What is the rustiest, most run down Healey you have ever seen?
BigGreen
Another one on eBay
BigGreen
And an even worse one also on eBay
L
Lambdaman
The rust in these cars can be put down to 2 factors, poor design and salt roads. Here in Sunny dry Australia we never saw our Healey's get to the stage of the worse ones shown here caused by salt on the road in North American Winters.
Rust in our cars has been limited to mud traps in the rear dog legs, bottom of front guards, sills etc, floors from wet carpets and finally the frame rusting from the inside out due to trapped moisture.
What measures do owners take now in North America during winter to prevent this rust reoccurring? Obvious the main one is not to drive them in Winter now they are a collector car and no longer a every day car
Chris_Masucci
Lambdaman, all I can tell you is what I did so this doesn't happen to my car again. I coated the entire chassis/bulkhead structure with POR-15 after sandblasting, and used their tie-coat primer under 3 coats of hardened Healey Blue enamel. The inside of the frame rails have also been coated as have the insides of outriggers and sills. Then I also used the Eastwood internal frame spray coating for the places that I couldn't reach, and finally coated the entire underside of everything with Waxoyl.
bighealeysource
Bronze
or keep 'em in a "car cave" that's got carpet tiles to sit on, dehumidifier for humidity and heat and air to attempt to keep the tin worm at bay !!! And this is nothing that fancy, just an 8 x 15 space built out under my house ( we're on pilings on the coast of South Carolina) where the Healey just fits. The air and heat is simply tapping into the duct work for the first floor half bath as only used by company and that heat or cooling is not missed in an empty bathroom !!! Plus like many, avoid driving it if you know weather is going to be bad as don't want to get these LBC's wet ! Or maybe it's the drivers who want to avoid getting wet !
Chuck9482912
Member
091207 BJ7 Inventory Documentation 148.jpgI like this picture of my BJ7 frame showing that the weld is the only thing left that hasn't rusted out on the bottom of the frame rail. Needless to say I bought this car knowing I would put a Kilmartin frame underneath it.
judow
Darth Vader - R.I.P
Not rusty but in boxes - my Agatha before restoration. Restorer suggested it would be a good parts car and did we really want to do this. Yes I said adamantly. Agatha and I are now living the high life.
L
Lambdaman
New entrant, bit of work needed on the door gaps!!!
HealeyRick
RAC68
Years ago, I had a good friend Ed who loved to acquire Healeys. Though I would have described most of his purchases as remnants at best, it was not uncommon for him to brag about the large number of Healey’s owned and I truly felt he valued even the least of his flock.
On one trip I accompanied him on, we picked up a 100-6 located in the middle of a muddy field. Questioning the sense of this purchase, he turned to me with a smile and a quip about the farmer using the wrong fertilizer. We dug the multi-part body and running gear out of the mud which turned out to be easier then originally though. Not surprising, everything from the bottom quarter of the door down had joined the field although the engine and trans survived as a multicolor display or not-so-careful handling.
Undeterred, Ed rapped the remaining body and running gear with the very strong plastic bands used by telephone line men when replacing a pole, and slowly pulled it onto his trailer. Driving home, I again questioned what he was going to do with this block of rust (sorry, but I saw little good in any of its parts) and he replied “Oh, it will contribute”.
Years later, I had to admit Ed’s insight. After retiring, he built his own Healey tri-carb using Original Healey Parts from the many cars he had salvaged and stored over the years. He had a love for the marquee, a dream in his hart, and a vision I just could not see.
Ray (64BJ8P1)
drambuie
On a different thread I was recalling a Rusted out hulk of a Healey I seen on eBay roughly 11 years ago, it was literally a Pile of rust Laying out in a open field in one of the southern states. Nothing was hardly left of it, no floors, dash, outriggers, frame...nothing! The only thing left was the engine block,rear end and some suspension bits. Anyway, it was absolutely skull cracking to watch the bidding wars begin at the very START of the auction! In fact it got so out of hand the owner felt so guilty he had to jump in and remind all the crazy bidders to take it easy! I'm not kidding. If I remember correctly it sold to a guy in Australia for around 35k. And just think about the shipping cost from America to Australia and you have a very grim picture indeed.
drambuie
. WOW...that baby should outlast the future production year 5000 car models! :smile:
JPSmit Tonight's ice cream run Spotted 3
shadowfever Shake down run Spridgets 2
L MGB 1977 MGB will only run on full choke MG 53
S TR2/3/3A problems getting the engine to run correct Triumph 21
F Spitfire Triumph Spitfire , what fuel to run Her on with no engine history? Triumph 11
P Carb Help - Car idle slows and dies after being run for a while Austin Healey 14
S TR6 Anti Run-On Valve question. Triumph 4
A MGB-GT Video- Three minute run through Smugglers Notch in Vermont. MG 4
A Spitfire Video- Three minute run through Smugglers Notch in Vermont. Triumph 4
D Spitfire 20-50 oil says run in car manuel Triumph 6
DrEntropy MGB Shakedown run MG 6
D TR2/3/3A Fuel line run from pump to carbs Triumph 5
S My 68 sprite hit and run Spridgets 10
N Spitfire Just picked up this 73 Spitfire. Hasn't run in ten years. Where do I begin? Triumph 10
steveg Anti-run on solution Austin Healey 10
D Been waiting for a hot day run Austin Healey 4
B MGB New Dual SU's and Run-On MG 3
BN6_2197 Correct run of the Choke Cable of BN6 Austin Healey 7
Marvin Gruber TR4/4A Almost a burnt run Triumph 12
PeterK Spitfire OK then but will it run Triumph 6
Sopwith_Camel 95 xj r cheap should i run away screaming? Jaguar 2
RickB MGB Taking a run north this weekend, Bellingham & Blaine MG 4
P TR6 Won't start after 10-mile run Triumph 21
gbtr6 TR6 Getting frustrated getting my TR to run properly Triumph 17
1 TR6 Tr6 needs choke to run good Triumph 11
H Rad bulkhead plates production run? Austin Healey 8
M_Pied_Lourd TR4/4A TR4 fuel line run. Triumph 5
L BJ-8 Engine run-on Austin Healey 21
RichBall Parts Run Spridgets 3
John_Mc General TR The secret to a 12 Parsec Kessel Run Triumph 1
T TR2/3/3A Can I run engine in car with no transmission? Triumph 7
J Found an E Type in a Barn. Bought it. Let's Make it Run Jaguar 15
J TR4/4A Making a '65 TR4 Run Awesome. Misfire, Ignition Tune Up, Carb Rebuilds. Help? Triumph 70
D LSR test run Racing 2
KVH TR4/4A Pre Ignition Run On Triumph 2
bighealeysource TR6 TR6 will not start back up after being run for a while and engine warm Triumph 15
angelfj1 General TR last run with the lady Triumph 19
S TR2/3/3A Ignition Run-On Triumph 5
D TR6 Anti run-on valve Triumph 3
Gliderman8 TR6 Starter energizes when in RUN Position...... Triumph 17
Keith_M Breakfast run Austin Healey 3
R reason for it said 1500 has cooling [run to hot] problems? Spridgets 20
B Strombergs Run Rich Triumph 12
NutmegCT TR2/3/3A low idle after a fast run - TR3 Triumph 4
Tinkerman TR2/3/3A TR 3A engine run in specs. Triumph 4
Tinkerman TR2/3/3A 60 TR3A Will not run above idle speed, help! Triumph 11
J TR4/4A TR4 won't run correctly Triumph 13
G Run on DIeseling RESOLVED Triumph 7
M TR4/4A 67 TR4A hasn't run for 10 yrs+... suggestions? Triumph 11
B TR2/3/3A Rad installed = TR3A no run Triumph 8
