General MG Spring and the smell of burning eclectics are in the air
Sopwith_Camel
I love how my home town of boston is dealing with snow and I'm BBQing .
well the Spridget is to be the main workhorse this summer. but I went out and try to start it . the battery sounded low and then smoke floated from under the dash. Ideas? its slated to get a new harness nest summer
the B the winter workhorse gets a new harness this summer but it is having "funny issues" the fan switch goes on in the off position un less you giggle the switch. the fuel gauge reads empty when if it was disconnected it would read full. and now all the marker lights are out. I would like to get another 2 months out of it before tear down. Ideas?
and the jag is starting to burn a hole in my budget for Repair panels but that will be ok and it gets a new harness this summer too.
its going to be a lot of quite days just wiring this summer. the chemo is still sapping my strength, so minumle driving.
steve
Mickey Richaud
Hi, Steve -
Sorry you're having health issues. I'm dealing with post-prostatectomy stuff myself. Not fun.
Anyway, no thoughts on your electrical issues, but hopefully you already have these wiring diagrams for the B; if not, they may be of help:
https://www.advanceautowire.com/mgb.pdf
:cheers:
Mickey
Sopwith_Camel
Sopwith_Camel
thanks ill print that out . i just scanned the Jag wiring diagram this morning.
the lights are back on I can't figure out why but the new harness will solve that. and i can't fine any burnt wires on the midget. thats a worry.
JPSmit
First off, sorry about the chemo - take care of yourself! In terms of the wire harness you clearly need an OEM spoke recovery kit!
https://www3.telus.net/bc_triumph_registry/smoke.htm
Seriously, when I had the harness out of the Midget I found a wire had melted and fused to the wire next it. It was replaced and all is fine - and I put relays in - but, two wires fused would account for your issues - as would a bad ground or two.
Sopwith_Camel
Sopwith_Camel
thanks, yes this i my third midget. everything looks ok I changed the wire to the started and it did start ok. I did pop the dash and went through what i could. I couldn't find any burnt wires on ignition system.
drooartz Spring service of the 4-door Sprite (Morris Minor) Spridgets 5
sim looking for 2 valve spring kippers for a 948 Spridgets 3
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
SpeedyG TR4/4A Door window regulator spring Triumph 5
mctriumph General TR Spring boot sale Umpteenth Annual Triumph 5
2 For Sale Dr. Doolin Spring Compressor for TR3 Triumph Classifieds 0
K TR2/3/3A Rear leaf spring brass and Delrin bushings ? Triumph 4
V MGB Thackery (double coil spring) Washer Substitute? What else works? MG 9
Tim Tucker TR4/4A Konig 16x7 wheels and leaf spring clearance for TR4 Triumph 5
Ed Foster T-Series MG-TD leaf rear leaf spring. MG 0
P MGB 1974 MGB front spring length. MG 0
F 59 bugeye spring bushing bolt Spridgets 8
Hamish Racing Another 3 sisters spring with commentary Racing 0
K TR2/3/3A Clutch slave "return spring"? Triumph 3
newmexTR3 TR2/3/3A TR3 Shock tower spring collar Triumph 7
jfarris TR2/3/3A First drive of spring - I hate electricity!!! Triumph 7
K TR2/3/3A Ignition timing questions while I'm waiting for Spring Triumph 27
B Poor quality BE replacement spring boxes Spridgets 0
B Any issue with cutting this weld on the spring base plates? Spridgets 4
AUSMHLY BJ8 Overdrive Accumulator Spring Tube Austin Healey 1
jfarris TR2/3/3A Relacing rear spring busings Triumph 3
J TR4/4A Seat install, Spring clip Triumph 0
F TR2/3/3A Leaf spring advice Triumph 16
K Missing spring clutch release lever Other British Classifieds 1
J TR6 1975 TR6 Alternator Advance/Retard spring(s) Triumph 1
T Heater Door Spring Austin Healey 1
R General TR Spring collar flange thickness options Triumph 2
Editor_Reid Unusual Leaf Spring Austin Healey 4
J Tips for quarter elliiptic spring install Spridgets 3
L Welding Bugeye Spring Base Plate?? Spridgets 1
R TR2/3/3A Throttle rod spring location Triumph 3
pkmh Front Spring Removal For BJ8 Austin Healey 8
R TR2/3/3A Carb throttle return spring tension Triumph 2
Got_All_4 TR5/TR250 Spring question Triumph 1
P TR6 Spring checkup Triumph 1
Merlin63Tr4 TR4/4A Triple to dual exhaust valve spring conversion done wrong? Triumph 7
K TR2/3/3A Auxillary Carb Return Spring in More BS about TR's. Triumph 0
66healey BJ8 shifter spring install Austin Healey 2
longbridgehealey Clutch return spring Austin Healey 7
A 1974 2500M Spring Rates TVR 6
Carlos TR4/4A Moss rear spring distance piece 674-560 Triumph 16
GeorgeC Rear spring disassembly - BN1 Austin Healey 1
tr6nitjulius General TR Triumph Club of So Cal Spring Drive 4/27/19 Triumph 0
Joe Schlosser Quarter Eliptic spring bushing Spridgets 6
dougie SOVERN's Pacifc NW Vintage Racing Spring Sprints Season Opener Racing 5
M For Sale Churchill 18G106 Valve Spring Compressor for Austin Healey 3000 Austin Healey Classifieds 0
Lotus Club SoCal LCoSC - Spring San Gabriel Mountains Drive Lotus 0
S TR2/3/3A Front coil spring recommendation? Triumph 7
K TR2/3/3A Auxillary carb return spring in "More BS about TR,s" Triumph 9
tr6nitjulius General TR Rites of Spring April 2018 video/pics Triumph 0
