Welded nuts for Bugeye seat frames
drooartz
Penny is missing the welded nuts for the seat frames, and while were fixing the other body issues I'd like to reinstall them. 1/4" 28 (fine) nuts, correct?
apbos
Seat runner to the floor is 1/4" 28. Hint: Moss UK lists the size in its listings.
Paul
drooartz
drooartz
Thanks for the confirmation and the tip on Moss UK.
Got_All_4 TR6 Seal To Body Mounting Bracket Welded? Triumph 7
AUSMHLY Remanufactured Laygear with welded 1st gear Austin Healey 20
Jim_Gruber Coolant Bypass Nipple on 948 Welded Closed - Advice needed Spridgets 7
S TR2/3/3A body tub welded Triumph 2
S TR2/3/3A battery box welded Triumph 4
M Bugeye Bumper Brackets Welded! Spridgets 8
Michael Oritt Epoxy-welded diff Racing 6
K TR2/3/3A TR3 Lower Bump Rubber Bolt Frozen Like its Welded Triumph 5
A TR2/3/3A TR3/4 head crack, can it be welded Triumph 11
R Never welded before - how hard is a sill job? MG 10
tr6web TR6 Need advice removing downpipe nuts Triumph 2
petnatcar Cylinder Head Nuts - Tightening Sequence Austin Healey 2
Scotsman TR4/4A Chimney nuts, where do they go Triumph 5
S TR2/3/3A ÂĽ fine square nuts Triumph 7
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
shadowfever Midget seat nuts and bolts Spridgets 2
A BN7 Front Hub Stud Nuts Austin Healey 5
T Storing nuts and bolts (so you can find what you need) Austin Healey 7
Z Lug nuts for Minitor rims Spridgets 1
HighAltitudeTR3 T-Series Why are there nuts in my core plugs?! MG 8
D Rear Brake Drum Nuts Austin Healey 15
Lin Water Pump torque value for nuts on studs Austin Healey 1
steveg TR6 Loose wheel nuts after torquing Triumph 2
D TR2/3/3A Wing nuts for gauge panel on TR 3 Triumph 10
K TR2/3/3A Coil nuts? The SW and CB nuts on a Moss gold coil? Triumph 3
J TR2/3/3A caged nuts problems Triumph 12
T TR2/3/3A Can someone confirm size and thread count on fuel line tube nuts [brass fittings]? Triumph 16
Rob Glasgow Rear Hub Nuts Austin Healey 11
D TR2/3/3A More small nuts [ and studs!] Triumph 2
healeyblue Longbridge side screen star shaped nuts Austin Healey 15
AUSMHLY BJ8 Manifold, how many brass nuts? Austin Healey 2
banjojambo TR2/3/3A TR3A Re-torquing Head Nuts Triumph 7
T TR2/3/3A Is there any problem in putting TR6 plastic wheel covers & TR6 lug nuts on TR3 wheels Triumph 4
Lin Rear Axle Hub Nuts Austin Healey 3
R TR2/3/3A 1961 TR3A's Nuts, Bolts and Screws Triumph 5
C MGB How do you remove "speed nuts"? MG 9
Bob_Spidell Re-torquing Head Nuts Austin Healey 4
D TR2/3/3A Cage nuts, attachment Triumph 6
JimLaney Whitworth Threads or Just Nuts! Spridgets 5
maxwedge5281 healey road wheel lug nuts Austin Healey 7
NutmegCT Loosen those nuts! Restoration & Tools 5
W TR2/3/3A Why a PO cut these holes in rear floor? Also, question re dealing with captive nuts Triumph 6
S Torque setting for U-Bolt nuts Austin Healey 12
KVH General TR What Happened to My Leaf Spring's Nyloc Nuts? Take a Look . . . Triumph 17
S TR2/3/3A caged nuts on the fenders Triumph 9
F J hooks an wing nuts for attaching hard top to body BT-7 - anyone got photos? Austin Healey 5
K TR2/3/3A The "brass wing nuts" rhat hold the instrument panel on...... Triumph 2
R Engine crank shaft nuts Austin Healey 1
jfarris TR2/3/3A TR3 gauge panel and nuts on gauges Triumph 5
