warwick-steve
Hi all
I have had my BT7 for 2 years and in that time have never used the soft top mainly because I prefer to drive it that way. However I am also reluctant to use it as the only time I tried to put it in position I found it almost impossible to relocate the soft top frame back under the rear cockpit. -- A tight fit which resulted in lots of pushing and pulling etc.
Am I missing a trick here?
Is there a recommended way to do this e.g. one side in then locate the other side.
How do you do it??
Advice from long time owners appreciated
cheers
Steve
How do you do it??
cheers
Steve
