Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: BN6: Shock absorbers do not fit after renewing the link arms
  1. #1
    Join Date
    May 2010
    Location
    Near Cologne, Germany
    Posts
    222
    Thanks Thanks Given
    Thanks Thanks Received
    Thanked in
    Gents,
    after renewing the link arms, the shock absorbers do not fit to the frame anymore. With the old ones everything is fine. Any ideas?
    You can find pictures of the problem as well as the old and new link arms attached.
    Cheers,
    Volker
  2. #2
    Yoda steveg's Avatar
    Join Date
    Sep 2007
    Location
    Altadena, CA
    Posts
    4,082
    Thanks Thanks Given
    142
    183
    Thanked in
    Re: BN6: Shock absorbers do not fit after renewing the link arms
    The studs are painted. Is that keeping them from seating properly?
    Steve Gerow
    Altadena, CA, USA
    Maker of most complete Big Healey rear disc kit
    Check out my galleries:
    http://www.pbase.com/stevegerow
  3. #3
    Join Date
    May 2010
    Location
    Posts
    222
    Thanks Thanks Given
    Thanked in
    The studs of the link arms or the studs of the shock absorber?
  4. #4
    Join Date
    Feb 2007
    Location
    California USA
    Posts
    4,190
    Thanks Thanks Given
    5
    60
    Thanked in
    What do you mean by 'renew?' The 'old' and 'new' links look to me to be completely different; i.e. the old are cylindrical, and the new are barrel-shaped, and appear to have welded seams. Also, from measuring my screen with a tape measure the new appear to be about a quarter inch longer socket-to-socket (that could cause the cocking of the shock body.
    Do you mean replaced, by chance?
  5. #5
    Join Date
    Aug 2016
    Location
    Greensburg, PA
    Posts
    161
    Thanks Thanks Given
    3
    Thanked in
    It looks like the center-to-center dimension of the new link is greater than the old one. Measure them to confirm.
    Bob was quicker than I was.🙂
  6. #6
    Jedi Warrior red57's Avatar
    Join Date
    Apr 2008
    Location
    Washington, USA
    Posts
    609
    Thanks Thanks Given
    10
    29
    Thanked in
    I agree with Bob & Jack on center-to-center dimensions, they do not look the same in the pictures anyway.
    It also looks to me like the diameter of the tapered pin on the black ones may be a fatter taper which would alter the depth of insertion into the shock arm?
    Dave
  7. #7
    Join Date
    Nov 2012
    Location
    Warrington PA
    Posts
    566
    Thanks Thanks Given
    Thanked in
    Angle of each is different as well.
  8. #8
    Join Date
    Sep 2007
    Location
    Altadena, CA
    Posts
    4,082
    Thanks Thanks Given
    142
    183
    Thanked in
    The studs are painted - those on the links. The unpainted others in picture 3 are bolts.
    IMO, the fact that the taper doesn't seat as far as the original is probably the problem. The link being a little longer just positions the shock arm at a slightly different vertical position.
    I'd remove the paint from the tapers, then measure the min & max diameters, comparing to those of the originals.
    Steve Gerow
    Altadena, CA, USA
  9. #9
    Join Date
    Sep 2007
    Location
    Altadena, CA
    Posts
    4,082
    Thanks Thanks Given
    142
    183
    Thanked in
    ShockVolkerGap.jpg Volker's gap between link and arm
    ShockGerowCrop.jpg Gap on my old rear shock, unseparated after removal from car.
    Steve Gerow
    Altadena, CA, USA
  10. #10
    Join Date
    May 2010
    Location
    Posts
    222
    Thanks Thanks Given
    Thanked in
    Thanks for all the hints. I will measure and come back soon.
  11. #11
    Join Date
    May 2010
    Location
    Posts
    222
    Thanks Thanks Given
    Thanked in
    As steveg said, the gap is larger with the new link arms. Do I have the correct shock absorbers for the BN6? I have Armstrong Part No 5550*2 and 5550*3 (see picture attached).
  12. #12
    Join Date
    May 2010
    Location
    Posts
    222
    Thanks Thanks Given
    Thanked in
    Gents, can anybody tell me if this is the correct positioning of the uppet stud of the link arm? Or must the mount of the leaf spring contact the nut of the link arm?
    What is the way to bring the link arm in the right position at the mount of the leaf spring? Ca I use a hammer?
    Cheers,
  13. #13
    Yoda John Turney's Avatar
    Join Date
    May 2002
    Location
    Concord, CA
    Posts
    3,923
    Thanks Thanks Given
    72
    46
    Thanked in
    Volker,
    There should be a distance tube, Moss#725-130, between the two ears on the axle. The upper stud goes through it. Tightening the nut while holding the hex section on the stud should pull the stud into place.
    John, BN4
  14. #14
    Join Date
    Sep 2007
    Location
    Altadena, CA
    Posts
    4,082
    Thanks Thanks Given
    142
    183
    Thanked in
    Volker,
    Following up on your earlier issue, did you clean the paint off your new links and the tapered stud fits properly?
    Steve Gerow
    Altadena, CA, USA
  15. #15
    Join Date
    May 2010
    Location
    Posts
    222
    Thanks Thanks Given
    Thanked in
    Gents, after cleaning off the paint and tightening the nut of the upper stud very hard, I was able to bring the link arm into the right position at the leaf spring. Unfortunately after adding the shock absorber I face the same problem as with the old link arm: the upper stud was squeezed out to the right of the upper cylinder of the link arm :-( Actually this was the reason why I started to replace it.
    Is this expected or at least"ok"? Please note tghe distance of the lower cylinder of the link arm and the lever of the shock absorber.
    Volker
  16. #16
    Yoda Randy Forbes's Avatar
    Join Date
    Feb 2003
    Location
    SW Florida (Sarasota/Bradenton area)
    Posts
    4,534
    Thanks Thanks Given
    12
    41
    Thanked in
    Not wishing to complicate things, but since it hasn't been mentioned...
    The stud going through the axle (with the distance tube) and for that matter, the tapered stud going into the shock arm, should not be tightened down until the weight of the car is resting on the wheels (in other words, sitting at normal ride height) or the rubber bushing longevity will be compromised.
    A rubber bush does not rotate as the body of the car moves up and down over road bumps, it flexes, or twists. If you tighten those links down when the wheels are off the ground, the rubber bush will already have some of its twist being used. When the car goes over a bump and the suspension is fully compressed, the bushing may be twisted beyond its engineered range of flexing.
    On the other hand, if you enjoy doing the job(s) often, don't worry about it...
    http://www.britishcarforum.com/bcf/image.php
    57 Healey BN6L-942 Wine Red/Honey Tan
    99 BMW M Coupe EB w/ ES/TS & 99 M Rdstr BK/BK
    01 BMW M Rdstr Steel Gray Performance Center (factory) Delivery
    16 X5M/DINAN Stg II Mineral White Metallic Wife's 716 hp/702 Lb-ft Turbo Hauler
  17. #17
    Join Date
    May 2010
    Location
    Posts
    222
    Thanks Thanks Given
    Thanked in
    Quote Originally Posted by BN6_2197 View Post
    Volker
    Does anybody have an answer or meaning to my „distance“ problem?
    Randy, thanks for this valuable hint
    Volker
  18. #18
    Yoda GregW's Avatar
    Join Date
    Jan 2005
    Location
    Santa Monica, CA
    Posts
    7,751
    Thanks Thanks Given
    20
    Thanked in
    It was mentioned earlier to get measurements of the stud diameters. The taper in your first photo looks more drastic on the new piece. Also much wider.
  19. #19
    Join Date
    Sep 2007
    Location
    Altadena, CA
    Posts
    4,082
    Thanks Thanks Given
    142
    183
    Thanked in
    Volker
    A) Is the replacement from one of the regular suppliers - AHspares for instance? If so, maybe that's the only one available out there. If not, suggest returning it and sourcing a good one - as it clearly doesn't fit properly.
    Can't tell from the pic if the tapered stud is seated in the shock arm and can be bolted up solidly with the shock bolted to the chassis.
    B) If A) is not an option and everything bolts up solidly - with the car on the ground per Randy above - it should work.
    Steve Gerow
    Altadena, CA, USA
  20. #20
    Join Date
    Apr 2008
    Location
    Washington, USA
    Posts
    609
    Thanks Thanks Given
    10
    29
    Thanked in
    I still think the taper on the link pin doesn't look right but that could just be the picture.
    One way to check the stress level on the link is to install the link in the axle bracket and the shock arm (not completely tight as Randy suggested, but snug enough to make sure it's roughly where it will be when fully tightened) while the shock body is loose/unbolted. The shock should sit in it's normal location when the link is connected... ie, there should be no strain sideways on the link in order to tighten the shock mounting bolts. If there is any sideways strain, the rubber in the links will not last long.
    Dave
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
