TR2/3/3A TR3 Driveshaft installation
mapleaf
I'm installing the driveshaft that I removed last fall and now I can't remember which way the bolts go. My factory service manual seems to show them going in from the transmission and rear diff. directions but I can't get them to go in that way. So, before I tighten them down from the opposite direction I am wondering, is there is a correct way or does it matter, or could there be bolt clearance problems?
TIA
bgbassplyr
ISTR that the bolts go in from the universal side with the nuts being installed from the diff and tran side. There has to be an angle on the universal in order to get the bolt to go through the flange. In other words, install one bolt, rotate the shaft 1/4 turn and install the next bolt. Continue untill all bolts are installed and then tighten the nuts.
Done the other way, I think there is interference between the threaded end of the bolt ant the diff cross under extreme drive shaft angles such as axel against the bump stops or getting air under the rear tires.
If I'm wrong, someone will jump in and correct me, please.
TR3driver
Great Pumpkin - R.I.P
That's the way mine are, but only because they don't fit the other way (unless you put the bolts through the flange first and then install the flange).
FWIW, on my 3A I found that even new Nyloc nuts would back off sometimes, so I switched to these:
https://www.mcmaster.com/#92501a430/=2epo20
Probably means my driveshaft was out of balance or something, but I got tired of having to tighten them during lube jobs.
M
mapleaf
Thanks guys. I have new grade 8 nuts and bolts and want to put it together today but I will keep an eye on them and if they do work loose I will replace them as Randall suggested.
Barry
tr3guy TR2/3/3A TR3 Driveshaft Triumph 5
M TR2/3/3A TR3 driveshaft question Triumph 5
R TR2/3/3A TR3 Timminge Triumph 11
J For Sale Triumph TR2 TR3 rocker panels, right and left Triumph Classifieds 0
J For Sale Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 0
J For Sale TR2 TR3 Tie Member Triumph Classifieds 0
S TR2/3/3A tr3 valve spring compressor Triumph 5
jfarris For Sale TR3 Stock Fan used (1956) Triumph Classifieds 0
jfarris For Sale TR3 Speedometer SOLD Triumph Classifieds 3
S TR2/3/3A My tr3 was stuck in reverse after a short drive Triumph 3
