Driveshaft Yoke Orientation
Twosheds
I thought that I read or heard somewhere that the driveshaft yokes are supposed to be 90 degrees to each other. Is this correct?
TRMark
Bronze
No, they should be in the same plane.
PeterK
Look closely at the slider and you should see an arrow stamped in the front section of the propshaft. This should line up with an arrow on the rear, when assembled correctly.
ISTR the yokes can only bolt into the tailpiece on the gearbox and pinion flange one way (i.e. the bolt holes are not a perfect square.)
So as long as the arrows are lined up, it will really on fit one way.
It IS important to keep the orientation of the u-joints in respect to the yokes in the same plane as when you removed them.
Twosheds
Twosheds
Well, The Old Gray Cells just ain't what they used to be. At least I remembered that they were supposed to be a certain way!
Thanks!
Twosheds
Twosheds
TRclassic3 said:
Is there something going on in the Lab we should know about?
No, I'm asking on behalf of a friend (No, really!). He had a vibration and took the driveshaft (TR6) to be balanced.
They said the splines were worn and built him a new one. It came back with the yokes in the same plane. He thought this was wrong and he called me.
I don't trust my bramaged dain enough to give a definitive answer!
J 5 Speed Driveshaft Yoke Austin Healey 25
AUSMHLY BJ8 Driveshaft Installation Austin Healey 10
AngliaGT MGB-GT '67 GT - Pulling Engine - Disconnect Driveshaft? MG 6
Y MGB First of probably many questions - driveshaft transplanting: MG 3
KVH TR4/4A Two Questions: Driveshaft and Brake Cylinder Fasteners Triumph 7
T TR4/4A Replacing rear pinion seal - remove driveshaft? Triumph 21
R 3000 Driveshaft Austin Healey 3
tr3guy TR2/3/3A TR3 Driveshaft Triumph 5
J TR4/4A Driveshaft repair Triumph 4
C Orientation of Driveshaft??? Austin Healey 2
T Spitfire Randall - anyone you would recommend for getting a driveshaft shorted in SoCal Triumph 4
C Spitfire Driveshaft Triumph 10
Scott_Hower Spitfire Late Spitfire 1500 CV driveshaft Triumph 3
D driveshaft question Triumph 4
D Driveshaft Woes... MG 6
M TR2/3/3A TR3 driveshaft question Triumph 5
M Driveshaft length Spridgets 6
M TR2/3/3A TR3 Driveshaft installation Triumph 4
drooartz Driveshaft install Spridgets 11
mgedit TR6 TR6 Driveshaft ... Cork Washer Triumph 7
dklawson Spitfire Spitfire Driveshaft - Which End Where? Triumph 8
N Spitfire Spit driveshaft ? Triumph 10
ronzet MGA Front driveshaft yolk cover - '58 MGA MG 10
Steve1970 driveshaft removal, here's an idea! Triumph 9
Atrus Bolt/Nut thread sizes leaf U-bolt & driveshaft Spridgets 4
jhorton3 Driveshaft Back In Spridgets 3
DNK My *8 driveshaft Triumph 16
Raymond driveshaft MG 10
timbn2 driveshaft question Austin Healey 9
BritCarFan Removing driveshaft from offset sphere joint. British Motor Corp 2
eejay56 Driveshaft radial play Triumph 1
T Name this driveshaft? Triumph 44
R driveshaft tunnel seat belt eyebolt- BJ-7 Austin Healey 3
Team_Sprite HELP! Driveshaft / Gearbox Spridgets 19
J TR2/3/3A Grease fitting access on front driveshaft TR3A Triumph 3
Airfix TR6 TR6 Driveshaft inteference? Triumph 1
Wana How To Remove Driveshaft? Austin Healey 6
G Rear hub/driveshaft setup Triumph 7
wkilleffer Driveshaft/u-joint questions MG 17
G TR6 TR-6 Rear driveshaft/hub Latest Triumph 32
Agrandshort TR2/3/3A Sliding yoke Triumph 11
J Wanted Front Yoke on Drive shaft Spridgets Classified 2
S TR4/4A Recovering Yoke Triumph 2
B Transmission rear bush for drive shaft yoke - no joke! Spridgets 2
Rut Datsun yoke for 5 speed Spridgets 26
tomshobby front yoke Spridgets 4
jerrybny Yoke flange question Triumph 2
KVH General TR Rear Brake Shoe Orientation Triumph 12
R TR6 Drive shaft orientation Triumph 3
roscoe Flywheel orientation question Austin Healey 3
