When I apply putty, I find that I only get about one pass with the spreader before I run into problems with build up. If I try a second pass with the same spreader, the film and build up left on the spreader from the first pass bunches up the putty and makes the first spread worse.
What I do is use a second or third or fourth spreader if I make a more passes to smooth down the putty more. Do people wipe the spreader with a rag each time or something? I thought maybe a rag with a little bit of lacquer thinner might be ok to get the film off in-between wipes because that evaporates so quickly. Anyways always up for new ideas.
steve
steve
