Holley fuel regulator questions
steveg
I've had one of these on the shelf for 10 years. I reinstalled it and it doesn't appear to work. Changing the adjustment doesn't change the pressure gauge at all. It stays at this high figure.
Do I need a rebuild kit - or a new regulator? Can anyone offer experience-based advice on what's happening here?
However, it does need to be able to bleed off, so loosen the gauge from the body, to simulate flow. Even though you backed it off, the max pressure has nowhere to go.
Michael Oritt
Steve--
If you are using an SU fuel pump you really do not need any fuel pressure regulator as the output of 2-4 psi's matches up to the carburettors' min/max requirements
I have one of these--matched up to a Holly Blue (higher pressure) fuel pump--on my Elva Courier only because I was experiencing fuel starvation at WOT and when coming out of tight right-handed turns that no amount of float adjustment or bowl reorientation would solve. Simply jacking up the fuel pressure to about 5.5 psi eliminated both problems and, despite dire warnings to the contrary, never resulted in any flooding, etc.
steveg
steveg
Steve--
Michael - I've been using a Facet gold box pump almost since I got the car in early 2000.
I'm looking to get to the BJ8 spec of 1.5 psi (48" head) and 18 gph. Was wondering if, at that pressure, my pump puts out enough gph for my rebuilt engine.
steveg
steveg
Got the Holley diaphragm installed. Backing off on the 4 diaphragm screws allows pressure to bleed off. Finally got it set to just under 2 psi. Will report back when I've done the flow.
steveg
steveg
Did the final science project:
Bought 10 ft of clear tubing and hung it from the garage rafters. When I first started the pump the level climbed about 7 ft and drained into the overflow gallon can I'd set up.
Used the regulator to adjust the pump pressure back to a head of 48". This equaled 2 psi on the gauge.
Then I tested the flow at that pressure - 57 oz in a minute. 26.7 gph. Well over the BJ8 specs.
Then took the car for a drive. Seemed leaner than before, which is good, as I was getting 10mpg.
When I got back to my garage, the pressure gauge was showing zero psi. Car was still running fine.
I don't understand how the regulator works - is the zero because the carbs were full. I could feel the pump vibrating, but the output from the regulator not so.
dklawson
I believe you are over thinking this.
Leave all the regulator housing screws fully tightened. (Loosening them will 1) allow leaks, and 2) alters the pressure setting you are trying to make with the adjusting screw). Loosen the regulator jam nut and adjusting screw. Start the engine. While the engine is idling, turn the adjusting screw in to increase pressure to what you want. Tighten the jam nut and you are done. Obviously this will be easier with a pressure gauge screwed into the regulator.
Holley's instructions are in the link below.
https://www.jegs.com/InstallationInstructions/500/510/510-12-803BP.pdf
The link below is a thread discussing adjustments while the engine is running.
https://www.fordbarn.com/forum/showthread.php?t=81644
dougie
Ditto
Michael Oritt
I'll agree as well and do not see how you are going to affect the fuel consumption (gph) by adjusting fuel pressure down unless you are willing to run in a constantly lean fuel- starved state.
steveg
steveg
To clarify, I'm running my regulator at 48" head (factory BJ8 spec) where my Facet gold box pump is delivering 26.7 gph (vs spec of 18 gph). No starvation going on.
Evidently when the float chambers are full and the float needles are shut, the pump runs but delivers zero psi.
These AFRs were at idle, after a 5 mile drive, while showing zero psi on the fuel pressure gauge.
This is with Martin Jansen's 5/16" float level which results in OzHealey's 3/16" jet fuel level. Rich UN needles.
With the AFR gauges, I'll be working towards improving on my current 10+ mpg mileage.
Michael Oritt
Steve--
My apologies--I somehow came away with the idea that you were seeking by adjusting the fuel pump regulator to achieve 18 mpg as opposed to gph.
What do the AFR gauges show at constant cruising speeds of 2500-3000 rpm's? Your current fuel economy of 10 mpg is about the lowest I have ever seen reported for a Healey!
steveg
steveg
Steve--
Michael - Ha ha - I've made those mistakes myself!
Just got the gauges installed today and only took a short drive on streets and a local road at 50 mph. Will report back after some freeway driving.
The business of "head" on the fuel pump - I'm responding to a post by Larry Varley on the email list re using head to set the regulator pressure. It seems to me to be more accurate than the fuel pressure gauges. I made a setup in my garage with a clear tube attached to a piece of electrical conduit so I could set my regulator according to pump head.
I think some combo of needles, richness and float level should get me to 14-15mpg around town.
Michael Oritt
I never ran across this acronym until just now when I browsed through the topic and saw it in Bob's post #4. So I googled "COTD meaning".
I don't want to incur Reid's wrath and all I will say is that the definition given at the "internet slang" site is quite different from that of the "Urban Dictionary" site.
I think I know the one to which Bob was referring.
John Turney
:scared:
Michael Oritt Holley fuel regulator adjustment Racing 13
B Holley carb set up Triumph 0
R weber 32/36 dgv carb -- holley equivalent? Spridgets 2
chrisc Wedge Tips/Hints on Edelbrock-Holley TR8 Conversion Triumph 4
6 T-Series Who Knows about Old TD Holley Carbs MG 10
chrisc Wedge Holley or Edelbrock for a TR8? Triumph 10
Brosky TR6 OK eBay again Holley 4BBl Intake TR6 Triumph 13
1976Midget Holley 32/36 Carb Spridgets 5
RSMTR8 Holley 390 or Edelbrock 500 Triumph 5
AndreL TR6 Conversion to electric fuel pump Triumph 10
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
A TR2/3/3A Those round fuel line clips Triumph 2
SherpaPilot TR6 Preping a New Fuel Tank Triumph 7
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
G MGB ugh.....the fuel gauge went to *** again! MG 8
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
J MGB Jet Tube to Float Chamber Fuel Leak MG 7
roscoe Fuel Gauge Austin Healey 0
D TR4/4A TR4a Fuel Pump Triumph 10
Erica MGB Carburetion and MGB fuel economy. MG 0
Frameman 1949 New Moss Motors Fuel Tank Austin Healey 10
RJS TR4/4A Fuel Pump Gasket Triumph 8
RJS TR4/4A Fuel Filters and percolation/ vapor lock Triumph 0
J TR2/3/3A Rear Fuel Line Clips Triumph 3
M TR6 Fuel return line Triumph 8
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
mctriumph TR2/3/3A Brand new fuel pumps Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
PAUL161 T-Series Fuel Pumps MG 5
D Fuel Gauge Austin Healey 7
Walter74 Fuel Line Routing Austin Healey 7
D MGB Fuel Pump MG 2
Editor_Reid Fuel Tank Interchangeability Austin Healey 2
Martinld123 Electric Fuel Pump Austin Healey 6
S TR2/3/3A Fuel Pump??? Triumph 14
D Fuel Pump Ticking but Not Pumping Austin Healey 8
A Spitfire Fuel Pump Triumph 5
A Spitfire Spitfire Fuel pump issues Triumph 5
K TR2/3/3A Fuel line routing from pump to carbs Triumph 7
BoyRacer Fuel Tank Sending Unit Austin Healey 3
D Fuel Line Clip vs Brake Line Clip Austin Healey 2
T Wanted Working Fuel Gauge for TR3A Triumph Classifieds 5
G Best fuel option for a 72 Midget Spridgets 5
A GT6 Fuel Pump Leaking at out port GT6 MK3 Triumph 0
wkilleffer MGB 1974 MGB SU fuel pump voltage issue MG 11
S fuel pump upgrade Spridgets 0
