BJ-8 SU Fuel Pump Replacement
stever
Hi, guys,
Based on recommendations received on an earlier post I have purchased an electronic SU fuel pump. Now I have to actually replace the old unit. What is the easiest, most efficient procedure to do this chore? I recall someone telling me to remove the rear seat insert for easier access to the pump. So, I would appreciate your inputs on this. Thank you!
Steve
Keoke
Stever because it be hot down here:
I suggest U remove the rear seat to do this task
John Turney
Yes, much easier to do it from the top by removing the rear seat pan. You will have to remove the tire and put jackstands under the axle to get off the seat pan from below on a BJ8.
S
stever
Thank you very much! I have quite a few little "chores" to do on the car such as an oil change, grease job, etc. so I will be putting it on jack stands anyway so that should be done all at the same time. Thanks, Steve
RAC68
Steve,
Removing the rear seat is not necessary, in my opinion, and only adds access work and potential issues. By raising the rear right side and removing the wheel, the pump is directly in front of you with all its electrical connections and fuel lines.
Your rear seats are secured with screw nuts under the area and, because of being open to road debris and moisture, are often rusted in place. Removing the seats can open you to additional work and the risks associated with removing these parts. You will not be wasting any time by raising the car and removing the wheel to view the site and evaluate the task ahead … even if you decide to go to the point of removing the seat pan.
Just my opinion,
Ray(64BJ8P1)
T MGA Local parts store replacement for MGA fuel pump MG 10
bmurphy7369 1994 XJ6 XJ40 fuel pump replacement Jaguar 6
Lynn Kirkpatrick Fuel pump replacement MG 4
Obtong Replacement Fuel Pump MG 16
AndreL TR6 Conversion to electric fuel pump Triumph 8
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
D TR4/4A TR4a Fuel Pump Triumph 10
RJS TR4/4A Fuel Pump Gasket Triumph 8
D MGB Fuel Pump MG 2
Martinld123 Electric Fuel Pump Austin Healey 6
S TR2/3/3A Fuel Pump??? Triumph 14
D Fuel Pump Ticking but Not Pumping Austin Healey 8
A Spitfire Fuel Pump Triumph 5
A Spitfire Spitfire Fuel pump issues Triumph 5
K TR2/3/3A Fuel line routing from pump to carbs Triumph 7
A GT6 Fuel Pump Leaking at out port GT6 MK3 Triumph 0
wkilleffer MGB 1974 MGB SU fuel pump voltage issue MG 11
S fuel pump upgrade Spridgets 0
S Sprite Fuel Pump Upgrade Austin Healey 1
F TR4/4A New to forum - Rebuilt Fuel Pump and weeping float bowl Triumph 9
P XJ12 Fuel pump relay 85 Jaguar 4
petnatcar Fuel Pump Upgrade Austin Healey 2
R Electronic Conversion on an SU Fuel Pump? Restoration & Tools 2
T TR6 Fuel pump lines Triumph 2
1 TR2/3/3A TR3 Fuel Pump Thread Type? Triumph 4
R Electric fuel pump wiring Spridgets 4
T SU Fuel Pump Mounting Austin Healey 5
D TR2/3/3A More Fuel pump questions. Triumph 10
Donald1107 59 TR3A Fuel Pump Triumph 48
BobHaskell SU Fuel Pump Pressure Austin Healey 1
Cutrog1 Fuel Pump Ticking Austin Healey 13
MGTF1250Dave T-Series MG TF fuel line from tank to pump MG 3
S SU fuel pump servicing Austin Healey 4
71TR6 TR2/3/3A AC Fuel Pump Lever Triumph 10
E MGB 1965 mgb fuel pump removal MG 2
D For Sale Su fuel pump Other British Classifieds 5
D For Sale Su fuel pump Austin Healey Classifieds 5
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
vette A Quiet SU Fuel Pump Austin Healey 2
A TR4/4A AC Fuel Pump stuff Triumph 11
AngliaGT Fuel Pump Problems Spridgets 2
B SU Fuel Pump Parts Austin Healey 8
B TR4/4A Mechanical fuel pump vs electric Triumph 16
P TR6 TR6 fuel pump question - glass bowl pump correct? Triumph 8
J TR4/4A Fuel pump saga Triumph 4
longbridgehealey Fuel pump racing, no gas Austin Healey 26
D General TR Fuel filter before the pump. Triumph 2
