TR4/4A Two Questions: Driveshaft and Brake Cylinder Fasteners
KVH
Is there any reason I need to reverse my driveshaft if I have the slip joint forward toward the transmission? I can't tell, but one picture in the manual seems to show it the opposite way.
Second, my rear brake cylinder fastening kit had three clips per side, but I can only get two on--the two big ones. The one called "distance piece" doesn't seem to fit; it's too tight already. Is that unusual?
Thanks all.
TR3driver
Great Pumpkin - R.I.P
I don't see why it would make enough difference to worry about; but both the TR3 and Stag workshop manuals specify splines towards the front.
Most of the illustrations (actually all of them AFAIK) show the rear brake cylinder clips in the wrong order. But I find that if I follow the text instead of the drawing, they all go on easily.
Popeye
Bronze
If anyone tells you putting the clips on is "easy", take it with a grain of salt:smile:. It must be possible to be easy, because I find it either a 10 minute (5-minute?) job that goes together perfectly, or a case of swearing and sweating. I just wish I knew *why* the easy ones go easy! I buy extra clips when ordering parts, just in case. Interestingly enough, if I have extra clips, I seem not to bugger up the first set!
charleyf
Regarding the drive shaft -- the slip joint has been forward on both of my TR4's, just like the TR3's.
groupdeville
Placing the slip joint forward helps keep it away from water and grit, thus lengthening its life. It is also well known that British sports cars employ the self-lubricating chassis design, where engine oil is recycled onto the frame, drive line, and surrounding components. With this arrangement, the driveshaft splines receive lubrication even in the absence of regular greasing.
KVH
KVH
All great help. Just redid those brake clips. I’d be nowhere without this forum.
Y MGB First of probably many questions - driveshaft transplanting: MG 3
wkilleffer Driveshaft/u-joint questions MG 17
scottkilpatrick TR4/4A Knock off wire wheels procedure..basic questions Triumph 9
K General MG 1968 Midget Questions MG 1
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
W General Tech 2500S starter motor and fuse box questions Triumph 3
KVH General Tech More Engine Rebuild Questions Triumph 15
P MGB 1980 MGB carb and oil questions MG 3
C My 2500M progress/questions thread TVR 5
K TR2/3/3A Ignition timing questions while I'm waiting for Spring Triumph 27
K TR2/3/3A A couple of small distributor tech questions..... Triumph 10
B TR4/4A Dumb Bumper questions Triumph 4
B Two questions about Bugeye floor panel weld drilling Spridgets 15
C TR2/3/3A So many newbie questions any help is appreciated! Triumph 6
R TR6 Questions on emission tank-to-canister pipe Triumph 0
AngliaGT MGB-GT Couple of Dumb Questions - '67 GT MG 11
C TR2/3/3A Three completely different questions from a TR3B newbie - thanks for any input! Triumph 6
D TR2/3/3A More Fuel pump questions. Triumph 10
K TR2/3/3A Hard start questions.... Triumph 4
F TR2/3/3A back half to chassis questions Triumph 105
D Carpet Questions Austin Healey 2
J TR6 73 TR6 Static Timing Questions Triumph 6
glemon Spitfire Spitfire Questions Triumph 7
B TR4/4A General exhaust questions Triumph 17
J TR6 1973 TR6 Rear Brake Operation Questions Triumph 4
Pythias Springs and ride height... Questions. Spridgets 2
L TR2/3/3A Engine removal questions Triumph 8
I Brake rod questions Spridgets 7
J TR6 2 Brake Questions Triumph 3
WJKB-TR6 TR6 '73 Ignition [IGN] Red Light questions. Triumph 6
K TR2/3/3A Couple of choke questions Triumph 1
T TR2/3/3A Questions on TR3A steering control head refresh Triumph 34
T TR2/3/3A Questions on fuel pump installation Triumph 7
C Non-Adjustable steering column questions Austin Healey 14
I Bugeye electrical questions Spridgets 17
Bayless Master cylinders questions Spridgets 7
B Seat Slide Installation Questions Austin Healey 14
Rut TR4/4A Rear end questions Triumph 8
P TR2/3/3A Chassis paint questions Triumph 8
R Jensen-Healey Fuel Tank Questions Other British Cars 17
doc50 1958 Nash metro door questions... Other British Cars 6
P TR2/3/3A TR2 color questions Triumph 23
steveg Holley fuel regulator questions Austin Healey 17
R Dash Install questions Austin Healey 31
T Tri-carb questions. Austin Healey 10
KVH General TR Type A Laycock Overdrive Questions Triumph 8
P BJ7 Carpet Install Questions Austin Healey 29
Talon TR2/3/3A Throttle rod link to carburetor; basic questions Triumph 4
M Chrome wire wheel questions Spridgets 5
