Coil Spring Removal
61Alpine
Happy Holidays to all British car fans.
Question.
I am about to remove my coil springs along with the entire front system.
What is the safe way to remove the coils.
Here is what I have in mind and advise would be appreciated.
Place my floor jack under the spring, put some pressure on it. Then undo the King Pin and while standing in front of the car, out of the way, lower the jack slowly, slowly until the spring in uncompressed.
Okay now what would you do?
Rob
Administrator
Boss
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by 61Alpine:
Question.
Rob
<hr></blockquote>
NOt sure how it compares to my Jag, but I went to Pep Boys and bought a couple of spring compressors. They're cheap and will make the job much easier (at least it did on my Jag)
Bugeye58
Rob, don't know for sure about the Alpine, but your method is exactly how I do it on the Sprite, and I have used the same approach on several different types of vehicles over the years.( Including Jag's) I think the key issue is doing it from a position where you are out of the way if something does go wrong.
Jeff
[ 12-27-2003: Message edited by: Bugeye58 ]</p>
piman
Hello Rob,
how can you stand out of the way and still lower the jack? If the jack slips that spring could go anywhere and at a very high velocity. Spring compressors are relatively cheap and far safer.
If I had to use the jack route I would securely fasten some wire rope around the spring and the suspension arm to prevent it escaping. This would be a last resort method.
Alec
61Alpine
61Alpine
I forgot about spring compressors. I'll go get me a set on Monday.
Thanks guys.
Mark Beiser
Thats how I have always removed coil springs on any car I'm completely removing the front or rear suspension from.
If the car is up on jack stands, there really isn't much travel left in the springs.
You need a spring compressor to get things back together though.
thegoodbeamer
Hi Rob
with the entire front end out it isn't too hard to remove the springs.A goo set of spring compressors is neccessary to do it and be safe.You could also make one as similar in the manual. That is using a 1/2 inch threaded rod. offset plate to match the spring.Use a 1/4 inch steel for this.Weld 1/2 inch nut to this plate keeping in mind it will be offset.To the top of the rod weld a nut or double nut and then just crank it till the spring is compressed.Then you are set to drop A arm and remove the spring.
Best wishes for 2004.
and as always its sunny
piman
Hello Mark,
you may be very carefull yourself but it can be a risky process to advise someone else to do as there are varying levels of skills that forum members have. Trolley jacks, in particular, can be awkward due to the arc described by the arm.
The energy in a spring, even on full droop, is still large.
Alec
Tiger
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by thegoodbeamer:
You could also make one as similar in the manual. That is using a 1/2 inch threaded rod. offset plate to match the spring.Use a 1/4 inch steel for this.<hr></blockquote>
I did this and they worked well the first few times, until the poor-quality steel I got at the home center started to bend --
61Alpine
61Alpine
Okay so tonight I pulled the entire front cross member. Came out real easy boom right on the floor.
Okay so today I rented one of the spring compressors that go inside witht he movable arms. This will not work because the arms are to long and you can't get the parts far enough apart to compress.
So tomorrow I will start making my own out of 3/8" plate steel.
I'll let you know how they work next week.
61Alpine
61Alpine
Well I ended up using the rented compressors. What I did was, I took the loose claw off. I put the bolt down through the top shock tower. Attached the claw about 3-4 turns up and tightened it up until the bottom coil no longer touched. Undid the upper ball joint and uncomressed the spring worked like a charm.
Rob
nevets coil spring removal Austin Healey 7
V MGB Thackery (double coil spring) Washer Substitute? What else works? MG 9
S TR2/3/3A Front coil spring recommendation? Triumph 7
KVH TR4/4A Front Coil Spring Packing Piece Triumph 12
D coil spring finish Austin Healey 5
KVH TR4/4A Front Coil Spring Spacers Triumph 1
J TR2/3/3A TR3 coil spring height Triumph 4
PAUL161 General MG Front Coil Spring Comparison MGB verses a MG TF MG 4
RJS TR4/4A Coil Spring Clutch vs. Diaphragm Clutch Triumph 2
W Spitfire 1980 Spitfire Coil Spring Replacement Triumph 2
T TR2/3/3A Average life span of a TR3 Coil Spring? Triumph 5
ekamm TR2/3/3A Tr3 coil spring compressor Triumph 20
H Coil Spring Compressor Triumph 10
G Choosing the correct front coil spring Spridgets 54
Baz Cracked coil spring! Spridgets 25
K Coil spring compessor again.... Triumph 8
K Safety issue:Coil spring compressors Triumph 9
T Recommendation on coil spring compressor Triumph 6
A A.H. MKII BT7 Coil Spring Free Length Austin Healey 5
R TR4/4A TR4A Front Coil Spring Replacement Triumph 8
S front/rear coil spring diamaters. Triumph 4
J Coil spring free length & correct brake servo? Austin Healey 2
John Loftus coil spring height Austin Healey 2
Jarhead Coil Spring Compressor Restoration & Tools 5
M Replacement of Lucas HA12 with Lucas SA12 Coil Austin Healey 6
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
wkilleffer MGB Coil resistance MG 4
Cokerair TR4/4A Fried Ignition Coil Triumph 18
J TR2/3/3A 58 TR3A Coil weak? 9KΞ© on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 4
J TR2/3/3A 58 TR3A Coil weak? 9KΞ© on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 1
F Hot Ignition Coil Austin Healey 6
timsgolf Coil Wiring Austin Healey 20
K TR2/3/3A Front coil springs? Triumph 2
R TR2/3/3A TR3A Coil/condenser problem Triumph 22
PAUL161 T-Series MGTF Xpeg Ignition Coil MG 22
longbridgehealey Coil terminals Spridgets 1
P TR3B Coil Issue? Triumph 7
A Wedge Won't fire without jumper from coil to battery Triumph 6
F Spitfire No output from coil HELP!! 1972 Spitfire 1.3L Accusspark Triumph 19
JPSmit female spade tab - coil Restoration & Tools 13
M TR4/4A Dedicated front coil over shock absorbers. Triumph 5
Lin Lucas coil question Austin Healey 8
K What to do for coil bracket on upgraded generator? Austin Healey 8
K TR2/3/3A Coil nuts? The SW and CB nuts on a Moss gold coil? Triumph 3
JPSmit Daughter's VW - coil pack? Other Cars 2
S Intermotor or Lucas Sport Coil ? Austin Healey 14
FlyingCat Spitfire Spark to Coil Triumph 23
S TR4/4A Coil-over suspension upgrade Triumph 4
JPSmit Bosch Coil question Spridgets 14
2 TR2/3/3A Coil issues Triumph 31
