Fuel tank straps
RestoreThemAll
Two questions about the straps for my BJ7.
1) The Moss catalog (21 in pic attached) shows a plate behind the mount that attaches to the boot wall. My mounts are fine but I don't have plates. What is the plate material? Steel? Cork?
2) One of the Ts on the strap is broken off. I was thinking about brazing a bolt on the end of it. Does that sound like a sensible fix?
R
RestoreThemAll
I see Steve. It goes to the back side. Makes sense. Is it about 1/8" thick?
R
RestoreThemAll
Perfect! Thank you very much.
Dale
ripvanwinkel
Hi,
There are two pieces of unknown material riveted to each fuel tank strap. Can anyone tell me this material is and are the rivets copper or steel?
grimes6
The material riveted to each strap is a thin strip of rubber. I am not quite sure of the rivet type but will check tomorrow and let you know.
Rob Glasgow
IIRC the original packing on the metal straps was more of a tan or brownish paper like material. Like a stiff cardboard. But semi water proof. And yes they were riveted but I don't know if they were copper or steel. At least on a BT7.
grimes6
The video may help on u tube [FONT=Verdana,Arial,Tahoma,Calibri,Geneva,sans-serif]https://www.youtube.com/watch?v=_8-leMY8Azo
I noticed in the comments section that one Healey owner had rubber strips under the straps the same as mine. Mine is a BJ7 so maybe they changed the material later. Just on my way to get the straps out of storage.
[/FONT]
grimes6
The rivets on my strap are copper bifurcated. I have taken some pics on my phone and will send them to you shortly. I am still not quite sure if the rubber strips are correct as the straps have shorter marks on them where something has been removed . The straps and the rubbers etc. are currently not together.
grimes6
Photos as promised. The rubber strips look professionally made but I couldn't be 100% that they are original . If you search for "fuel tank strap" on this forum you will find a previous post which discusses this item. The ruler is metric.
Healey Nut
When I did my BJ8s I used a leather belt that I cut then used those brass butterfly paper clip things where you spread the wings out on the back side .
***** NOTE I AM NOT A PURIST ***** so I have no idea and couldnt care less if its not “CORRECT”
Patrick67BJ8
I seem to recall that the material was about 1/16” thick and it reminded me of a gasket type of material.
catfood BN1 Fuel tank straps Austin Healey 5
PatGalvin TR2/3/3A Late model TR3 Fuel Tank Straps available to a nice home Triumph 0
M TR2/3/3A TR3 Fuel tank straps and pads Triumph 13
SherpaPilot TR6 Preping a New Fuel Tank Triumph 7
Frameman 1949 New Moss Motors Fuel Tank Austin Healey 10
Editor_Reid Fuel Tank Interchangeability Austin Healey 2
BoyRacer Fuel Tank Sending Unit Austin Healey 3
B TR6 Fuel tank replacement Triumph 0
JPSmit Fuel tank sender - how does it work? Spridgets 4
S Large capacity fuel tank Spridgets 1
MGTF1250Dave T-Series MG TF fuel line from tank to pump MG 3
JPSmit Fuel line - gas tank question Restoration & Tools 5
M TR2/3/3A Fuel Line Fitting at the Tank. Triumph 5
Ljohns New Midget/Sprite Fuel Tank Austin Healey Classifieds 1
Michael Oritt Fuel tank safety Austin Healey 18
BoyRacer Fuel tank sealing rubber is too thick Austin Healey 3
R Jensen-Healey Fuel Tank Questions Other British Cars 17
Martinld123 Fuel Tank Cap 100 BN2 Austin Healey 7
F Wanted 1960 Triumph TR3A fuel tank Triumph Classifieds 5
wkilleffer MGB Classic Gold fuel tank drain plug MG 12
SD Bugeye Half capacity of the fuel tank Spridgets 10
B TR2/3/3A Fuel Tank Venting Triumph 8
Zimmycobra For Sale Original 1966 TR4A Fuel Tank Triumph Classifieds 0
L T-Series TD Fuel Tank MG 2
NutmegCT Fuel tank cleaning/restoration Restoration & Tools 47
H Bugeye fuel tank sending unit - repair or replace Spridgets 5
sim fuel tank sender reading full all the time Spridgets 9
Basil E-Type fuel tank mounting bolts [$&^##$%*!!] Jaguar 16
J Bugye Fuel Tank Leak Austin Healey 4
Basil About to re-install my fuel tank Series I E-Type Jaguar 6
Popeye TR4/4A Found this odd long bolt in my fuel tank... Does anyone know what it is? Triumph 17
T Wanted Jaguar MK2 fuel tank and Radiator Jaguar Classifieds 8
T TR4/4A Fuel tank venting Triumph 1
L 100/6 BN4 Fuel Tank feed Austin Healey 5
Popeye Engine starving for fuel before tank is empty - 2001 Audi TT Other Cars 5
T TR2/3/3A Late Fuel Tank in Pre-TS60000 TR3A Triumph 3
Got_All_4 TR2/3/3A Has anyone tried to rewind/fix a fuel tank sending unit? Triumph 11
L Fuel Tank sender 100/6 Austin Healey 8
Got_All_4 TR2/3/3A Fitting the trunk floor pad & fuel tank cover Triumph 2
K TR4/4A Fuel tank options Triumph 4
O TR2/3/3A Fuel tank vent Triumph 1
Csarneson BN4 Longbridge Fuel Tank Austin Healey 15
E TR4/4A TR$ Fuel line from tank Triumph 13
rjc157 Fuel tank sender Austin Healey 13
S Hot tip: seal for fuel tank sender Austin Healey 9
B Fuel tank woes Austin Healey 4
TulsaFred Fuel Tank fitting and nipple Spridgets 6
catfood Fuel tank question Austin Healey 1
C Full tank but no fuel!!!!! Austin Healey 15
