Webbing for Soft Top
martx-5
I need to replace...actually install...new webbing on the soft top ribs of my '58 TR-3.
My problem is that there is no old webbing for reference. What I need to know is what are the measurements between each of the ribs and to the back deck where it screws in.
Geo Hahn
Here's a copy of the instructions that came with my top:
https://www.geocities.com/tucson_british_car_register/top-webbing.gif
You may find this to be close but only approximate as their may be some variation in manufacturers.
Many find it is useful to leave that back bow (the one above the window) unattached to make it easier to get the front tenaxes fastened. When erecting the top it also helps to leave the 'knee' joint slightly forward and push it home once everything is in place.
Geo Hahn
Sorry, I forgot that a geocities link is not 'clickable' from here. If you cut and paste the URL into the appropriate line on your browser you should get it okay.
BRIAN TOWNE
You might be able to follow the seams in your soft top. Thats what I did when I installed new top and webbing. Marked them to the seams on the top then shortened up by about 1/4 inch in each section to put some load in the top.
martx-5
martx-5
Thanks guys...that is exactly the info I was looking for. At least now I know how the ribs have to line up with the seams etc.
MDCanaday
My best advise is to use the seams as a rough guide, but make sure the bows are aranged so as to give good head room ect. test fit with tape, when its "right" put on REAL seat belt webbing.Its stronger, and lasts longer than sin. You will need a small nail and a butane lighter to "snell" the holes for the retaining screws.
Good luck !!
MD(mad dog)
Frameman 1949 Soft Top Webbing Austin Healey 2
nevets BN6 Soft Top Webbing Austin Healey 2
Celtic 77 MGB Seat webbing replacement. MG 1
Texas TR3 TR2/3/3A Convertible top webbing installation help? Triumph 5
Celtic 77 MGB 1977 seat webbing replacement. MG 1
B BT7 Top Webbing Austin Healey 1
af3683 TR2/3/3A TR-3 Top Webbing Installation Triumph 13
af3683 TR2/3/3A TR-3 Top Frame Webbing Questions Triumph 7
mountainman TR2/3/3A Tr3 Top Frame Webbing ? Triumph 20
T Wedge TR4a, TR6 and TR8 seat webbing's interchangeable? Triumph 2
martx-5 TR2/3/3A TR3 Hood Stick Webbing Triumph 5
G Top frame webbing N/A, what do I do? Is it needed? Spridgets 4
SpannerMan TR6 TR6 seat back webbing material source Triumph 7
jerrybny Conv top webbing question Triumph 2
Tinkerman TR2/3/3A Top Webbing on TR3-A Triumph 9
AUSMHLY Convertible Top Webbing and Color Austin Healey 7
Nunyas Seat Bottom diaphrams vs webbing MG 10
R TR4/4A 1963 TR4 soft hood cover with attached plastic stiffeners Triumph 2
S TR6 Soft top material Triumph 10
A TR6 TR 6 Soft Top Triumph 4
C Wanted Early MGB soft top and/or tonneaus, condition not very important MG Classifieds 0
KVH TR4/4A Closing the Soft Top Triumph 11
J TR2/3/3A TR3 Soft top speed limit? Triumph 9
dougie Did Big Healey Drivers Go Soft? Austin Healey 8
Donald1107 TR2/3/3A Soft top Triumph 14
R BUGEYE SOFT TOP FIT Spridgets 2
bighealeysource Soft Brake Pedal Austin Healey 7
Dnickels Spitfire Spitfire mk2 front suspension too soft Triumph 2
C 100/6 BN4 Soft Top Frame Austin Healey 16
J TR6 Hardtop/Soft Top Installation Triumph 2
W TR6 Tr6 soft top lnstall Triumph 5
CharlesBN1 BN1 Soft Top installation - need advice! Austin Healey 3
Bayless Need soft top for Morris Minor Other British Cars 5
D TR2/3/3A Fitting the hood. Soft top. Triumph 6
Graham H TR2/3/3A TR3A soft top Triumph 4
D TR6 Soft Top Selection 1976 Triumph TR6 Triumph 5
B Soft Top Boot Cover - BJ7 Austin Healey 5
H Soft Top Straps Spridgets 2
D BT7 soft top front bow seal Austin Healey 0
warwick-steve BT7 soft top frame location Austin Healey 6
I BJ8 soft top frame dimensions Austin Healey 4
C Top frame pinching soft top - BJ8 Austin Healey 6
R BT7 soft top [hood] question Austin Healey 4
R soft plug leaking Austin Healey 45
Desert Rat Bugeye soft top Spridgets 2
Marla TR4/4A Soft top frame Triumph 13
Marla TR4/4A Soft top success Triumph 1
Lutz Kramer Soft Top Zippered Window Austin Healey 5
N TR6 found a Soft top frame from a 1972 for sale Triumph 2
John Turney Longbridge BN4 Soft Top Austin Healey 9
