Driveshaft/u-joint questions
wkilleffer
Well, I'm finally getting around to changing the ujoints on my 74 MGB. The one by the rear axle failed this time last week while I was driving it.
It looks like the yoke one the prop shaft took a bit of a beating in all that, and may need to be replaced. It's possible that there might not be enough metal to hold the circlips in. Now, if that wasn't the case, would there be any other hazards to reusing the part? Would it throw the driveshaft off balance or anything like that?
Getting the parts and figuring this out has been a bit of a downer, and we're having to borrow a car. No hurry to return it yet, but I don't like having cars for long periods of time if they don't belong to me. Just one of the downsides to buying an MGB with sketchy maintenance history.
Thank you,
Dave Russell
Yoda - R.I.P
Just my personal opinion.
If any parts of the drive shaft, joints, yokes, look questionable, replace them now. The least that can happen is having to do it again. The worst is that the shaft can get loose, whip around, & do real damage to the car & it's occupants.
The only experience I have with a bad U-joint was with my Dad on the way to Alabama the beautiful from West by god Virginia.... He had replaced the engine in a late 70's Pinto Wagon. About halfway through the trip, around Kentucky and in the middle of nowhere in the middle of the night, The rear UJ bearings let go on the interstate. Well, I stayed with dad, and my mom and sisters rode on ahead to find an open parts store. They showed back up about an hour or so later with new parts. I remember my dad under the car with nothing but a scissors jack holding it up... and scrambling from under it 2 or 3 dozen times when 18-wheelers would go by at 70 mph - rocking the car on it's jack.
Last thing I remember about that car was sitting for hours a couple months later prying the studs from the snow tires it had on it as Alabama laws don't allow studded tires.
PAUL161
William, The one thing you don't want, is to have any vibration in the drive shaft. If the yoke is questionable, replace it! Tony, ( theautoist.com ), probably has some. /ubbthreads/images/graemlins/thumbsup.gif PJ
Platinum
If the yoke is booger'd up, replace the shaft. The U-joints are a Spicer part, easily acquired thru NAPA, or any of the domestic parts houses.
Next time you should pay closer attention to yer butt... that thing shoulda been talkin' to your posterior for a WHILE before it let go to the point you describe! /ubbthreads/images/graemlins/grin.gif
wkilleffer
wkilleffer
[ QUOTE ]
[/ QUOTE ]
Well, looking back on it, it was vibrating a bit. But I didn't have any idea that something like this was going to happen. Frankly, I would have thought the tranny was more likely to give out than a ujoint. I was almost hoping it was the gearbox so I'd have an excuse to get a 5-speed conversion from Chattanooga's own Rivergate 5-speed.
Platinum
"Glutton fer Punishment" huh? Good choice of gearboxes, too /ubbthreads/images/graemlins/wink.gif
"May as well" do it all at once, and ya get yer wish!
wkilleffer
wkilleffer
[ QUOTE ]
[/ QUOTE ]
Can't really afford it. It would have been something else to pay for. Maybe one day.
Keoke
[ QUOTE ]
Thank you,
[/ QUOTE ]
Generally speaking when a :U: joint fails under load while driving the yokes get trashed and must be replaced.Prolly a good Idea to souce a complete useable drive shaft. If the yoke was not damaged it could be properly reused with the installation of new Crosses. The one you have should not be reused.--Fwiw---Keoke- /ubbthreads/images/graemlins/nonono.gif
tony barnhill
Great Pumpkin - R.I.P
Got lots of shafts/yokes...but I would replace the whole shaft, not just the yoke!
Keoke
Yep Tony, that one is trashed , give him a good price on one---Keoke- /ubbthreads/images/graemlins/wink.gif
mjamgb
I tried and tried to replace a u-joint once... I learned I stank at it and always take them to a driveline shop. They are nearly always able to replace anything wonky, have the experience to tell if something can be reused and are able to balance the shaft for you!
tony barnhill
FEDEX has his driveshaft!
Naomi
William I agree with everyone else. When I first bought my 64 MGB it had aluminum bolts holding the drive shaft in place. Of course I didn't know it at the time. I was downtown (thank goodness not on the highway) when they snapped. No damage to the drive shaft but the rod under the car with the rubber boots that keep the fan from going into the radiator were also bad so I ended up with a chain reaction --- drive shaft breaks, MGB stops dead in the road, motor keeps moving and tears radiator up, radiator bends shroud, towing bill and lots of dollars in repair.
Make sure all is okay under there. Can you imagine what would have happened had I been on Interstate::(
Naomi (Owner of a 1964 MGB, a 1979 MGB, a 1980 MGB. Each repaired hundreds of times but still loved /ubbthreads/images/graemlins/smile.gif
PAUL161
Aluminum bolts holding the drive shaft??? That's one for the books! /ubbthreads/images/graemlins/rolleyes.gif PJ
wkilleffer
wkilleffer
[ QUOTE ]
[/ QUOTE ]
That's great news. Now, it needs to stop raining for a bit so I can actually to the work.
Banjo
I bought a 76 Lincoln Continental for $35 once, because the lady lost the rear u-joint going up the hill in front of our shop.
I got some good money for that 460. /ubbthreads/images/graemlins/devilgrin.gif
Keoke
[ QUOTE ]
[/ QUOTE ]
Don't loose a "U" joint in front of Banjo's shop!!---Keoke- /ubbthreads/images/graemlins/angel.gif
BritCarFan Removing driveshaft from offset sphere joint. British Motor Corp 2
AUSMHLY BJ8 Driveshaft Installation Austin Healey 10
AngliaGT MGB-GT '67 GT - Pulling Engine - Disconnect Driveshaft? MG 6
Y MGB First of probably many questions - driveshaft transplanting: MG 3
J 5 Speed Driveshaft Yoke Austin Healey 25
KVH TR4/4A Two Questions: Driveshaft and Brake Cylinder Fasteners Triumph 7
T TR4/4A Replacing rear pinion seal - remove driveshaft? Triumph 21
R 3000 Driveshaft Austin Healey 3
tr3guy TR2/3/3A TR3 Driveshaft Triumph 5
J TR4/4A Driveshaft repair Triumph 4
C Orientation of Driveshaft??? Austin Healey 2
T Spitfire Randall - anyone you would recommend for getting a driveshaft shorted in SoCal Triumph 4
C Spitfire Driveshaft Triumph 10
Scott_Hower Spitfire Late Spitfire 1500 CV driveshaft Triumph 3
D driveshaft question Triumph 4
D Driveshaft Woes... MG 6
M TR2/3/3A TR3 driveshaft question Triumph 5
M Driveshaft length Spridgets 6
M TR2/3/3A TR3 Driveshaft installation Triumph 4
drooartz Driveshaft install Spridgets 11
mgedit TR6 TR6 Driveshaft ... Cork Washer Triumph 7
dklawson Spitfire Spitfire Driveshaft - Which End Where? Triumph 8
N Spitfire Spit driveshaft ? Triumph 10
ronzet MGA Front driveshaft yolk cover - '58 MGA MG 10
Steve1970 driveshaft removal, here's an idea! Triumph 9
Atrus Bolt/Nut thread sizes leaf U-bolt & driveshaft Spridgets 4
jhorton3 Driveshaft Back In Spridgets 3
DNK My *8 driveshaft Triumph 16
Raymond driveshaft MG 10
timbn2 driveshaft question Austin Healey 9
eejay56 Driveshaft radial play Triumph 1
Twosheds Driveshaft Yoke Orientation Triumph 5
T Name this driveshaft? Triumph 44
R driveshaft tunnel seat belt eyebolt- BJ-7 Austin Healey 3
Team_Sprite HELP! Driveshaft / Gearbox Spridgets 19
J TR2/3/3A Grease fitting access on front driveshaft TR3A Triumph 3
Airfix TR6 TR6 Driveshaft inteference? Triumph 1
Wana How To Remove Driveshaft? Austin Healey 6
G Rear hub/driveshaft setup Triumph 7
G TR6 TR-6 Rear driveshaft/hub Latest Triumph 32
C Bugeye propeller/drive shaft- universal joint Spridgets 1
fpstude TR4/4A Steering U-Joint Question for TR4A Triumph 5
K TR2/3/3A Inner tie rod ball joint. Triumph 6
R TR2/3/3A Replace Upper Wishbone Ball Joint Triumph 4
R TR2/3/3A Replace Upper Wishbone Ball Joint Triumph 15
Griz Universal joint let go Austin Healey 15
Jim_Gruber Strange noises - Bad U Joint perhaps? Spridgets 10
Foura TR4/4A Universal joint diameter Triumph 9
D TR4/4A inner tie rod ball joint tension Triumph 0
TomMull TR2/3/3A Flooe panel to bulkhead joint detail Triumph 3
