If the lock washers for the oil pan bolts appear to have imprinted themselves into the pan(probably from over tightening) would the correct size "flat" washer added underneath the lock washer solve this problem?
In my opinion adding a flat washer just introduces two more surfaces where a leak may occur. I always use a dolly and hammer to flatten any dimples caused by over-zealous tightening but the use the original style bolts and split washers.
