What if the wrench doesn't quite fit?
dcoplan
Member
I'm about to bleed my brakes and was testing the fitting of my wrenches to the bleed nipples. I have both metric and SAE but both of them have just enough play to make me nervous about rounding the edges if they're in there too tight.
Tricks? Tips?
Dan
PS - Has anyone else noticed that the nut size is different on the front and back or should I just consider myself "lucky"? Strange.
smaceng
Due to modern machinery, some of the bleed screws are 10 mm, and some are like the original of 3/8". Use the appropriate wrench!
G
Basic rule pf thumb, if the bleeders round or break then the cylinder is old enough to need replacment anyway. At least that's how I look at it.
PAUL161
I always use a six sided socket to initially break them loose, then use a box wrench to bleed. PJ
aeronca65t
What Paul said: use a six-point socket or box wrench to do the initial loosening.
dklawson
I recently was informed about an additional step you can take to prevent stubborn bleed nipples from breaking quite so easily. Take your set of drill bits and find one whose shank is the closest fit that will just barely go down the hole in the center of the nipple. Insert the shank of the bit, then use your wrench to loosen the nipple. Having the drill shank fill the hole is supposed to prevent the nipple from collapsing on itself and is therefore supposed to reduce your chances of shearing the nipple off.
drooartz
Is it bad that I saw this thread title, and my first thought was "vice grips"?
Just wondering :devilgrin:
dklawson
Yeah, that's bad. I was never so upset with myself as the day I broke a bleed nipple off in a caliper... and I was using a tiny box end wrench too!
nomad
So,Doug, did you end up salvaging it or have to scrap it.
Kurt.
Bob Claffie
Once in a great while you can coax a stubborn bleeder to come loose by gently trying to TIGHTEN it. Not looking for a quarter turn or anything like that but any movement at all will signal that it's ready to back out. Bob
dklawson
Kurt.
I was able to save the caliper. The "HELP" section of the local Advance Auto had the bleed nipple repair kit. You take the caliper off, drill out the port for the broken nipple, tap 1/8 NPT and install the replacement nipple/bushing assembly. It was on the car years later when I sold it. The only downside to the kit was that their installation torque seemed to be "too high" and of course you had to already own a 1/8 pipe tap. Of course, I always needed a different sized wrench for that bleed nipple.
I used the kit after breaking the nipple and trying to drill out and re-tap the port. The replacement nipple never seated right... I did something wrong cutting the threads (too large, not concentric, angled... who knows). Later I learned about another fix that works even if the female threads are screwed up a bit. Buy a new bleed nipple and grind the pointed tip off so it is flat faced and shorter. Drop a single "ball" from a ball bearing down into the bleed hole in the caliper and install the flat faced nipple behind it. The modified nipple will drive the ball down into the tapered seat and always be on center to seal as well (if not better) than the original pointed tip nipple. Think of it a "Grose Jet" for your brake caliper.
BTW, I was trying the tighten/loosen method Bob described when this particular nipple broke. I was very upset when it happened because normally the tighten/loosen method had worked for me.
petnatcar Knock-Off Wrench - The New and Improved Version Austin Healey 12
K TR2/3/3A Does this fitting need a Whitworth wrench? Triumph 10
K For Sale Rare TR3 Folding Lug Wrench Triumph Classifieds 1
steveg Advice wanted on HF impact wrench purchase Austin Healey 12
TomMull Harbor Freight "Earthquake" impact wrench Restoration & Tools 10
S TR2/3/3A original tr3 hood wrench Triumph 15
TomMull cordlesss impact wrench, pricey but... Restoration & Tools 4
T Thinking of building an adaptor to allow a torque wrench to tighten the knock-ons Austin Healey 32
histerical What's with this wrench ? Spridgets 2
Jim_Gruber Did I find another need for a Whitworth Wrench Set/ Did I screw up intake manifold Spridgets 5
W TR4/4A Wrench? Triumph 2
C A great substitute for a "Not Quite 3/4 Inch" hex wrench Austin Healey 9
NutmegCT General Tech SU carb wrench - free! Triumph 1
TomMull Torque wrench Restoration & Tools 16
T Impact wrench question Triumph 12
D torque wrench Spridgets 21
pkmh Spinner Wrench - A New Color 'Twist' In Design Austin Healey 9
Westfield_XI Help, I need a knock off wrench Spridgets 17
tahoe healey flea market wrench Austin Healey 9
drooartz MGB Wrench for MGB diff fill plug MG 5
richberman Rear axle nut wrench for rent anyone? Austin Healey 26
CinneaghTR Oil Filter Wrench? Restoration & Tools 20
toysrrus "FOR SALE": KING DICK JACK, WRENCH & STORAGE BAG: Spridgets 11
T Torque wrench question Triumph 17
weewillie electric impact wrench Restoration & Tools 18
Jim_Gruber Wheel Bearing Grease/ Impact wrench on hubs Spridgets 11
I Torque wrench calibration Triumph 21
I trailing arm torque, torque wrench questions Triumph 28
DeltaAir423 Anyone have a pinion flange wrench? Restoration & Tools 7
davidk Jack and lug wrench locations Triumph 8
Jim_Gruber Impact Wrench and Air Hose Size Spridgets 6
jjbunn New Tool - ratcheting wrench Triumph 14
RickB Are most of us optimistic wrench jockeys? Spridgets 22
B Cylinder head nut spanner [wrench?] Austin Healey 1
J Use of an electric impact wrench, little off topic Triumph 10
L Another Wrench Restoration & Tools 0
Banjo got a new wrench Restoration & Tools 11
L New Ratchet Wrench Restoration & Tools 23
J Big wrench, two locknuts...[tierod/gaiter revisit] MG 4
B Day One with wrench and BN1 Austin Healey 1
Bret Torque Wrench questions? Restoration & Tools 7
Mwalsh What would you do [big wrench question] Restoration & Tools 4
Guinn Brake wrench MG 7
T Son of Torque Wrench Restoration & Tools 2
tahoe healey wire spoke wrench Austin Healey 1
V What kind of torque wrench? Restoration & Tools 6
Obtong Strap Filter Wrench MG 8
Basil Looking for GOOD Torque wrench Restoration & Tools 52
coldplugs Torque wrench [Where are we headed?] Restoration & Tools 12
Martinld123 Emergency Brake Doesn't Release Austin Healey 9
