TulsaFred
I replaced the U-joint on my BE today, but ran into a problem. The grease fitting on the new U-joint runs into the yoke.
At first I thought I must have installed backwards, so I drifted it back out and turned it around. Still no go.
The zerk runs into the yoke and prevents the joint from rotating more that a about 5 degrees!
The U joint is from NAPA part number PUJ 341. It's the uprated part, USA made by Federal Mogul.
It looks like the angle that the zerk goes into the spider is incorrect causing it to interfere with the yoke. The original u joint on the other end of the driveshaft looks like the zerk is at a steeper angle.
Could I be missing something?
Fred
Fred
