General Tech Bleeding Brakes—Venturi/Compressor
KVH
I have one of those old Griot’s garage one man bleeder kits that you use with a compressor. When I use it, I never see an end to the bubbles. In other words, I don’t get to a point where everything just looks like clear fluid coming through the plastic line.
Can anyone just give me a little thumbnail description of how that tool is effectively used, and whether it is still considered a good tool. I see so many others out there.
Thank you
martx-5
Sorry, I don't know how that particular brake bleeder works, but I've always managed to bleed brakes by myself using the gravity method. With as far along as you are with the bleeding, it should be a breeze to finish by gravity bleeding.
CJD
I do know that if you open the bleeders too much they will suck air. So the air is not from the system, but introduced through the bleeder screw threads. Only crack the bleeders just enough to get a flow, no more, and the bubbles should stop.
LarryK
I use a tall glass jar filled about half way with brake fluid. I run a clear hose from the bleeder to the bottle with hose clipped to jar to keep fom popping out. Hose is long enough i can see from drivers door. I open bleeder and pump brakes and watch bubbles. Fluid when pumped might return to cylinder but air goes to the top of jar and out. Used one man bleeders, but can be messy. Have not seen Griots, but have used similar.
TomMull
+1. Also note that the bubbles are generated at the bleeder screw so the air may still be evacuated from the system even when you see the bubbles. At least that's what I've found with my vac bleeder.
Tom
Geo Hahn
One alternative is to wrap the bleeder threads with Teflon tape to better seal against the ingress of air as you vacuum bleed.
I have used the venturi sucking unit from HF (looks like the Griots version) but for easy bleeding I usually go with a pressure bleeder made from a bicycle inner tube. Quick, easy and effective.
KVH
KVH
Thanks guys. I finally got everything working fine. I had a terrible time bleeding those lines, and maybe because so much air was caught in the lines from when I put the car on jacks two months ago with the fluids empty.
I eventually used the old fashioned way—my son pumping the brakes, but it literally took over an hour of going back and forth thru the process until my rear cylinders would finally bleed.
So, naturally, I’m wondering if it was all my fault, and I have two questions.
First, did I mess up by not bench bleeding the master cylinder. I can’t recall ever needing to do that when I replaced the brake master cylinder in the past. It always seems the bleeding process took care of that.
Second, when I was all done I noticed that the emergency brake was partially on. Could that have been part of the problem? (Should I have publicly admitted doing this)
TomMull
Those master cylinders often get air bound. Bench bleeding will avoid that. So will cracking the pressure line at the cylinder itself while pumping after it's in the car. Not a problem with a vacuum or pressure bleeder though.
Although the hand brake will limit the movement of the pistons in the wheel cylinders, you still should be able to get rid of the air.
Tom
fundytides Bleeding Lockheed Brakes on 1951 Vanguard Other British Cars 11
C TR2/3/3A bleeding brakes Triumph 11
dklawson Spitfire Bleeding Herald Brakes [similar to Spit] Triumph 9
Jim_Gruber Brakes and Bleeding Spridgets 16
oxford Bleeding Brakes! Up-date. Austin Healey 0
oxford Bleeding Brakes! Austin Healey 25
F Spitfire Bleeding Rear Brakes - Ran Into Issues Triumph 7
T Spitfire Bleeding brakes Triumph 6
B Bleeding BJ7 brakes Austin Healey 9
K Problems with Bleeding the Brakes onan XKE? Jaguar 2
tahoe healey Bleeding the bloody brakes again Austin Healey 10
tahoe healey re bleeding brakes. Austin Healey 5
pkmh Bleeding brakes Austin Healey 18
Lynn Kirkpatrick Bleeding dual system brakes & how do they work? Restoration & Tools 5
bcbug Bleeding Brakes Spridgets 2
drooartz Help -- first time bleeding of clutch/brakes Spridgets 8
chicken bleeding the brakes Austin Healey 9
bighealeysource bleeding the brakes on my BN1 Austin Healey 4
bighealeysource bleeding the brakes on a BN1 Austin Healey 15
WillR bleeding brakes MG 18
C What was that tool for bleeding the brakes? Spridgets 3
RickB Bleeding dual circuit brakes? Spridgets 12
SCguy Bleeding Brakes ? Triumph 10
O TR6 Bleeding TR6 Brakes Triumph 2
jlaird Bleeding brakes Spridgets 8
Monark192 Bleeding Brakes MG 12
delisaj Bleeding the brakes-- won't work.. help! Triumph 4
SCguy TR4/4A Still bleeding my brakes on my TR4!!! Triumph 7
Guinn Bleeding brakes MG 9
SCguy Bleeding Brakes tips? Triumph 7
R bleeding de brakes Austin Healey 10
B Help Bleeding the Brakes Austin Healey 13
R tool for bleeding brakes? Rover / Land Rover 3
F Bleeding Front brakes MG 11
S Bleeding the Brakes Austin Healey 10
Frameman 1949 Brake Bleeding Austin Healey 0
KVH General Tech TR4A Brake Bleeding Triumph 5
Crankshaft TR2/3/3A Bench Bleeding Triumph 8
Govtslug TR6 Brake Bleeding Triumph 58
TRclassic3 TR2/3/3A Odd observation when bleeding Triumph 5
rgfrey Bench Bleeding Brake Master Cylinder Austin Healey 2
R TR2/3/3A Bleeding the Slave Cylinder Triumph 118
N Need brake bleeding advice Spridgets 6
tahoe healey DIY Extension for Clutch Bleeding Austin Healey 23
F TR2/3/3A Bleeding Technique Triumph 46
K Bloody "bleeding" issue Austin Healey 55
bugedd Bleeding clutch Spridgets 2
F TR2/3/3A Bleeding Hydraulics Triumph 9
S Help with clutch bleeding on BJ8 Austin Healey 7
