bthompson
It always happens on those beautiful days when you just want to be <span style="font-style: italic">driving</span>...
Zipped over to the local Pep Boys for my half-year purchase of Castrol in various weights, in preparation to Drain That Which Is Drainable.
<span style="color: #996633"><span style="font-style: italic">(Just realized my Castrol gear oil is GL5, not GL4; but that's a gripe for another thread.)</span></span>
On the way home, I noticed that my tranny seemed to be rattling, when coming to a stop in neutral. It sounded like a ringing metallic coming from underneath the shifter. Having visions of layshaft bits floating in my oil, I zip on home, and before changing the oil, I jack up a rear wheel and give it a spin. <span style="font-style: italic">Clank, clank, clank...</span> I gave it a little wobble. (<span style="font-style: italic">clankclank.</span>) It didn't seem to be spinning the tranny when it clanked, like there was some slop in the line.
And sloppy drivelines mean u-joints.
I reached in and felt the rear one. Seemed solid; nothing rattling or clanking. I squeezed under further, and shoved my hand up the Hole-O-Grime in the tunnel. Yep. Just floatin' around in there. Has a cap disappeared? Have my needle bearings ground themselves into dust? Dunno, can't tell. But the two halves of the yoke seem to be only marginally acquainted with each other.
This <span style="font-style: italic">should </span>be a really easy job. Eight bolts and out. And If John Twist can do one in five minutes, I should be able to do one in about an hour. :wink:
Except I don't have a bench vise or a press. Anyone ever tried doing a u-joint with a C-clamp? What's the quick-and-dirty procedure for changing a u-joint with a BFH?
