Bret
Ok not directly related to LBCs but I do have a tool question for a work project I am investigating right now.
Specifically "torque wrench calculations” when using extensions and/or adapters, will they affect the selected torque settings?
Here is what I am dealing with – we are getting some failures of a slip torque limiter that is required to protect a boom from collisions and over extentions. Rather than breaking something under those conditions it is intended to slip. Problem is when it slips it should be easy to release the bolts and realign the boom and then torque the bolts again. However what is happening is it is seizing up and making resetting a real pain. I suspect one of the following conditions is the root cause – the bolts have been over-torqued one too many times (i.e. stretched) and need replacement. Or they are not being “evenly” torqued by the operators and techs.
The procedure requires a setting of 40lbs on 9 bolts. Using a mechanical (“click type”) torque wrench with a 1/2” drive with a 3/8” adapter and a socket. However sometimes other things get in the way during the procedure and require a 4” or a 6” extension to reach the heads of the bolts.
I realize that extensions do have some affect, but I ain’t that sure how much or how to calculate it. Moreover at 40lbs I’m not even sure it really matters.
Oh & before someone asks the wrenchs are calibrated regulary and the cal reports indicate all came in well within specs.
Thoughts?
Thoughts?
