BN4 and BN6 Limited Edition Prints
David Townsend
100-6-Badge-web.jpgAfter a brief foray into my Triumph catalog to complete the TR6 illustration, I'm back to the Healeys—this time with the BN4 and BN6. And yes, the 3000s are coming next.
The BN4 and BN6 standard illustration will include disc wheels (including hub caps), overdrive gearbox, and adjustable steering column. ou can customize your print with any of the available options including:
  • Available factory body/interior color combinations (special colors are available upon request)
  • 48-spoke wire wheels
  • 60-spoke wire wheels
  • Octagonal wheel nuts
  • Dunlop racing wheels with competition knock-offs
  • Delete overdrive gearbox
  • Delete adjustable steering column
  • Headlamp grilles
  • Lucas 576 spot lamps
  • Wood rimmed steering wheel
  • Weber carburetters
  • Manufacturer’s plate with the serial numbers of your specific car
  • Lucas style wing-mounted mirror
  • Raydyot mirror (mounted to driver’s door)
  • Other options as may be required to personalize your print
These highly detailed illustrations based on Gerry Coker’s original line drawing, are beautifully rendered and printed on museum quality, acid-free, giclee paper. The ultimate gift for the Healey lover. Prints come in 12" x 24" and 18" x 36" sizes. Approximate delivery time is 2-3 weeks.
You can order at Sports Car Art.
DerekJ
David. The 100-Sixes had two different types of interior depending on the model. Are you planning on doing both? The early cars also had an integral head and smaller carbs and a single windscreen washer, plus a few other minor differences which may or may not be visible on your drawings. I look forward to seeing the first versions.
David Townsend
David Townsend
The order form includes the capability to upload pictures so I can adjust each illustration to accommodate specific differences.
Tech396
I just went to the site to order a print. I didn't see an area to go for a pre-view.
Is this possible to see what we are buying?
Thanks in advance
David Townsend
David Townsend
Thanks in advance
Absolutely. I'll post up some JPEGs once I get the illustration back from my technical editor. You can get a good idea of the illustration style by looking at the BN1 and BN2 drawings.
Tech396
Thank you for the reply.
There were three types of BN4s from 56-59, I'm curious to know which one you chose to base the drawing on, early (2 Port) Middle (6 Port) Both with Longbridge interior.
Or the late (6 Port, with the newer style interior and soft top frame. "Abingdon trim"
David Townsend
David Townsend
The base art is a bit of a mash up of various BN4s (same for the BN6). I then adjust the illustration to the specifics of each customer's car, hence the reason I ask for photogrpahs when submitting an order. When cars aren't available for my personal inspection, my "go to" resource for details is Clausager's "Original Austin Healey",
David Townsend
David Townsend
Here a few samples of the BN4 and the BN6 illustrations.
The BN4 is based on one of the early "Longbridge" cars with the carbs on the horizontal, and a few other details peculiar to the early cars. As for the Primrose over black colors well, they're not really my cup of tea but I wanted to try something other than Healey blue (not that there's anything wrong with it)/ Same for the steel wheels. If you're an afficianado of the first 100-6s let me know what things that might need changing. There's only so much accuracy I can achieve using examples from books and the Internet.
I chose to accessorize the BN6 with a wood rimmed steering wheel, Lucas "Flamethrower" spot lamp and Raydyot side mirror but you get your print with the accessories of your choice.
AH-BN6-rear.jpgAH-BN6-cockpit.jpgAH-BN6-front.jpgAH-BN6.jpgAH-BN4-rear.jpgAH-BN4-cockpit.jpgAH-BN4-front.jpgAH-BN4.jpg
DerekJ
I think the primrose over black is a great combo especially when you add a black hardtop to it. It is also the only colour combination that came with a yellow interior. Very rare. The primrose coloured cars (without black coves) had black interiors.
The Longbridge BN4s had a single windscreen washer while the later cars had two, same as the 3000s.
DerekJ
A couple more minor details.
The windscreen washer bottle on the Longbridge cars was made of glass. The piping on the seats of the later 100-Sixes did not go right round the 'ears' of the sides of the front seat where it hinges. The piping on the Longbridge car above is however correct as it was similar to the 100s. I think that some of the other differences between the models will be very difficult to see on the illustrations, such as the interior panelling behind the front seats and also the arm rests. The Longbridge car has a saddle style armrest similar to the 100s but slightly shorter while the later cars have a rectangular pad on top of the tunnel.
David Townsend
David Townsend
Derek,
Great help with the details. I've made note of them. This is where having folks submit pictures of their car with an order really comes in handy in helping to get things just right. Again, thanks for you assistance.
DCTownsend
Tech396
I would like to order a print but need to know what info you need to have the correct glass washer bottle and 6 port engine, as supplied from the factory
on my Longbridge Healey
Thank you in advance
David Townsend
David Townsend
I've attached the pic that I used to draw the glass bottle. Images of the engine bay, rear (interior) quarter, and the aforementioned washer bottle would be very helpful in making the details accurate. You can upload images directly to the order form and there is also a Special Instructions box where you can fill in anything you think I would need to know.
healeyblue
washer bottle and rear panels. Can't help with the engine bay pics as I have the 2 port engine not 6 port.
healeyblue
Note the door seals are different on the longbridge cars as well. No furflex on the perimeter, just at the front edge of the door opening.
Tech396
moss bottle.jpgThis photo from Dereks site shows the original brackets nicely. I will upload the necessary files on your website when I place my order, but thought this may be of help for you in the meantime
David Townsend
David Townsend
Here's BN6 that's been customized a bit (customer's request) with a hardtop, Enod's petrol cap, glass washer bottle, Girling front disc brakes, and commission plate. The 100 6 badge in the background has been moved to the right side so it didn't interfere with the hardtop.
jnew >>> Austin-Healey Parts Lists for BN4-BN6, BN7-BT7, & BJ7-BJ8 Available Online Austin Healey 17
C Price difference between 100-6 BN4 and BN6?? Austin Healey 14
Jim_Newman Hardtop BN7 vs BN4 [BN6 vs BT7] Austin Healey 7
A 100/6 BN4 Restoration Austin Healey 4
A 100/6 BN4 Door Lock Austin Healey 15
zoohow BN4 Top Frame Installation Austin Healey 1
W BN4 Engine Mounts Austin Healey 2
B For Sale Too many Healeys - BN2, BN4, BT6, BJ7 For Sale Austin Healey Classifieds 0
rgfrey BN4 Ignition/Turn Indicator Light Austin Healey 7
P BN4 Generator Woes Austin Healey 7
W BN4 History Search Austin Healey 7
W Wanted Servo for BN4 has to be original 1957 or before any condition considered. Austin Healey Classifieds 11
W BN4 Steering box bushing. Austin Healey 2
Csarneson BN4 Windscreen Washer Jet Austin Healey 3
Hangtown Healey BN4 Front Springs Free Length Austin Healey 3
Csarneson BN4 Interior Assembly - Unidentified Holes Purpose Austin Healey 2
BoyRacer BN4 Front Wings on a BN1 Austin Healey 9
C 100/6 BN4 Soft Top Frame Austin Healey 16
A BN4 Hard Top Austin Healey 23
B Any experiences with adjustment of Jet Adjusting Nut on BN4? Austin Healey 5
B Side window question for early Longbridge BN4 Austin Healey 4
B For Sale Brand New Black Tonneau Cover for BN4 and BT7 - for Right Hand Drive Car Austin Healey Classifieds 0
B Longbridge BN4 top frame question Austin Healey 6
K BN4 Locking Door Handle Removal Suggestions Austin Healey 10
B BN4 Longbridge door panel question Austin Healey 4
B Piping for Aluminum Shut Pillar Finisher on Longbridge BN4 Cars - Yes or No? Austin Healey 4
longbridgehealey BN4 Longbridge flasher unit. Austin Healey 19
longbridgehealey Removing BN4 Bonnet Austin Healey 9
John Turney BN4 to Early BJ8 Rear Axle Austin Healey 12
longbridgehealey 100-6 BN4 horn question Austin Healey 2
B Differences between BN2 and BN4 speedometer gears?? Austin Healey 7
Csarneson Early BN4 steering box pitting Austin Healey 16
Csarneson BN4 Cam Gear Install Austin Healey 3
K Correct side screen nut for early 58 BN4 Austin Healey 14
D For Sale Detroit Locker Diff, Servo and Springs BN4 100/6 Austin Healey Classifieds 0
P BN4 Hesitates on Starting Austin Healey 12
Csarneson BN4 Wiring Questions Austin Healey 5
D Photos of Longbridge BN4 door seal track. Austin Healey 5
Bugeyze BN4 Windscreen Shims? Austin Healey 13
Csarneson BN4 Engine Rebuild Questions Austin Healey 8
G Wanted AH 100-6 BN4 Steering Wheel Austin Healey Classifieds 2
1 Price check on an original 1957 100-6 BN4? Austin Healey 29
L 100/6 BN4 Brake fluid Austin Healey 17
L 100/6 BN4 Hood fittings Austin Healey 5
MisterB Shut pillar differences? BN4 to BJ8 Austin Healey 7
L 100/6 BN4 Fuel Tank feed Austin Healey 5
longbridgehealey BN4 turn indicator blinking very slowly Austin Healey 2
Csarneson Battery Cable routing pics on a BN4? Austin Healey 7
T Dunlop 4 wheel Disc brakes on BN4 Austin Healey 11
busybrit Healey BN4/6 bell housing vs BN7/BT7 differences. Austin Healey 2
