TR4/4A Dedicated front coil over shock absorbers.
malbaby
Has anyone fitted Mustang 11 QA-1 adjustable coil over shock absorbers,
Interested to know.... did you modify the spring tower and what length spring and spring rate did you use.
Tybalt
Do you mean Mustang II? That would be the downsized Mustang for the 1974 through 1978 model years before they went to the Fox body cars for 1979. On to springs bearing in mind that I have no direct experience with the application you mention but have done a fair amount of chassis set up in the past.
The stock front TR6 springs per Richard Good are ~305 lb/in and his performance front springs are 390 lb/in with a free length of ~8 7/8" and that ride height will be ~1" lower than stock. Unfortunately he doesn't mention the ID of the spring or diameter of the spring wire. He does note that for use on the TR4A that a spacer will be required.
It looks like the QA-1 Mustang II coilover uses a 2.5" ID spring and considering the lower damper mounts on the Triumphs and the ride height/preload adjustment nuts, I'm thinking off the top of my head that the QA-1 9" long spring (shortest QA-1 offers) might be a bit too long unless you put in a fair amount of preload but that in turn has the potential to lead to coil binding. My off hand guess is that an 8" spring, perhaps even a 7" one is the length you are looking for. As far as spring rates go, I'm thinking something in the 325 lb/in to 400 lb/in neighborhood is the answer without knowing anything else about your car. Of course if your suspension is heavily modified, then a full blown suspension analysis is in order. You might look at Swift Springs. They offer a wide variety of lengths and spring rates. The spring rates are listed in kgf/mm so 1 kgf/mm is 56 lb/in. A 7kgf/mm spring is 392 lb/in for example. In the 6 inch, 7 inch and 8 inch springs the range of spring rates go from 4 kgf/mm to a bone shattering 28 kgf/mm and even higher as spring length decreases. I think that you could run these without an issue in the stock spring towers but best to get some good measurements and confirm. Do run a spring pad at the top of the spring in the tower and while helper springs can be used when using shorter length springs, if you can find a spring that doesn't require too much preload to get you at your desired ride height without the need for helpers, you're probably better off.
M
malbaby
"Tybalt", thank you for your comprehensive comments.
My forum post was bought about by my desire to obtain a much "softer" and adjustable ride than the factory spec of around 310 lb/in.
"Performance" springs are a no go for me. Ok for a track car.
The factory springs are about 11" free length.
Thoughts were to use 3" ID springs on the Mustang C/O shocks that can be bought outside QA-1, eg Eibach, perhaps even modifying the TR upper spring tower and/or the bottom spring plate to overcome using springs that may be too short.
My other options are to fit ordinary 250lb springs of suitable length, wire diameter, number of turns etc that would probably have to be especially made, or better still have variable rate springs custom made.
I remember someone on a TR forum many years ago, perhaps in Germany? offering to make variable rate springs.
Tybalt
I was operating on the assumption that with the use of coilovers you wanted to be able to adjust ride height with everything in situ. That is why I was talking shorter length springs as opposed to springs at or near stock length. As for spring rates, Swift offers a 4kgf/mm (224 lb/in) and a 5kgf/mm (280 lb/in) spring in various lengths at 1" increments and IDs of 60, 65 and 70 mm.
Here's the URL for Swift's US operation listing of metric coilover springs, I can't help but think that Swift has some sort of outlet set up in Oz as well:
http://swiftsprings.wpengine.com/products/metric-coilover-springs/
toysrrus Info. needed on dedicated TR 3 Websites. Triumph 3
D Spitfire Spitfire mk2 front suspension too soft Triumph 2
Z Front Springs Removal Austin Healey 3
Z Front Shocks Austin Healey 19
T TR2/3/3A tr3 front carpet replacement Triumph 5
G For Sale: Triumph TR2, TR3, TR3A Sheet Metal Body Parts – Front Apron (valence) with grille, Bonnet (hood), Doors, Boot (trunk) Deck Lid Triumph Classifieds 3
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 14
crispy BJ8 Front Suspension Austin Healey 9
B Bent frame rails near BE front end Spridgets 2
K TR2/3/3A Front Hub and Felt Seal Triumph 1
K TR2/3/3A Greasing the Front Wheel Hubs? Triumph 9
B Front Wheel Camber Setting Austin Healey 8
F TR2/3/3A front body mounts Triumph 7
8 Wanted BJ7/8 front grill top cowl Austin Healey Classifieds 4
R Wanted WTB TR-3A front bumper brackets [pr] Triumph Classifieds 5
B 2013 Nissan Frontier front end mystery Other Cars 7
K TR2/3/3A Front wheel bearing adjust and end float?? Triumph 10
71TR6 TR2/3/3A TR3A Front Sway bar- how to install? Triumph 5
R TR6 Front suspension fulcrum pins Triumph 6
Kurtis Bugeye Sprite front frame rail horn replacement Spridgets 2
K For Sale Triumph TR3A front bumper and overiders Triumph Classifieds 0
B MGA Front bumper solution!! MG 1
Upland Mark IV front suspension Spridgets 3
pkmh Front Spring Removal For BJ8 Austin Healey 8
M Wanted Bj8 left front wing Austin Healey Classifieds 3
steveg Picture needed - front turn light Austin Healey 4
S TR2/3/3A Front Suspension Triumph 6
R TR6 Proper alignment of gearbox front cover plate Triumph 3
J Front Suspension Rebuild Austin Healey 16
I Bug eye front disc brake conversion. Spridgets 5
B MGA Sealant for front plate? MG 1
RAC68 Front Seat-back Angle Austin Healey 14
nichola TR6 Transmission front seal replacement question Triumph 8
71TR6 TR2/3/3A Right Front Suspension Damage Repair? Triumph 50
P TR6 New front shocks & air in clutch Triumph 15
Leatherman Wanted Red and black TR2 / 3 front emblem Triumph Classifieds 6
L 100/6 replacement front seats Austin Healey 7
J Wanted Front Yoke on Drive shaft Spridgets Classified 2
S For Sale TR3 front nose,trunk & petronix distributor Triumph Classifieds 0
L Denis Welch Front Disc Conversion Kit 100/6 Austin Healey 6
nichola TR6 Classic Technologies front sealing block Triumph 7
B TR4/4A Front cam bearing Triumph 8
A Front wheel bearing issues Austin Healey 11
bighealeysource Question on 100M front brake cylinder Austin Healey 4
M TR6 Front Brake Caliper Bracket Part Identification Triumph 0
A Front Shocks Bushing Replacement Austin Healey 2
J TR2/3/3A Front apron position Triumph 9
K TR2/3/3A The flexing front spindle and no brakes syndrome? Triumph 5
Jayplum TR2/3/3A Front suspension / springs Triumph 5
M Wanted WTB Late model TR6 Front Brake Caliper Brackets Triumph Classifieds 0
