Results 1 to 4 of 4
Thread: hood or bonnet whichever you prefer
Discuss the Austin Healey Sprite and the MG Midget. Two different but similar cars sometimes referred to collectively as the Spridget.
  1. #1
    Join Date
    Aug 2006
    Location
    Suffield,ct.
    Posts
    52
    Thanks Thanks Given
    Thanks Thanks Received
    Thanked in
    The last time I pulled my engine on my 66 sprite when I replaced the bonnet the back of it is about 3/4 of an inch lower than it was or should be. I've fiddled with it and concluded i have no idea how this happened or how to fix it. Any ideas?
    Thanks
  2. #2
    Join Date
    Apr 2006
    Location
    Santee, Ca
    Posts
    3,031
    Thanks Thanks Given
    Thanked in
    Re: hood or bonnet whichever you prefer
    On each hinge there are 4 bolts. Two that are "forward" and two that are "rear"
    If you put washers between the hinge and the hood on the "rear" holes you will raise the rear of the hood.
    If you put washers between the hinge and the hood on the "forward" holes you will lower the rear of the hood
    BillM
    '69 Sprite Mk IV
    '60 MGA
    '65 Midget
  3. #3
    Join Date
    Aug 2006
    Location
    Suffield,ct.
    Posts
    52
    Thanks Thanks Given
    Thanked in
    OK so I'm thinking there were probably two washers on the rear bolts and none on the front and then I put one on each bolt when I put it back together.
    Thanks
  4. #4
    Join Date
    Apr 2006
    Location
    Santee, Ca
    Posts
    3,031
    Thanks Thanks Given
    Thanked in
    It doesn't adjust the hood if the washers touch the bolt head, the washers MUST go BETWEEN the hinge and the hood.
    Bill
    '69 Sprite Mk IV
    '60 MGA
    '65 Midget
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
