TR2/3/3A Hi Torque Starter Repair
M_Pied_Lourd
Hi guys,
I suspect my hi torque starter that is installed on my 60 TR3A is toast ....thought it might be the solenoide but it checks out.
So, the question is, once I get the thing un installed (not looking forward to it), are these starters rebuild able? I have a couple of local shops I could take it to, but I thought I would ask if anyone here might have previous experience before I bother. Or, should I just go ahead and bite the bullet and order one from British Starters...
Cheers
Tush
martx-5
Having been in the electrical rebuilding business for about 30 years before I retired, if the high torque starter is similar to the ones that British Starters provides...e.g. the typical Nippondenso type, then they most definitely can be rebuilt by any local shop. The only real difference between a typical Honda and a British Starter gear reduction type is the mounting adapter plate. All the guts inside are the same. Even the drive gears used by British Starters are ones that come from common Nippondenso starters.
M_Pied_Lourd
M_Pied_Lourd
Thanks Art,
That is promising! I will try and get the old one off tomorrow and drop it at a local shop. I believe the PO also had another crapped out one in a parts bin that he gave me so maybe I'll look at having that one repaired as well.
Cheers
Tush
mgedit
Hi Tush. Read that some people have had those high torque starters come apart during service, although no personal experience. Might be good to loctite the through bolts that hold it together. Cheers, Mike
M_Pied_Lourd
M_Pied_Lourd
Thanks Mike,
Will do.
Cheers
Tush
TR3driver
Great Pumpkin - R.I.P
Might be worth having a look inside yourself. With mine, just the ball bearings had failed and I was able to source replacements from MMC for just a few dollars. Lots cheaper than having a shop rebuild it. It's not rocket science (but don't lose the ball that transmits motion to the pinion gear :smile: )
M_Pied_Lourd
M_Pied_Lourd
Well, I did manage to get the starter out...getting it back in will be "fun" to say the least. I didn't bother attempting to take it apart myself...no idea as to the actual make of the starter...I wouldn't even know what or where to order parts from...simpler in this case to throw money at the problem :cool: although I normally like to do it myself. I took two in (had another one kicking around in a parts bin)...$145 to repair both, back on Wednesday...
Cheers
Tush
mgedit
Sounds reasonable price for both, and always nice to have a spare. Did you helicoil those places on bellhousing or are you doing the contortion to get at the nuts? Cheers, Mike
M_Pied_Lourd
M_Pied_Lourd
I'm wishing I helicoiled or welded a nut on the back...I'm doing the contortion thing:cool: video to follow....
Cheers
Tush
M_Pied_Lourd
M_Pied_Lourd
My understanding was that the front nose/adapter was he only thing that was TR specific, no?
Hi Tom, I know that there were two types of starters fitted to TR3s depending on year/comm number. I think it would be a different hi torque starter for each application.
Cheers
Tush
poolboy
Cheers
Tush
And I think the starter's pinion had to have the correct number of teeth for the application. I seem to remember the one for the TR6 has 11....or maybe it's 9.
martx-5
Cheers
Tush
Yes, there are two different starters as shown on the British Starters website. TS50001 was the change over. There's a different gear on the starter due to the change in the flywheel when Triumph changed the starter.
https://www.britishstarters.com/Triumph.html
TR3driver
But the gear is the only difference; unlike the originals where the entire motor was different.
FWIW a friend of mine got the wrong starter the first time, and the shop where he bought it just swapped the gear for him, no charge. It's easy to get the wrong one, since the flywheels interchange so easily (eg TS13571L is wearing a later ring gear & gear drive starter to match).
P TR2/3/3A British High Torque starter Triumph 6
M High-Torque Starter Austin Healey 10
Martinld123 High-Torque Starter Austin Healey 4
B TR4/4A High Torque Starter Wiring Triumph 9
B High-Torque Starter Rattling Noise Austin Healey 3
M TR2/3/3A Has anyone put in a Hi Torque Starter from Moss? Triumph 21
B High Torque Starter Spridgets 7
B TR6 Hi Torque starter wiring - '76 TR6 Triumph 3
T High Torque Starter Triumph 9
K TR2/3/3A TR3 starter dog bolt torque value? Triumph 1
R New High Torque Starter Issues Triumph 5
B High Torque Starter Broken mount Austin Healey 1
tinman58 TR2/3/3A Hi torque starter TR3 Triumph 2
E Bugey Starter Switch with High Torque Starter Spridgets 3
bill_powell High Torque Starter & Datsun 5-Speed Spridgets 3
Bruce_B Hi-Torque Starter Question Spridgets 5
T TR6 Best source for a TR6 high torque starter? Triumph 12
Bruce_B Question on hi-torque starter & Rivergate Spridgets 9
N high torque starter??? Spridgets 11
R High Torque Starter Austin Healey 2
Carlbanan56 MGB Rear axel torque? MG 4
C Steering Arm Castle Nut Torque Austin Healey 5
B Head Re-Torque Austin Healey 8
Joel Lester TR2/3/3A What final front suspension torque settings needed? Triumph 7
W TR2/3/3A Differential cover torque Triumph 4
D TR2/3/3A Torque for bolts back of transmission ? Pl Triumph 0
AUSMHLY BJ8 Cylinder Head Re-Torque Austin Healey 26
D 1.8 2007 Toyota Avensis Clutch & Flywheel Torque Settings? Other Cars 0
Lin Oil sump torque value? Spridgets 3
Lin Water Pump torque value for nuts on studs Austin Healey 1
Lin Gear Reduction High-Torque Starters: Inertia or Pre-engaged? Austin Healey 4
D Torque Sticks Restoration & Tools 6
J TR2/3/3A Head Torque - Wet or Dry Triumph 6
BJ8Healeys Torque on Midget rear wheel hub nut Spridgets 7
K TR2/3/3A Front brake caliper mounting torque? Triumph 1
S Fan blade bolts - torque setting and thread-locker? Austin Healey 4
R Our J-H plan - torque specs needed! Other British Cars 2
S Locknut - rear wire wheel - torque spec? Austin Healey 15
S TR2/3/3A Torque specification on large pitman arm nut Triumph 1
Michael Oritt Torque values needed for 100 Austin Healey 5
R General Tech Crank bearing cap broke...Torque?? Triumph 37
Michael Oritt Torque Setting needed Austin Healey 10
M Replacing front shocks, torque setting? Spridgets 2
G Torque for Front Pinion Nut Austin Healey 3
D torque values Austin Healey 2
K TR4/4A TR4A clutch pressure plate to flywheel bolt "torque value"? Triumph 2
Jim_Stevens TR2/3/3A Axle to leaf spring torque Triumph 2
T Thinking of building an adaptor to allow a torque wrench to tighten the knock-ons Austin Healey 32
69MGC MGC Rear Diff Cover Bolts Torque? MG 5
G TR4/4A ARP Bolt Torque Specs Triumph 10
