Torque Sticks
  • Thread starter Deleted member 8987
  • Start date
Deleted member 8987
I did professional auto repair and diagnosis for probably 40 years according to she who keeps track of that stuff.
About 20 years ago, the clueless individual ran the stop sign, and my career was over.
Saturday I helped at a Church sponsored car care Saturday, and saw Torque Sticks for the first time.
When were these invented, when did they come into use? I can imagine Snap-On with their new stuff to wow the folks in the trenches having them first.
Interweb reading seems to indicate they work well for some things.
TR3driver
Great Pumpkin - R.I.P
Been around for at least 30 years that I know of. Accuracy is pretty low though, from what I understand. They need to be matched to the impact gun; but impact guns get weaker as they age, etc. And if you pick up a gun with a bigger hammer inside (or longer lever arm), it will put more torque through the stick than it's rating.
Don't recall where or who offhand, but I'm pretty sure I've seen a note from a major car maker saying a torque wrench is required to tighten lug nuts.
Deleted member 8987
20 years ago nobody around here had heard of them.
Strange.
LarryK
Thought about buying a set when I worked for a shop. Matco driver showed me a set, wound up buying a full Snap-On torque wrench set, which I still use today. As TR3driver says, impact guns are accurate for a while and/if you use same exact air pressure each time.
Deleted member 8987
You read up on them, everybody has a different idea as to how they work. Makes your head hurt.
Within 20% of marked value, maybe.
Worth the effort? Nah.
DavidApp
Are they a little better than the Tire shop guy just setting the impact gun to "$" and calling it good.
I always try to take my wheel to the shop if I need tire work and torque it myself at home with a proper wrench. Have thought of taking the wrench with me and re torquing the nuts on the tire shop forecourt if I have more than one wheel done.
One thing I have noticed is that my front brake rotors never warp.
David
LarryK
I have watched the tire guys just zap them with impact. At my one store I would torque them before I left and it irritated the manager. I would hold up two fingers and give a thumbs down. Watched an alignment thru the waiting room window as the tech used vice grips to adjust toe-in. Had a pissy fit right there and he had to borrow a wrench. Still had to realign when I got home. 3 degs off. Never have gone back. My shop now is two blocks away and gave me the torque specs and offered wrench to check.
Carlbanan56 MGB Rear axel torque? MG 4
C Steering Arm Castle Nut Torque Austin Healey 5
P TR2/3/3A British High Torque starter Triumph 6
B Head Re-Torque Austin Healey 8
Joel Lester TR2/3/3A What final front suspension torque settings needed? Triumph 7
W TR2/3/3A Differential cover torque Triumph 4
D TR2/3/3A Torque for bolts back of transmission ? Pl Triumph 0
M High-Torque Starter Austin Healey 10
AUSMHLY BJ8 Cylinder Head Re-Torque Austin Healey 26
Martinld123 High-Torque Starter Austin Healey 4
B TR4/4A High Torque Starter Wiring Triumph 9
B High-Torque Starter Rattling Noise Austin Healey 3
D 1.8 2007 Toyota Avensis Clutch & Flywheel Torque Settings? Other Cars 0
Lin Oil sump torque value? Spridgets 3
Lin Water Pump torque value for nuts on studs Austin Healey 1
Lin Gear Reduction High-Torque Starters: Inertia or Pre-engaged? Austin Healey 4
J TR2/3/3A Head Torque - Wet or Dry Triumph 6
BJ8Healeys Torque on Midget rear wheel hub nut Spridgets 7
K TR2/3/3A Front brake caliper mounting torque? Triumph 1
S Fan blade bolts - torque setting and thread-locker? Austin Healey 4
R Our J-H plan - torque specs needed! Other British Cars 2
S Locknut - rear wire wheel - torque spec? Austin Healey 15
S TR2/3/3A Torque specification on large pitman arm nut Triumph 1
Michael Oritt Torque values needed for 100 Austin Healey 5
R General Tech Crank bearing cap broke...Torque?? Triumph 37
Michael Oritt Torque Setting needed Austin Healey 10
M Replacing front shocks, torque setting? Spridgets 2
G Torque for Front Pinion Nut Austin Healey 3
D torque values Austin Healey 2
K TR4/4A TR4A clutch pressure plate to flywheel bolt "torque value"? Triumph 2
Jim_Stevens TR2/3/3A Axle to leaf spring torque Triumph 2
T Thinking of building an adaptor to allow a torque wrench to tighten the knock-ons Austin Healey 32
69MGC MGC Rear Diff Cover Bolts Torque? MG 5
G TR4/4A ARP Bolt Torque Specs Triumph 10
K TR2/3/3A Steering box drop arm Nut torque value? Triumph 0
K TR2/3/3A Steering box rocker shaft Nut torque value? Triumph 4
tr3guy TR2/3/3A TR3 Fan Bolt Torque Triumph 3
Popeye TR4/4A Rear leaf spring bolt torque Triumph 11
M_Pied_Lourd TR2/3/3A Hi Torque Starter Repair Triumph 14
S Torque setting for U-Bolt nuts Austin Healey 12
M TR2/3/3A Has anyone put in a Hi Torque Starter from Moss? Triumph 21
Jim_Gruber Question on 948 Head Torque Specs - Before I break something please Spridgets 3
S Torque Range? Austin Healey 13
KVH General TR That Front Fan Dog Bolt Again--Torque It Triumph 7
K TR4/4A Gearbox front cover[Moss 848-000] torque spec? Triumph 1
Griz Manifold nut torque Austin Healey 11
B re-torque heads? Austin Healey 5
J Need dimensions for BJ8 PII radius [torque] box carpet flaps. Austin Healey 1
K TR2/3/3A Oil Pan bolt torque spec? Triumph 2
M TR4/4A TR4A - Torque the Front Suspension Trunnion Bolt! Triumph 5
