glemon
I just got the six u-joints for my TR250 rear end, some questions, first they have a off clear to yellowish waxy grease on them, looks different than the grease (dark brownish red) I usually squirt from my grease gun, have read all greases are not compatible, can I use these as is or should I clean them out and re-grease.
Second, I have a clearance problem, with one sided on and fully in with the circlip the other side pushed in won't go far enough that I can get the circlip on, and it is in as far as it will go. Also one side drove in firmly as it should the other I could almost press in with my hand. I got these from a vendor I generally trust, but am questioning the quality of these parts. Off to work, will check replies at the end of the day, thanks,
Greg
Greg
