original detail (chrome strip) line anyway.[/QUOTE]
My car no longer has that detail - the side of the car has been cut & smoothed so I can go higher.
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]Just seems they should be angled to match the wheel well angle at that elevation, doesn't it?[/QUOTE]
One of the reasons they've not been cut yet - I'm still looking at their placement.
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]Have you considered the rear spoiler offered by Victoria British? It is intended for the roadster, but is styled after the original Special Tunings rear spoiler developed for the rubber bumper MGB GT. I think this GT spoiler helps the car look longer and a bit more "rakish" and ballanced. Besides, it's supposed to be good for about 50 lbs of reduced aerodynamic lift at speed![/QUOTE]
I did briefly - but everybody uses it. Plus, I think VB's dropped it from their catalog; I know Moss did a few years ago.
Whew!! & I'm already about 4 years into this project!!
mccalebr said:
Tony,
Ray
Like this?
MGB Berlinette
mgb4tim said:
mccalebr said:
Tony,
Ray
Like this?
MGB Berlinette
Yah, way more work than I wanted to tackle - plus, I don't like the rear end of that coupe.
Cool, they're functional! Understand the space limitations.
But I think they're backward... shouldn't the leading edge of the vent parallel the trailing edge of the wheel arch?
Know what? After looking at the photos, I've gotta go to the bodyshop tomorrow to see....hmmmmm
They're pulling air out of the fender, not pushing it in so they should look like on this Cobra:
& here's a close-up of the passenger fender (the wheelwell is to the right):
Scott_Hower said:
Whoa Nellie! Does that mean I get an extra discount on my next order :thumbsup:
If they're backwards, Scott - you win a "theAutoist" cap! hehehe
To quote Paris Hilton - how often does THAT happen? - Cobra's are HAWT! LOL
Tony, I think that rear spoiler can work, if the leading edge of the end caps match the angle profile of the rear edge of the hood scoop and the rear edges of the end caps match the angle profile of the rear fenders/tail lamps. Further, if the end caps were attached to the quarter panels and the center section of the spoiler lifted with the trunk lid - as in the 70's GSX - that might be really sharp. A little hard to visualize, wish I could photo shop your pics!
Cool. Does it come in pink? Wife needs one :smile:
I'm trying to visualize what you mean by "end caps" - think you mean the extreme ends of the spoiler itself....the entire spoiler will lift with the trunk - there's just not enough 'meat' on the top of the rear quarters to put anything of size on them.....the ends of the spoiler (where they turn down) will go into the valley of the quarter panel & match its line along with the line of the little 'fins' that end in the tail lights.....there will be 2 spoiler 'feet' out near the edges of the trunk lid & 1 'foot' under the 3rd light....those will be completely underneath the spoiler itself but will have some angle to them.
Is it possible to mount the spoiler so it's removable? In case you change your mind?
I've always found non-functional rear spoilers to be ricer-ish.
Yup. And despite all the aerodynamic data people spout in favour of them, they do approximately bugger all at normal road speed, hence the old response: "Spoiler? What does it spoil? Answer - "The looks of the car"
You CAN certainly redesign the back of the MGB so as to have a nearly level rear deck spoiler like the Coune coupe, but as Tony indicated, it is a LOT of work and it would still (IMHO) look like an MGB being buggered by an Alfa Graduate.
There has obviously been a lot of constructive thought go into the project from the driveline end, it would be a shame to cheapen the result with geegaws and styling malapropisms. Anyone with a Visa card and the address for JC Whitney can do THAT.
PS - I had a TR-6 chin spoiler all modified to attach under the nose of the Jamaican (would have made it look like a Datsun 240Z, though) but relented when I gave it some thought. Even though it could have been much better integrated in the design than a rear spoiler on an MGB, it did bugger all and the only thing it would have spoiled in the end was the clean looks of the car. So I am not just making an off the cuff judgement here, I have personally considered this issue and come to a decision based on that.
