mgb4tim said:What reverse lights are you using in that modified rear valance?
They're not as large as the black area makes them look....we made a template & sprayed black paint all around it to look at the positioning.....& I agree they have to be a little higher.....but, they have to line up no higher than the matching holes we've already cut through the inner fenders....they're working vents pulling hot air out of the engine compartment.Scott_Hower said:Another opinion ... sorry, cant help myself, tell me to go away/shut up and I will... side gills are too large/low. Maybe an M3 gill?
Yep, those holes are for the dual exhaust....we're modifying the lower OE MGB taillight lens to incorporate a reverse light....you know that flat reflector section in the lens? We've cut it out & have moulded a reverse lens from a BMW into that square & are putting the reverse lamp in the OE taillight....gonna be neat.Scott_Hower said:mgb4tim said:What reverse lights are you using in that modified rear valance?
Knowing Tony and his engine... I'm guessing thats for dual exhaust.
I threw away a perfectly good trunk lid after trying to make that profile...thing ended up weighing more than I could lift....no real way to do it with the vertical taillights that I could figure out.mccalebr said:I've always been a fan of the molded in spoilers...in truth it was more of a turned up lip...think, late '60s/early '70s Vettes, 240Z w/ground effects pkg., or GT40...something like this:
https://bp2.blogger.com/_FoXyvaPSnVk/SByMsDeEO-I/AAAAAAAArFg/hf_UlOCBQdQ/s1600-h/SH40_22.jpg
Of course, that would be quite a bit of body work. The spoiler would probably be flush with the top of the rear fenders with a short section on each, then a corresponding upswept lip molded into the trunk lid. My guess is that there are fiberglass profiles available.
mccalebr said:Tony,
Ray
Yah, way more work than I wanted to tackle - plus, I don't like the rear end of that coupe.mgb4tim said:mccalebr said:Tony,
Ray
Like this?
MGB Berlinette
hehehe....doors & trunk both:.....remote, keyless system that unlocks & pops either door or trunk open!Scott_Hower said:Erm... dumb question, but how are you going to open the doors? You have some tricked out door opener?
tony barnhill said:They're not as large as the black area makes them look....we made a template & sprayed black paint all around it to look at the positioning.....& I agree they have to be a little higher.....but, they have to line up no higher than the matching holes we've already cut through the inner fenders....they're working vents pulling hot air out of the engine compartment.Scott_Hower said:Another opinion ... sorry, cant help myself, tell me to go away/shut up and I will... side gills are too large/low. Maybe an M3 gill?
Scott_Hower said:tony barnhill said:They're not as large as the black area makes them look....we made a template & sprayed black paint all around it to look at the positioning.....& I agree they have to be a little higher.....but, they have to line up no higher than the matching holes we've already cut through the inner fenders....they're working vents pulling hot air out of the engine compartment.Scott_Hower said:Another opinion ... sorry, cant help myself, tell me to go away/shut up and I will... side gills are too large/low. Maybe an M3 gill?
Cool, they're functional! Understand the space limitations.
But I think they're backward... shouldn't the leading edge of the vent parallel the trailing edge of the wheel arch?
tony barnhill said:Know what? After looking at the photos, I've gotta go to the bodyshop tomorrow to see....hmmmmm
If they're backwards, Scott - you win a "theAutoist" cap! heheheScott_Hower said:tony barnhill said:Know what? After looking at the photos, I've gotta go to the bodyshop tomorrow to see....hmmmmm
Whoa Nellie! Does that mean I get an extra discount on my next order :thumbsup:
tony barnhill said:If they're backwards, Scott - you win a "theAutoist" cap! heheheScott_Hower said:tony barnhill said:Know what? After looking at the photos, I've gotta go to the bodyshop tomorrow to see....hmmmmm
I'm trying to visualize what you mean by "end caps" - think you mean the extreme ends of the spoiler itself....the entire spoiler will lift with the trunk - there's just not enough 'meat' on the top of the rear quarters to put anything of size on them.....the ends of the spoiler (where they turn down) will go into the valley of the quarter panel & match its line along with the line of the little 'fins' that end in the tail lights.....there will be 2 spoiler 'feet' out near the edges of the trunk lid & 1 'foot' under the 3rd light....those will be completely underneath the spoiler itself but will have some angle to them.Silverghost said:To quote Paris Hilton - how often does THAT happen? - Cobra's are HAWT! LOL
Tony, I think that rear spoiler can work, if the leading edge of the end caps match the angle profile of the rear edge of the hood scoop and the rear edges of the end caps match the angle profile of the rear fenders/tail lamps. Further, if the end caps were attached to the quarter panels and the center section of the spoiler lifted with the trunk lid - as in the 70's GSX - that might be really sharp. A little hard to visualize, wish I could photo shop your pics!
Scott_Hower said:Is it possible to mount the spoiler so it's removable? In case you change your mind?
I've always found non-functional rear spoilers to be ricer-ish.
