TR6 Oil pan is going to leak: suggestions?
nichola
Bronze
Check out the gap at the oil seal housing (pics). That’s a little more than .026 and I’m looking for suggestions. My first thought is to run a little extra gasket there, spanning the bottom of the seal housing.
From what I’m reading here and elsewhere it seems running RTV along oil pan flange but dry on the engine block side, sandwiching the gasket, is typical procedure to mount the pan. But that certainly wouldn’t address this gap at the seal housing.
TR3TR6
It looks like you may need to do a little forming on the oil pan. Check it with a straight edge first to see if the lip is flat. Good luck.
Mickey Richaud
:iagree:
What he said. The flange of the pan is quite prone to distortion due to over-tightening the mounting screws. You may find that you'll need to tap the surface back into shape - the good solid surface of a bench vise makes for a great surface to tap on.
Good luck!
Mickey
nichola
nichola
Bronze
:iagree:
Good luck!
Mickey
Thanks guys. The pan is not dimpled, but was a bit up on the front end, doing a little teeter totter routine. By only torquing to 5 ft lbs it fit nice and flat. Just concerned with the rear seal housing gap. Going to make an extra gasket the length of the housing to take up the gap.
poolboy
I don't think an additional paper gasket would be the answer....You are going to need something that will ooze into the crevices.
Permatex Ultra Gray Gasket Maker would be my choice if faced with that situation.
nichola
nichola
Bronze
I have some and was going to use it for the pan side of gasket, dry on the block side. But at the housing I was going to housing, ultra gray, a straight gasket, ultra gray, pan gasket, and oil pan. I agree some ultra gray needs to fill in the gapsy. I’m sorta scratching my head wondering why that housing isn’t level with the block surface. Didn’t pay attention when I disassembled.
Tr6easyrider
Don't remember, is there any play in the bolt holes of the housing or do the bolts shanks help center it?
Maybe the housing dropped down from the weight but held by the seal on the crank as you tighten the
bolts. Just a guess. And don't forget the copper washer on the top bolt.
nichola
nichola
Bronze
I just slid the seal over the crank and the bolts lined up, so I fastened it, and I did use the sealing washer at the top. After I saw the mismatch I loosened all the bolts and tried to slide it down but no go. Thought I might squeeze that seal a little off center but nope, and probably not a good idea anyway.
Merlin63Tr4
If this was my engine, I would fabricate a filler piece using shim stock of the appropriate thickness, match drill the attach holes and install the filler piece using sealant between the oil seal housing and the filler piece.
M.
nichola
nichola
Bronze
M.
I like the metal shim suggestion. Thanks.
nichola
nichola
Bronze
Oops... not going to use Ultra Gray, rather will use a gasket sealant (not a gasket maker). Here's the last item from Permatex on what NOT to do.
10. Using a gasket maker as a dressing on a conventional gasket.
This might be the most common gasketing error of all. Many mechanics will use an RTV gasket maker to hold a conventional or cut gasket in place during assembly. Some mechanics will even use the RTV gasket maker as a dressing, coating both sides of the gasket. Gasket makers are the wrong product for these applications – their formulations are too thick for use as a dressing. If you’re installing a conventional gasket, use a gasket sealant – they’re available in sprays, liquids, and tubes, with specialized formulas for a variety of applications.
LarryK
I use a spray glue or the 3M emblem adhesive to keep gasket in place and small bead of rtv the rest on engine side. If I figure on not taking it apart again, I use old plain permatex, hardened type.
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 0
M TR2/3/3A oil pan bolts Triumph 16
69MGC T-Series TC Oil Pan Weep Hole, Is it really necessary? MG 4
S 1275 oil pan removal Spridgets 30
I Bugeye oil pan help Spridgets 3
T Oil pan leak? Spridgets 7
S TR2/3/3A Oil Leak Dripping from Front and Rear of Left Side Oil Pan---Only While Running Triumph 14
D Oil Leak at rear of oil pan Spridgets 11
D TR2/3/3A '59 TR3A oil pan leak Triumph 12
T TR6 Oil pan Triumph 5
R GT6 Oil pan bridge installation Triumph 15
T TR2/3/3A TR3 Oil Pan Paint? Triumph 2
K TR2/3/3A Oil pan Again.... Triumph 4
K TR2/3/3A Oil Pan bolt torque spec? Triumph 2
germanmichel Camshaft change , oil pan has to be removed ? Austin Healey 2
bugedd Front suspension and oil pan Spridgets 17
bigbadbluetr6 TR6 Oil pan gasket Triumph 2
Michael Oritt Leaking oil pan Racing 8
RJS General TR Straightening Oil Pan Triumph 5
D TR6 Tr6 oil pan Triumph 3
J Measurement for aluminum oil pan Austin Healey 3
M Broken off dip stick plastic tube, stuck oil pan, and I think too much... Spridgets 10
T six cylinder oil pan - wtb Austin Healey 2
PatGalvin TR2/3/3A TR3 Engine Front Sealing Block, Oil Pan Screw Size and Thread Pitch? Triumph 11
SMGoose Oil pan Triumph 9
Crankshaft Oil pan gasket seal Triumph 10
DNK Oil pan Gasket Triumph 7
T TR6 Will a 71 TR6 oil pan come off in the car? Triumph 3
R Alloy Oil Pan from Moss Austin Healey 9
M Leaky oil pan... again Triumph 16
I source for used 948 oil pan Spridgets 4
Morris Oil pan gasket Spridgets 10
M Oil pan torque Triumph 23
Geo Hahn TR2/3/3A TR3/4 Oil Pan Gasket Triumph 49
T 1500 oil pan is off, what should I look for? Spridgets 20
S oil pan bolt Other Cars 9
hondo402000 Oil pan heater Triumph 11
Superwrench Oil Pan -black Austin Healey 3
M TR2/3/3A TR3 aluminum oil pan Triumph 9
4 '03 X-Type 2.5L Oil Pan Gasket R+R ? Jaguar 2
N BJ8 Dented oil pan Austin Healey 28
mountainman TR2/3/3A TR3 Oil Pan Gasket? Triumph 7
A TR2/3/3A Triumph TR-3, 4, and 6 alum. oil pan Triumph 3
H Aluminium oil pan Austin Healey 9
W oil pan bolt questions Austin Healey 18
mountainman TR2/3/3A TR3 Leaking oil pan Triumph 17
GBRandy Oil Pan Gasket Installation Triumph 11
livinginthepast Beautifying the oil pan-948 rebld. It's the pits! Spridgets 12
boxfullofyertoys Oil Pan Gasket Spridgets 8
1 Austin oil pan bolts. Austin Healey 4
